Question about Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
Encore 802.11 My modem works fine, and when I hook up my router I cannot access the internet. DB
  • bongr_18 Aug 23, 2008
    when i connect the modem directly to my desktop or laptop the connection to the internet is good but when i connect the modem to (encore) wireless router then to desktop i cannot access the internet and at the same time in my laptop but the signal is good.
  • guinicor Aug 24, 2008
    no me entra a internet
  • Encore Master
  • 6,487 Answers
What's the brand of your router?? did you already configure the router to work with your modem and ISP?
Posted on May 09, 2008
Need manual.. Cannot access internet..modem indicator stays orange
Per chance have you looked on YouTube for a video on how to hook up this particular router: Generally they have a video for just about anything imaginable. Good luck!
Jul 28, 2014 | Belkin N750 DB Wireless Dual Band N Router
Yesterday had Cable Internet hooked up at new house--when done modem had all lights green, and wireless router connected and worked fine. Now router won't connect to Internet, and USB connection direct to...
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Jan 04, 2011 | Motorola Computers & Internet
Access to internet through the modem works fine. As soon as I hook up the router, no access. I have booted up the modem, the router, and the PC with no luck. I have pressed in the reset button on the...
you can not acces the internet if you reset the modem and the router. once you reset the router it set back to original factory setting. theres a certain configuration for the modem the router especially for the ip address. you have to get in touch w/ your internet service provider for the modem and router configuration.
Jun 07, 2010 | Computers & Internet
Hook up router and can't access internet from wired computer.
Sometimes the modem-computer-router not "sync" together.
Try this.
1-hook the computer to modem. Internet yes? good.
2-hook the computer to router and check you IP. If it like,
the router's DHCP is working.
3-reset router to default setting.
turn off all and turn on modem, router, computer.
keep me posted.
Jul 06, 2009 | Belkin (F5D7231-4) Wireless Router
My two computers cannot pass through my broadband provider (through the switching hub) at the same time.
that is not possible for an single isp connection you can only connect one computer at a time and hub is basically a repeater that is it simply repeats the packets it receives from one input out the others.
May 18, 2009 | Encore ENH905-NWY (ENH905NWY)
Router worked. Modem quit. Now it won't work with new modem
Ok in this case the problem is more than likely a generic one for all modems. All modems like to bind themselves to whatever device you have initially plugged in when you plug in the power cable for the modem. My guess is you had the pc hooked up directly to the modem and then plugged in the poewr cable to the modem.
To fix this you need to unplug the router and modem cables for 2 minutes. Plug in the modem with it being hooked up to nothing but the wall [Power Cable and Internet Cords hooked up only; no pc yet]
Your router is probably not need to be bridged so there should be a small hole somewhere on the router normally on the back or bottom saying reset. Press and hold that button with the router only plugged into the power no internet or pc [Although it doesnt matter if the pc is hooked up to the router] for at least 10 seconds. This will cause the router to reset to the factory default settings undoing the bridge. After this time the modem should say it has internet and whatever else except a activity light and similar things.
What you want to do now is unplug the router from the power and hook up the modem to the router and then plug the power cable back into the router.
After all this you should be able to go into the pc and access the router and set up the settings you like or need for the router if you want. Otherwise you should have internet again.
Jan 13, 2009 | Linksys Wireless-G WRT54GS Router...
85 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
