Question about Sharp CV10NH Air Conditioner
The AC doesn't seem to cool when the temperature in the room in really high, in the range of 90-95F. It works for 3 minutes, and then stops for 3 minutes. Also, I have read the booklet that came with it, and it says that it's not supposed to work when the temperature is over 95F. What kind of a silly rule is that?! I mean, that's why I bought it! Is there something wrong with my AC, or is this normal?
  • Sharp Master
  • 43,501 Answers
What happens is that the high pressure side gets too high when the temps are very high...that is why it is shutting down....without getting very technical there are good reasons why they would set this unit up to work at temperatures 95 and below...
try to get the room temperatures below 95 and then make sure you leave it run so that itmaintains rather then shutting it down and trying to reagin the cool again... this is actually more efficient if you are not away for days at a time...
So yes, that is very normal...
heatman101
Posted on Aug 31, 2010
Testimonial: "Thank you."
  • Coconut-Lime Jun 11, 2011
    We have one that worked for years. Now it blows cool air out the exhaust (used to be hot air) and the compressor kicks-off just seconds after attempting to start up (the lights dim just a bit while this occurs). Don't know what to do about it. Don't have a sales receipt, but Sharp said the compressor is probably still under warranty due to the date code "07 A". Can you please elaborate some on what this problem could be?
  • Randy Buck May 12, 2014
    More than likely it has a bad run capacitor for the compressor. They are fairly inexpensive to replace.
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
How much more efficent is this than my 40 yr old janitrol 125000 btu beast
not knowing what you are replacing it with, it is hard to give a reasonable answer ( old sealed units against split system converter ac units )
However if you work along these lines, you will come to a logical decision
First off the old machines had the compressor operation tied to the thermostat setting so the compressor ran full blast until the room cooled to the set temperature. Then it stopped and remain stopped until the room heated up. At this point the compressor restarted and that is the point the the most power is consumed
again it runs full blast until the room again cools and switches off
So you can see that you have a varying room temperature and high energy consumption on start up
Now compare that to inverter units
The compressor is running all the time ( no high energy start ups every 10 minutes or so) but the compressor becomes less efficient as the room cools down
Still running at full rpms but the controls reduce the compressing action--less power to run the compressor--so there is a reduction in power used
The temperature variation is reduced because as the room warms a bit the compressor pumps a bit more gas and doesn't start at full load as per the old unit
Next , the latest units have better temperature / humidity recognition controls so they can be set at night so a room maintains an ambient temperature /humidity so that as the night gets cooler and the air drier you don't wake up freezing
It will even get to the point where you wonder if the unit is working
Lastly you can run the unit at a much higher setting ( 27 Degrees c instead of 24 or less and have the same comfort level as at 24-25 degrees c)
lastly warranty is for 2 years at best and parts will be available for the next 10 years against parts for your old unit
Mar 21, 2016 | Heating & Cooling
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
Aug 06, 2012 | DeLonghi PAC A120E 12000 BTU Portable Air...
Fans only run with ac on
These are classic symptoms of a failed coolant temperature sensor. The description doesn't include the year of your Venture so ask the part store for a location of the coolant sensor and you should be able to change it yourself. One really easy way to tell if the sensor is bad is to unplug it, if the fans come on shortly after you unplug it, then the sensor is bad and the wires are fine. There are two sensors, one for the gauge, one for the computer. The one for the gauge is working since you get a reading, make sure you clarify the one you need at the part store.
Apr 04, 2012 | Cooling System for Chevrolet Venture
Hi. I recently installed 1.5 T, 3 * Split AC, LG. Whole day the AC works fine and no problem in cooling too. But once in 2 day outdoor unit start making thudding noise continously and does not stop for 4...
Hello
Sounds like the compressor is shuting down on high heat.There could be a couple reasons for this.
1 Check that proper voltage is being supplied to compressor.
2 Freon level may be low.This would be a service call.
3 Bad or intermitent connection at thermostat.
4 Main contacts to compressor sticking,usually burnt or pitted.
Apr 08, 2011 | LG Heating & Cooling
Infocus LP530 will turn on and work great for 15 minutes then shuts down and the green light turns orange and blinks. The Bulb only has 283 hours on it.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work get a small fan and place it near the projector ro provide extra cooling. The projector is running border line on high temperature and just needs a little extra cooling.
Jul 20, 2010 | InFocus LP 530 Multimedia Projector
After having the projector on for 15-20 minutes the lamp will go out for 1-2 minutes then turn back on with no intervention This will repeat at no set intervals. The projector is not quite 5 years old...
get a small fan and place it near the projector to provide
Jun 28, 2010 | InFocus ScreenPlay 7205 Multimedia...
During cooking, the microwave will work for about 3 minutes then completely shut down.There appears to be a complete power failure.After the units sits for about 5 minutes,it resets itself and you can cook...
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
Oct 20, 2009 | Samsung SMH7178STD Microwave Oven
Soleus KFGHP-09-ID Mini Split
This is normal operation for these styles of minisplits. The thermostat is not in the remote but is located on the return air of the indoor coil, so the air needs to be flowing in order for the thermostat to measure the rooms temperature. Set your fan speed to auto and the fan will slow down when setpoint tempurature is met.
Phil Hodges,
Tech support Soleusair
May 18, 2008 | Soleus KFS18GW 18,000 BTU Heat & Cool 230V...
Vent fan runs intermittently, starts on and off regularily
I don't have the manual but there should be a temperature setting for the fan to come on.
Jun 23, 2007 | Bosch HMV9305 Microwave Oven
Sharp CV10NH Air Conditioner Logo
755 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
