Question about Holmes Products BH3955-U Bionaire Utility Heater
Off/on switch only stays in Of positmpsp2@alum.rpioion even though the u;nit turns on.
  • 857 Answers
It seems to be a mechanical problem, the most probable cause is the bad switch.
Try to open it and see you will come to know about the faults.
There i nothing to worry because the product is working so everything is else is fine.
Posted on Aug 31, 2010
The sound keeps going down will not stay up even if u turn it up manual nit though thr remote
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 22, 2015 | Emerson LC320EM9 32 in. LCD HDTV
I have a 2001 Pontic Sunfire. My clock and light stay on. How do I turn this off please?
It should go off after the car is turned off and you open the drivers door. It may stay on for a few minutes then should go out. If not you may have another problem like a bad drivers door switch. But if everything rlse is working properly associated with the door switch for example interior lights something could be wrong with the unit or its not hooked up correctly.if its not the factory unit its most likely nit properly wired up.
Sep 01, 2014 | Cars & Trucks
Brake lights stay all time without car being on
So they stay on when the car is turned off with no engine running?
I imagine this flattens your battery?
Or do they only stay on once the ignition has been turned to "on" even without the engine running?
Could be the pedal switch sticking in which case you would simply need to look under the dash behind the pedal and try and "jiggle" the switch, though if they only stay on once the ignition is on I would lean towards a bad earth for the globe socket.
First maybe try and disconnect the pedal switch to ensure that its breaking the connection properly and turning your lights on and off.
Depending how handy you are, you could remove the tail light and run an additional earth for the globe socket.
Apr 09, 2014 | 1994 Geo Prizm
LCD TV won't turn on- power light flashing
This is a very common symptom of a failure in the power supply board. The failure is caused by parts called capacitors. Here is a link to information on what needs to be replace on the power supply board to repair it. It is an easy repair, takes about 20 minutes.
http://www.ccl-la.com/catalog/product_info.php?cPath=95_97&products_id=216
Jul 21, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
No it's not beyond the sleep problem but the problem is that I work on my pc will fall to sleep and as I alume alume does not and remains in standby and I have nothing to do that will stop
You can program your "Power Button" to do a lot of things or even nothing.
To program go to "Control Panel" "Hardware and Sounds" then select "Power Options". Here you can "Change When the computer sleeps".
Hope this helps.
May 31, 2012 | Dell Optiplex GX280 Intel Desktop PC -...
Tiburon 04, left turn signal lights stay on once activated by either turn switch, hazard light switch, or alarm. Can sometimes get them to go out by using right turn switch position, or playing with hazard...
replace the turn signal 'Clicker' also known as the turn signal relay. Most likely the problem unless you have a really wierd electical issue that will be hard to isolate...
Peace,
Jan 23, 2010 | 2004 Hyundai Tiburon
Suzuki katana 600 not running
check your starter switch, it may be even grounding, which would cause all these problems
Jul 30, 2009 | 1992 Suzuki GSX 600 F (Katana)
Holmes Products BH3955-U Bionaire Utility Heater Logo
Top Holmes Products Heating & Cooling Experts
paulcarew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
