Question about Pioneer AVIC-N2 Car DVD Player
Bypass for N2
How...EXACTLY do I perform a bypass for the N2? Im new to this...so if possible, break it down thuroughly! Thanks!
There are to steps, very simple...
solder two points under the silver sticker on the bottom of the head unit (pay a pro! don't mess up your deck!) then you ground the light green parking brake wire (attach it to the black ground wire coming out if the same harness) this will give you "full function". i have this unit and have the upgrade, it works.
Posted on May 22, 2008
Soldering under 'VOID' sticker
I think you should let who ever do it for $30. Because the procedure take about 1 hour or longer for a professional. You have to strip it down to the bare mother board and the solder points are smaller than a pin tips packed with tiny components with only hair line space in between. Beside that you can rip the ribbon cable and/or knock your laser assemblies out of alignment and countless of other things can go wrong like tiny micro springs, switches and gears can pop out of place with a slightest touch. But if you still want to give it a try, you can find the instructions, pictures and diagrams on avic411.com forum. You just have to look through it, but it is there. I had to pay for my from Ebay, and I am a master solder tech and it is still is challenging everytime I do it. Goodluck.
Dec 06, 2008 | Pioneer AVIC-N2 Car DVD Player
Avic bypass
The original Avic N1 only needed to have the parking brake wire grounded for video in motion. Then, the latter series came out and on the underside of the in-dash unit, they have a foil sticker that needed to be removed and a jumper carefully soldered on the circuit board. Avic N2's had a switch installed under this sticker to avoid people from making soldering mistakes. I think the N2 brain may be looking for an N2 unit and giving you trouble. more info on this subject is available @ www.avic411.com.
Aug 04, 2008 | Pioneer AVIC-N1 Car DVD Player
Avic-n1 bypass
Heres a good site that has alot of bypass guides for Pioneer Avic Units
http://underground-secret.com/avic_n1_bypass.html
Pioneer Avic D1, D2, D3, N1, N2, N3, N4, Z1, Z2, Z3, F700BT, F900BT & F90BT.
Aug 03, 2008 | Pioneer AVIC-N1 Car DVD Player
Avic N2 Issue
You can still perform the bypass internally. The N2 is done by connect the two points under the VOID sticker and the N1 will have to be taken apart completely. Unless you are a pro, I would recommend that you have it done professionally. Sound like someone tried and put too much solder and then cleaned up but also took out the pin. If you need I can perfome the bypass or if you have enough guts I can walk you through it. The instruction is sellling on Ebay for about $10. Unless you are really technically incline it very easy to fry your unit beyond repairable. Goodluck.
Jun 12, 2008 | Pioneer AVIC-N2 Car DVD Player
E- Brake Bypass
This forum should have what you are looking for:
http://www.avic411.com/forum/viewforum.php?f=11&sid=d2e7eb58b07df6e1abc1cd149fb69b3a
Apparently, you are not alone!
May 22, 2008 | Pioneer AVIC-D3 Car DVD Player
AVIC N2 parking brake bypass
There are two ways to complete this project:
1st
underneath the mounting bracket of the radio not the brain theres a silver sticker like mentioned above there are two silver solder points right beneath the sticker it must be jumped with a wire or you can use the solder to connect the two contact points after this you must still ground the green parking brake wire to the car.
2nd-(also my favorite choice and the one I'm using on my N5 & on my 7800dvd those who know pioneer know what i'm talking about)
buy a ptr7 pheriphial device and wire as follows (they come factory ready to bypass alpine and pioneer units)
wire as follows-white wire to green parking break of the deck your bypassing
red wire to vehicles 12v source
green wire from device to remote
black wire to vehicle ground wire
final important step I know because this happended to me
make sure you take a little screwdriver agfter wiring or something and switch the
PTR 7 to the off position-or else this will make the PTR7 not function correctly
May 08, 2008 | Pioneer AVIC-N2 Car DVD Player
Bypass NAVI
Ummm, its against the law for the driver of a motor vehicle to able to see the screen of a tv or dvd player while the vehicle is in motion! Dummy, watch the road!!!!!!!!
May 07, 2008 | Pioneer AVIC-Z2 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
N1 internal solder bypass to work with newer software, N2 solder the two connection under the silver sticker(might void warranty), N3 switch the switch under the silver sticker(might void warranty). Goodluck.
Mar 31, 2008 | Pioneer AVIC-N2 Car DVD Player
Not pioneer but kenwood indash dvd player what easy way
Run your parking brake ground throught a manual switch and switch it off before you turn off your car everytime. Goodluck.
Nov 08, 2007 | Pioneer AVIC-N2 Car DVD Player
Pioneer AVIC-N2 Car DVD Player Logo
106 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
