Printer says "unlock scanner" I don't know what that means or what to do to make my printer/scanner work.
  • Anonymous Dec 11, 2008
    printer says "unlock scanner then press power"
    Problem Solver:
  • 18 Answers
Hi djmac,
Have you tried reinstalling the logical print/scan device?
Terry
Posted on May 08, 2008
My xerox work centre 4118 is locked How am I going to unlock it
Do you mean your "Scanner" is locked? Were the paper exits to the left of the opening there should be a sliding switch. I suggest that you should use a flashlight to locate it This is the locking mechanism that once toggled , it will unlock the scanner. Remember to turn-off the printers power before attempting this.
I hope this resolves your problem, Steve
Nov 06, 2015 | Xerox WorkCentre 4118x multifunction ( fax...
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
My HP Officejet J4580 All-in-One scanner does not work. Whenever I would turn on the printer, the scanner head (or what ever the thing with the light is) would start "clicking" and not move from...
1. Too much friction while moving the optical scanner unit.. Open the flat bed scanner lubricate the rail
2. Optical scanner unit faulty,remove the scanner unit open it gently, clean mirrors in side the unit with ear buds re-fix & clean the flat bed mirror neatly especially at home position.. re-fix as it is then check..I suggested this activity for only tec guys..
Sep 10, 2011 | HP OfficeJet J4580 All-In-One Laser...
Hello, I have a Lexmark 2670 which is relatively new. When trying to print an alert keeps popping up saying "Scanner Unit Open". I've tried different things, but don't know why this is...
Hi
Check your System scanner application is running. Open the End Task manager select the tab process and see there may be scanner.exe is there select that one and click end task.
Try it.
Cheer
Jun 05, 2011 | Lexmark X2670 All-In-One Printer
Hello, I am attempting to scan an important document and the printer keeps saying "set the document on the platen glass" the document is there but it keeps saying the message
The best way to scan images to save on yourcomputer is to use the scanner software on the computer. Not the scan functionon the scanner.
You don't say what type of scanner software you have but usually scannersoftware works this way:
1) Place photo on scanner
2) Open scanner software
3) Using the software, Initiate scan
4) Name the Scanned item and save it to your desired location/folder
Note: some applications will automatically save to --My Documents--My Pictures
5) Repeat process for each pic to be scanned
May 01, 2011 | Canon Pixma MP480 All-In-One InkJet...
My printer is X4690. I have been using the scan function quite frequently. Today it won't work. It is getting stuck on "downloading applications". I have tried to reboot it but it persists. Print...
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps don
Mar 13, 2011 | Computers & Internet
Canon PIXMAMX347 1. My Print and Fax Screen shows that the "Canon MX340 Series oOffline,Default". How to I get it back to "Idle, Default" which is the equivalent of "Online,...
right click on the printer driver and read through all the task you will see online then click on it if the problem persist Delete the printer driver then reinstall it back it will work and make sure you don't have more than one printer driver on your computer iF you does notice the one that is ready when you put on your printer then make that one your default printer driver if this confuse you delete all the printer driver and reinstall new one.
Jan 30, 2011 | Computers & Internet
Please help... Says "scanner locked"
Power off the printer. There is a green tab located in the paper output section of the printer. If you side your hand below the keypad on the left side you will feel the tab sticking down. Pull the tab towards the front of the printer to unlock the scanner. Then power on the printer, this should remove the scanner locked message. Hope this helps you.
Jan 26, 2011 | Samsung CLX-3160 All-In-One Laser Printer
Have a Xerox M20i Copier/Scanner/Fax. Display indicates "Scanner Locked" Cannot make copies nor fax out. Please help
If you look under the scan assembly you will see a yellow or green tab which locks the scan head. Try locking and unlocking it a few times then on the final unlock reboot your printer.
Jan 18, 2011 | Xerox WorkCentre M20i All-In-One Laser...
I can print, but I can't scan. Printer screen says "Problem" and tells me to "Try scanning from computer".
hope this helps
Jan 17, 2011 | HP Officejet 6200 All-In-One InkJet...
229 people viewed this question
jasbo
jasbo
