Question about Texas Instruments TI-89 Calculator
I'm trying to graph y=-2x^2 and it says "window variables domain"
    Sergeant:
  • Texas Instru... Expert
  • 266 Answers
Press diamond key, then window and then input the following values:
xmin = -10
xmax = 10
xscl = 1
ymin = -10
ymax = 10
yscl = 1
xres = 2
Then graphing function. See cap image
Posted on Mar 08, 2012
4 Suggested Answers
  • 8068 Answers
SOURCE: everytime i try and draw a graph it comes up with
The window variables are not correctly set. Xmin < or = Xmax; Ymin < or = Ymax. Press Apps key, select Window editor. In Window Editor set the values of Xmin, Xmax, Ymin, Y,ax or press F2:Zoom and press 6:ZoomStd.
Hope it helps.
Posted on Nov 22, 2009
SOURCE: Error in graph
try loading a saved graph it will clear the wrong settings
Posted on May 29, 2008
oneplusgh
  • 100 Answers
SOURCE: Today i was trying to
Your ranges for your window settings are more, or less out of bounds with the equation y=2x+23, that you entered.
Press the [green diamond], and the [F2] keys to bring up the graphing coordinates. Enter the following values to fix the graphing coordinates. Starting at the top, xmin= -8, xmax= 8, xscl=1, ymin=0, ymax=40, yscl=1, xres=2. Now, press the [green diamond], and the [F3] keys, and the graph should display.
Posted on Dec 19, 2010
How can I graph Y= 2X+3 on an HP 48GX? I have
Enter the equation as 2*X+3. Make sure that the name of the independent variable X in the equation and that on the INDEP:X line are both Capital letters or both lowercase letters.
Aug 28, 2013 | HP 48gx Calculator
How can I graph Y=2X+3 on an HP 48GX? Thank you!
What is the domain and range of the functions y=2x-3
For y = 2x-3, both range and domain are from -infinity to +infinity. If you wanna read more about it, please open the following link: http://www.intmath.com/functions-and-graphs/2a-domain-and-range.php
Jul 06, 2011 | Cell Phones
I don't remember how to type a piecewise function into the y= screen so that i can specify i want one graph (.5x+5) from 0&lt;x&lt;10 and the other (10+2x) x&gt;10
Here is an absurd example of a piecewise function
Y1=11 for X less than 10
Y1=3 for X in the range [10, 20[
Y1=X+5 for X in the range [20, 30[
Y1=10 for X larger than 30
Here is the screen capture of the Y= editor window.
You have
  1. the definition of the function within a domain, enclosed in () followed by the domain enclosed in ()
  2. a + to introduce the second piece (definition) (domain)
  3. + a third piece (definition ) (domain)
  4. and so on.
  5. Use the [2nd][TEST] key sequence to access the relational operators, less than, greater than, etc.
Here are two screen captures for the Y= editor and the resulting graph. You have to play with the window dimension to display a clear graph. Note : 3 pluses in equation, 4 pieces in graph.
The + in the definition of the function, (X+5) in the third interval does not count towards the number of pieces.
You can use the logical AND operator in the definition of the limits of a domain. See screen capture below.
Jan 20, 2011 | Texas Instruments TI-84 Plus Calculator
Today i was trying to graph y=2x+23, but when ever i would press graph it would pop up window variables domain. What do i do to fix this?
Dec 18, 2010 | Texas Instruments TI-89 Calculator
Won't Graph Exponential Function
Ok, try these two things and you should be just fine.
1.) Check your range for your graph. It is possible that the range you are using isnt large enough to show the curve. Also try using Z-fit vs Z-st. These are options that your calculator will give you once the equation is graphed.
2.) Place a parenthesis around the 2x, make sure that you and the calculator are both using the same order of operations. This move mill ensure that the calculator will multiply the variable, x, by two and then do the exponential.
This should do it!
Happy Graphing!
Jul 25, 2010 | Texas Instruments TI-84 Plus Calculator
Graphing Problems
In home folder (main calculator screen) press [Diamond][F2:Window]] to access Window configuration screen.
Press [F1] ( not mecessary now because the F1 page is open by default). In the F1 page of configuration screen set Xmin=-10,
Xmax=10
Ymin=-10
Ymax=10
Xscale=1.
Yscale=1.
OR
Press [Diamond][F2:Window][F2][6:ZoomStd] (Zoom Standard) to set all values as above.
If a graph is active (axes displayed, or part of a curve is showing) press [F2:Zoom][6:ZoomStd]
Feb 15, 2010 | Texas Instruments TI-89 Calculator
Windows variables domain. What does this means? I can't plot my graph.
It means that there's something wrong with your window variables.
Press Diamond F2 to bring up the Window editor and examine the values. Make sure that xmin<xmax, ymin<ymax, and the other values make sense for what you're trying to graph.
Feb 09, 2010 | Texas Instruments TI-89 Calculator
Everytime i try and draw a graph it comes up with window variables domain
Hope it helps.
Nov 22, 2009 | Texas Instruments TI-89 Calculator
Error in graph
...with this process you will erase everything....
press "2nd" function and then "Mem"
then press "F1" and choose "3"
Press ok, and then wait, THAT'S IT!
May 20, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
63 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
