Question about Dell Dimension 4700C PC Desktop
Dell 4700C randomly goes into "sleep mode" and doesn't wake up.
I have a Dell 4700C and lately it has been entering into sleep mode while it is being used. The screen will go to black and the green monitor buttom will turn amber and I can tell the background programs are also frozen. The computer will not wake when I move the mouse or press a key. It either occurs randomly or when I'm using multiple programs or starting Windows. I have searched for Adware and Spyware. I have even did a clean sweep of the hard drive and reinstalled Windows. A few months ago I upgraded the memory and replaced the power supply to fix a previous problem. I don't think the new problem has anything to do with the old one but I'm not sure if this is something that can be fixed easily or if there is just too much wear and tear and I need to purchase a new pc.
  • 3 Answers
Honestly, my first suggestion would have been to upgrade your memory. If you go into control panel and check your power settings (I'm assuming you're on windows XP) Do you have all of you options set to "Never"? You may also want to check your BIOS settings to see how your sleep/hibernate is set up. Aside from that, you'd have to run some hardware diagnostics to give a better idea of what to look for. Hope this helps!
Posted on May 09, 2008
Why and how does my fitbit flex go into "sleep mode?"
You can enter or leave the "Sleep mode" by tapping the Flex rapidly for 1-2 seconds. You'll feel a vibration and the LEDs will blink. (The blinks will depend on if you are entering or leaving sleep mode.) In this mode, the Fitbit Flex reduces the LED intensity and doesn't give alerts. Afterwards, it will provide some data about your sleep pattern - length, movement, waking up during the night. This can help you determine the quality of your sleep. (Note: it isn't a replacement for consulting a doctor if you always wake up tired.)
I hope this helps.
(You can manually enter your sleep and wake times into the app without using "Sleep mode". Then the app will use the movement data from the Flex to determine sleep quality. However, LED lights (primarily blue frequencies) are known to reduce sleep quality so dimming them helps most people sleep better. The alerts will also interrupt your sleep and reduce the quality.)
Jan 11, 2015 | Fitbit Flex Wireless Activity & Sleep...
How to wake Dell All in One, Win 7, from sleep mode
In Windows 7, there is a bug, if you put the PC in sleep mode when the system is running on batteries then it may still drain out the batteries and you cannot wake it up. In this case, you need to connect the AC power and reboot the PC. If you put the Pc to slepp when the AC power was connected. Then there are no issues and just by pressing the enter key it should come out of sleep mode. Sometimes - depending upon settings - you may need to press the Power button the PC to wake it up from sleep mode.
If you have already tried all this, then please go to the Power settings in Control panel and check all the setups that exist. You may need to change some of them.
May 25, 2014 | Dell OptiPlex 760 MT Desktop Computer
Sleep function
Usually pressing the power button once will wake a computer from sleep. Often all that is needed is a mouse movement or hitting the enter key. If your are in Hibernation mode as opposed to sleep mode
The key stroke(s) needed will be in the Power Settings section of control panel.
Mar 23, 2014 | Dell Precision M4400 Notebook
Laserjet 1536dnf mfp not waking out of sleep mode
Disable sleep mode or update firmware. Cause this is a firmware bug.
Nov 13, 2013 | HP Laserjet M2727nf Multifunction Printer
I put my Dell Dimension 9200 XPS 410 into sleep mode after connecting a wireless keyboard and mouse and the only way to wake it is to hold the power button in until it shuts off and then switch the power...
I would say it is in the Hibernation Mode To get it out of this mode you need to go to your Control Panel, open "POWER OPTION'S" and deselect the Hibernation mode then reboot.
Sep 26, 2013 | Dell Dimension 9200 PC Desktop
Dell inspiron 1545 goes to sleep while in use
The solutn is...please uninstall..the AHCL driver from ur pc..then the problm is solve...try it...thank u..
Mar 26, 2013 | Dell Inspiron 1545 Notebook
My HP w2007 has started clicking to Monitor Going to Sleep and then going blank. I have never known how to wake it up so I have to turn the whole computer off and restart. HELP
Hey there, Normally simply pressing a random key on your keyboard or moving your mouse should wake it up, if it doesn't though I think the easiest way to solve this is to simply turn off the sleep mode after x amount of time.
If you have windows 7, press the start button and type in "power options", go ahead and open power options and there you will be able to set the time it takes before your PC shuts down, and you can also set it to never.
If you still wish to use this feature but just want to be able to it's a bit tricky and it won't even work for all PCs but if the keyboard waking isn't working, then it's probably because your pc does have this feature. When your PC is off, boot it up again and enter the bios by pressing F10 i believe it is for HP. And somewhere you should be able to set which devices are allowed to wake up your computer, all devices are probably disabled now, so go ahead and enable the keyboard to wake up your computer. Now save and exit, and the next time your PC goes to sleep mode you should be able to wake it up by pressing a key on your keyboard.
I hope I was able to assist. If I was, please don't forget to rate this solution.
Jul 28, 2011 | HP Pavilion F1523 15" LCD Monitor
Hii iam pankaj i have dell SE178WFP LCD monitor. My problem is whenever i start my pc monitor shows that it is on power save and monitor starts blinking.. what can be the problem and how it can be...
Try holding down the fn and f8 keys or if your problem is you cannot wake from power saving mode (after your PC goes to sleep, then its probably just the driver for your video card). VISTA has some issues with certain drivers that the PC cannot wake from sleep
Jul 30, 2009 | Dell E176FP 17" LCD Monitor
Can't wake up....gone into sleep do you wake it up
press and hold the power button down for about 5 secs. The computer will shut down. Restart it and right click on the desktop, go to properties then look for screensaver tab , then choose power options, click on hibernation tab at the top and uncheck enable hibernation. Or choose stanby options and choose a longer time before the computer goes to sleep.
Mar 21, 2009 | IBM ThinkPad T23 2647 Notebook
Dell Dimension 4700C PC Desktop Logo
659 people viewed this question
Alun Cox
