Question about Bissell Vacuums
I have a bissel carpet cleaner however there is a part that snapped, where would i be able to get the part i need?
  • Bissell Master
  • 17,129 Answers
Only way out for you is to either check up your nearest Bissell service dealer to take along the broken part for a spare or repair. If however there is none around then check if it can be salvaged from any old Bissell sets.
Since the specific part is not disclosed , have it checked with an expert.
Posted on Aug 31, 2010
No suction on my Pro heat steamer
You may want to check to see if the removable nozzle is correctly placed into its place. This is the plastic part where the water is sucked up through by the carpet cleaner. The nozzle notches must fit into the groove on the cleaner correctly and the metal bar need to snap back on top of the removable nozzle, Also sometimes if you have hair trapped in the nozzle or the bristle, it will affect the suction power of getting up the dirty water. The dirty water tank need to snap in place by making sure the top of the gray snaps on each side is over the top groove of the dirty tank on each side and the the gray snaps are pushed down and pushed into the tank to until it is snapped in place.
Super Simple answer could be: The Dirty water tank could have bubbles in it causing it not to **** too.
Mar 03, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell carpet cleaner won't dispense the
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fdghd
Apr 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I need instructions on how to use my machine. Can you please help!
if its a bissell,go to bissel .com and request a manual sent to you.there should b a cartridge that you push a button to unlock so u can fill it with water or carpet shampoo.I fill mine half water half carpet shampoo. then u put it back on ,make sure it either clicks or snaps on.plug in and turn on,they usually have a button that turns that say wash or rinse.it depends on your machine.
Jan 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
How to use the bissell proheat Carpet cleaner 8910
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Jan 18, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
The bissell proheat turbo carpet cleaner is not sucking up water.
heatman101
jer
Jun 08, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell proheat 2x carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
May 30, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Replacing the little black rubber belt
bissell.com has videos on how to replace belts.
May 04, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
How can I get the vacuum up feature to work
I didn't have the grey snap lock in the correct locked position--once that was securely locked it worked fine
Mar 31, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
How to change the belt on a bissell powerbrush deep carpet cleaner.model 1694
Turn the machine OFF (O) and unplug from
the outlet. To check if the brush belt or
pump belt has broken, you will need a flat
head screwdriver. Insert the blade end into
the lower slot of the belt access door to
release the lower snap. If necessary, insert
the blade end into the upper slot to release
the upper snap.
Hope this helps.
Richard
Mar 10, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Schematic parts diagram for bissell proheat 9200 carpet cleaner
Hi, just go to amazon here: Amazon com bissell proheat carpet cleaner parts and you can find every needed parts. I hope this was helpful. Cheers
Jul 24, 2008 | Bissell 9200 Upright Vacuum
Vacuums Logo
53 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
