Question about Pioneer AVIC-N2 Car DVD Player
AVIC N2 parking brake bypass
How exactly do i bypass the e-brake to view movies while the car is in motion? Is it easy? Can a normal person do it? I have a 02 Yukon....could you break it down simply for me? Thanks
  • 1 more comment
  • supreem77 May 09, 2008
    Thanks! I really appreciate your feedback-however...i have no idea what you just wrote....means!
  • Anonymous May 22, 2008
    How exactly do i bypass the e-brake on a Pioneer Avic D3Y to view movies while the car is in motion? Is it easy? Can a normal person do it? I have a 04 Nissan 350Z. Could you break it down simply for me? Thanks
  • dbell40 Jul 09, 2008
    already grounded parking brake green wire, when go down the road screen get a pop up blocker saying cant view while driving
  • 3 Answers
Heres a good site that has alot of bypass guides for Pioneer Avic Units http://www.underground-secret.com/
Pioneer Avic D1, D2, D3, N1, N2, N3, N4, Z1, Z2, Z3, F700BT,F900BT & F90BT.
Posted on Sep 27, 2008
There are two ways to complete this project:
1st
underneath the mounting bracket of the radio not the brain theres a silver sticker like mentioned above there are two silver solder points right beneath the sticker it must be jumped with a wire or you can use the solder to connect the two contact points after this you must still ground the green parking brake wire to the car.
2nd-(also my favorite choice and the one I'm using on my N5 & on my 7800dvd those who know pioneer know what i'm talking about)
buy a ptr7 pheriphial device and wire as follows (they come factory ready to bypass alpine and pioneer units)
wire as follows-white wire to green parking break of the deck your bypassing
red wire to vehicles 12v source
green wire from device to remote
black wire to vehicle ground wire
final important step I know because this happended to me
make sure you take a little screwdriver agfter wiring or something and switch the
PTR 7 to the off position-or else this will make the PTR7 not function correctly
Posted on Sep 20, 2008
The wire u would use for the handbrake just put it streight to earth
Posted on Jun 21, 2008
    Problem Solver:
  • 4 Answers
I dont think these solutions will work. A simple solution follows. Under the unit, there is a silver sticker. remove sticker. there are two solder points under sticker. You need to solder a jumper between the two points. either a piece of wire, or like I did just create the jumper from the solder. I will warn you. Be careful to not over heat the area. Also, this will void your warranty.
Posted on Jul 18, 2008
Just cut the wire ging to the e brake and loop it back to the stereo
Posted on May 09, 2008
    Problem Solver:
  • 8 Answers
You can find the bypass method here:
Pioneer Avic-N2 Bypass
They also have bypass guides for Pioneer Avic D1, D2, D3, N1, N2, N3, N4, Z1, Z2, Z3, F700BT, F900BT & F90BT.
They are very knowledgeable and helped me with all of my questionspromptly! This is a rare thing in today's world and it is well worthhaving expert advice so you don't mess up your expensive unit. You willnot be disappointed! I am only one of many of there satisfiedcustomers.
Posted on Feb 17, 2009
Is there a way I can watch a DVD movie on my Pioneer AVIC-Z2 screen without having to put on my parking brake?
Yes, there is a way to watch a movie without the parking brake engaged. The parking brake safety mechanism is there for a reason, and I do not suggest that you disable this sytem so that you can watch movies while driving. With that said, the simplest way to bypass the parking brake system is to take the parking brake wire from the head unit, run a wire to a chassis ground point, and then put a toggle switch inline so that you can flip it on and off. This will simulate the engaging/disengaging of a parking brake.
Again, I do not condone or recommend watching movies while driving. There are enough distracted people driving on the roads.
May 18, 2009 | Pioneer AVIC-Z2 Car DVD Player
Avic bypass
The original Avic N1 only needed to have the parking brake wire grounded for video in motion. Then, the latter series came out and on the underside of the in-dash unit, they have a foil sticker that needed to be removed and a jumper carefully soldered on the circuit board. Avic N2's had a switch installed under this sticker to avoid people from making soldering mistakes. I think the N2 brain may be looking for an N2 unit and giving you trouble. more info on this subject is available @ www.avic411.com.
Aug 04, 2008 | Pioneer AVIC-N1 Car DVD Player
E- Brake Bypass
This forum should have what you are looking for:
http://www.avic411.com/forum/viewforum.php?f=11&sid=d2e7eb58b07df6e1abc1cd149fb69b3a
Apparently, you are not alone!
May 22, 2008 | Pioneer AVIC-D3 Car DVD Player
Bypass for N2
there are to steps, very simple...
solder two points under the silver sticker on the bottom of the head unit (pay a pro! don't mess up your deck!) then you ground the light green parking brake wire (attach it to the black ground wire coming out if the same harness) this will give you "full function". i have this unit and have the upgrade, it works.
May 08, 2008 | Pioneer AVIC-N2 Car DVD Player
Bypass NAVI
Ummm, its against the law for the driver of a motor vehicle to able to see the screen of a tv or dvd player while the vehicle is in motion! Dummy, watch the road!!!!!!!!
May 07, 2008 | Pioneer AVIC-Z2 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
N1 internal solder bypass to work with newer software, N2 solder the two connection under the silver sticker(might void warranty), N3 switch the switch under the silver sticker(might void warranty). Goodluck.
Mar 31, 2008 | Pioneer AVIC-N2 Car DVD Player
Not pioneer but kenwood indash dvd player what easy way
Run your parking brake ground throught a manual switch and switch it off before you turn off your car everytime. Goodluck.
Nov 08, 2007 | Pioneer AVIC-N2 Car DVD Player
Avic n2
You have to bypass the Parking Safety feature. Here is the info I have found. I have not verified it myself for accuracy, so use at your own risk. AVIC-N2 lockout bypass: Underneath the MAIN unit (not the hideaway) is a small silver sticker, peel this back. There are two contacts with the label "R197". Drop a bit of solder between these to connect them. Also, you must ground the Parking Brake wire.
Sep 26, 2007 | Pioneer AVIC-N2 Car DVD Player
Pioneer AVIC-N2 Car DVD Player Logo
2,600 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
