Question about Teac DUAL CASSETTE A/R 110/220 Single Dual Cassette Deck
Replacement belt for Tascam 122
Do you know where I can get a replacement belt for a Tascam 122 cassette deck
    Scholar:
  • 54 Answers
Well, after a quick search on the net, the only place I can find that still carries them is consolidated electronics in the USA. I have ordered from them years ago and they were very good. You will find an online catalog and how to measure your belt to get the right one.
NOW.....when belts go, the rubber deteriorates with age. The belts stretch. Carefully, without stretching the belt further, place it on an inch ruler, belt laying flat. Make tight corners on the belt by pressing one side against the other and measuring the length against the ruler. The belt length is the measured length times 2. Write this number down !. Try stretching the belt A LITTLE....if it snaps back to length, then it isnt in too bad a shape, and you can order a belt 3% smaller and one 6% smaller. If you stretch the belt and is slooooooowly comes back, then the rubber has turned to licorice. If it If your belt has already stretched and it is still in one piece, when you measure it, it will be too big. I would order several belts, one 10% smaller, one 13% smaller and aonther 16% smaller, that way you should get the right one. If the belt has broken, without stretching it, **** the broken ends together and tape them butted together, then measure the belt. Its been a long time since I've done a 122', but if there are other belts in there too, order them as well. When one belt goes, there are more to follow in the very near future. I would first try contacting Teac/ Tascam to see if the correct belt is available from the factory, or possibly an entire belt kit !. If you need more instructions on belt measuring, go to : http://www.ceitron.com/passive/flatLbelt.html and follow instructions at the top of the page.
Good luck.....Rob
Posted on May 09, 2008
  • Sam Palermo
    Sam Palermo May 08, 2014
    I have used Consolidated myself many times but there is also Ken's Electronics in MI. and Marrs Communications and MCM Electronics also has some belts as well as MAT Electronics. There are no shortages of belts if you are in the business like I have been.
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
How do you hook up a Tascam 122 cassette deck to a receiver i tried to hook it up to my Nad 7155 receiver and no sound what am i doing wrong please help
cassette decks have line OUTPUTS. If it records there may be line inputs. Connect the OUTPUTS to the appropriate INPUTs on ur amp. Select the correct input on the amp. If it doesn't work u will need to verify the amp inputs work and that the tape outputs r active.
If so chg the cables.
Jun 02, 2016 | Tascam Computers & Internet
How do i hook up my tascam 122 cassette deck to my Nad 7155 reciever i tried
The RCA outputs sockets on the 122 connect to either tape 1 or tape 2 "PLAY". on the Nad.
The Line In Jacks on the 122 connect to the record of tape 1 or tape 2 rec of the Nad.
If you connect it to tape 1 connect both to that.
To listen to the deck you select either tape 1 or 2 depending which you have connected it too.
May 29, 2016 | Tascam Audio Players & Recorders
Tascam 238 recording deck won't stop rewinding.
Well which is it 122 mk III or the 238?
The grease in the 122 will harden with time and gear crack or lose teeth. The deck needs to be worked on. There is myself in Chicago,
Russ in New Jersey that are still working Teac Technicians. There is Adrian in CA but I am not sure he wants to work on cassette decks.
Jun 08, 2014 | Tascam 122MKIII Single Dual Cassette Deck
Tascam 122 mk III error code
The Tascan 122 Mk III does not have a computer in it to give error codes. I suspect that you have a power supply issue but I can only help you if I see the unit. I am in the Chicago area and run a shop for fixing these decks. I have been doing it for 40 years and have worked at the Teac Factory Service in IL.
skywavebe@sbcglobal.net if you need my help.
The symptoms are recognized as a cracked transport gear that is resolved by a new gear and a transport cleaning and new grease put in. I have done about 6 of them as this is described. I have parts in stock.
Sep 06, 2012 | Tascam 122MKIII Single Dual Cassette Deck
Need belts for tascam 102 mk2 cassette player
This is easy to take care of just contact Marrs Communications and select the
Supreme" CASSETTE KIT $19.95
http://marrscommunications.com/tascam-cassette-kits
Oct 11, 2011 | Tascam 102 MKII Single Dual Cassette Deck
Tape reel on either deck stops and tape gets jammed. This is on a Tascam dual cassette deck model 322.
Try replacing the belt, because when the belt is a bit old it looses its elasticity and it can't drive the whole thing properly.Tape A and Tape B works independently.
Jul 25, 2010 | Tascam 322 Advanced Dual Well Single...
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
733 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
