Question about Canon imageRUNNER iR C2880 Color Copier
Irc 2880 black drum giving white line, so is there any way to get rid of this line when i take 10 no. copy from service mode
  • 1,219 Answers
change the drum unit, or try to dismantle it and clean but these is not recommended.
Posted on Aug 31, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Tip
Get rid of the line in your faxes or copies from your copy machine
If you are getting one of those black lines in your copies from the copy machine/fax machine, it may not need a new drum.
Most likely the scanning glass is dirty if the line appears from copies that are fed through a feeder, clean the little glass strip area (usually to the left) just before the scanning area where you manually place a paper to be copied. In most cases there is a spec of something on that glass. Don't scrap it with anything abrasive because if you scratch the glass you will have a line that will never go away. In most cases a damp klenex, paper towel or soft cloth with water will work. For stubborn specs dampen your klenex, paper towel or cloth with a little rubbing alcohol. This will also work well for getting rid of any greasy smudges on the glass strip and the larger glass area on the copy machine. Most of the thime the spec is from liquid paper or white out.
If you are getting calls from people you send faxes to saying your copies have a line on it and you use a dedicated 'fax machine only', look for the glass strip and clean it as directed above. If you are receiving faxes with a line, call the sender and give them the above tip.
If this tip works, it sure beats paying for a new drum you don't need.
on Aug 25, 2010 | Office Equipment & Supplies
How do you reset drum and developer counters
Press the Utility/Counter button then meter count then details then stop 00 stop01 to access service mode then clear drum and developer do not exit out all the way once counters are cleared touch end then power off the main PWR ON/OFF switch located on the left hand side of the machine in the rear then remove the Drum Cart and replace drum and Developer then reinstall drum cart. Enter service mode again Run Function F-8. Do no print or copy before doing this. So disconnect FAX line and Network cable.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 08, 2014 | Minolta bizhub 350 Black and White Copier
Need to replace the drum on a minolta bizhub 350 copier
First get into service mode. Utility/Counter then meter count then check details. Then Stop 00 stop 01. Counters. Clear Drum and Developer. Then touch end do not exit all the way out of service mode. Turn off the machine using the main on/off rear of machine left hand side. Then remove the image cart. and replace the drum and developer. then turn machine on reenter service mode. Run F-8 found under Function. Do not print copy or allow fax to print before this is done. Or you will have to replace the developer again. So remove network cable and fax line if machine is as printer and FAX. after powering off
Jan 15, 2014 | Minolta bizhub 350 Black and White Copier
I am trying to find the drum, I have a line on my copies and would like to get rid of it.
The line is only in your copies?????
If so you problably have the mirror scanner durty.
Make a print and see if the line are stil there. If so, open the front door and next to the toner unit you will see the fotoconductor unit. inside you have the drum. I advise you to change not only the drum but also the blade.
Just make sure the line apaned also copy and print. If so you are right, the drum is faulty.
Good luke
Feb 21, 2011 | Ricoh Aficio 2022 Black and White Copier
CANNON IRC -2880
this code is for a bad OHP sensor, wich detects transprerencies.
Aug 19, 2009 | Canon IMAGERUNNER 2230 Copier
White line and very, very dirty copies
the nealy black copies sounds like the drum is going, try adjusting the exposure to light, if it comes out with the whole page the same way but just lighter than change drum. White line sounds like there is something on the coronas.
Jul 22, 2008 | Canon PC-940 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Copies here and recipients faxes: dark, lined
How long has the drum been in there?
try this:
1-take out toner, look and see if it is ok. do you see stripes on it?
2- look at the drum are there any black rings on it? ( you did not specify white or black lines)
3- where the glass is on the opposite side ( the part you lifted to clean the glass, look at it standing from the back. you will see a white metal plate with some springs in it if you touch it. this is the reference that the fax has if there is/are a black dot on it it will give you a black line clean carefully. if it is scratched use white out to cover and make white again.
For the darkness try making a copy in photo mode if it is still too dark change drum.
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Canon imageRUNNER iR C2880 Color Copier Logo
253 people viewed this question
old marine
old marine
