HP Pavilion TX2000Z Notebook Logo
Posted on Aug 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have power to my hp pavillion tx2000, but its not booting up, and no screen, but all the lights come on, apart from the caps lock light that stays off, i have removed the battery power and ac but still nothing happens
Hubert Thong
Level 1:
  • Contributor 31 Answers
  • Posted on Feb 15, 2014
Hubert Thong
Contributor
Level 1:
Answers
31
Questions
Helped
4067
Points
53
Dismantle the motherboard, locate the nVidia chip, cover all surrounding area with heavy duty aluminum foil. Burn the chip with a small blow torch. Just circular motions and do not linger too long. Rationale is that the chip has detached due to the heat generated and you are now trying to reconnect it to the board. Hey, the set's already dead so no harm trying it, right? Sending it back to the brand reps will cost a bomb. In my recent 3 years of "burning" this chip, I must have rescued upwards of 120 laptops of various brands with similar faults with only 4% recurrence. Have fun trying to "raise" the dead.
Anonymous
Level 2:
Sergeant:
  • Expert 238 Answers
  • Posted on Aug 31, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
238
Questions
0
Helped
43287
Points
570
  • Check your power cord & adapter.
    If its working then check the battery, reseat the battery & check.
    If available then check with another battery
    If no, then remove the battery & switch on the PC in AC mode.
    Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
    If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
    If still no display, connect an external monitor, check if display is comming.
    If Display is coming then your LCD need to replace.
  • Snoopy techo Nov 23, 2010
    Sounds mad but had the same problem - switch it on with just the battery in - then wrap it in a duvet for 45 minutes (yes i know sounds mad) then switch off (if not already over heated!) Start up again and it should start normally - i did this as warrenty no good, HP usless, and it worked i was shocked! - Good luck :)
  • Anonymous Nov 23, 2010
    What processor u r using? is it AMD, with graphics card?
    If yes, then It smees your laptop's graphic chip has gone faulty. get it replaced. hp parts are very costly, so go to a local repairing center and it will be fixed @ cheap.
The question on the hp g42 the f12 lightOrangestay's on And the cap key blinks 1 x every 3 sec.
could be faulty ram or screen faulty,or even over heating,clean out the fan.
Tx2000 hp laptop not booting up, all lights are on green except amber light from wireless button
Do you get anything on the screen at boot? When you removed the HDD did you test it? It powers up, but will not boot correct? Fan spins, LED's Blink? Battery charges? Can you get to BIOS or Boot Menu? Can you do a Restore/Recovery? If you insert a repair disk into the DVD/CD rom drive does it respond? Take a look at HP support page: http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=solveCategory&cc=us&dlc=en&jumpid=reg_r1002_usen_c-001_title_r0001&lc=en&product=3658348
Ihave hp pavillion dv7 1245dx when you power up it acts like its locked in hibernation everything is on and the cap lights blink but the screen stays dark ...
I suggest try to do a Hard Reset on your machine by removing the Battery, unplugging the Power Cord and after that Press and Hold the Power button for about one minute without any supply on the machine. After that put it all back in and see if still doing the same problem, If its still doing the same problem count the blinking lights on your caps lock it indicates what could be the hardware that's faulty on your machine then call the manufacturer's tech support and tell them that it gives you that kind of problem.
When i power my hp tx2000 it display all lights and the cap light is flashing but there is no display at the screen even it does not boot, what can i do to repair it.
mi computadora tiene un año 6 meses es una tx2627cl ; derepente comenzo a pitar y cada vez que la prendo pita y el lector de huellas digitales no reconoce y esta lenta que hago ayudenme porfa es urgente
Hp pavillion tx2000 all lights are on - hard
That's a very common issue with that model, You will have to reflow the GPU with a heatgun. You can find more info from http://www.msbin.com if needed.
My BOSS HP tx2000 will not turn on WHILE...
ok Do you hear any soun when your system try to boot?like a beep sound ?
try this remove battert remove the ac adaptor from the noatbookand press and hold the power button for 10 sec and connec the ac adapter not the battery and turn on the noatbook and at the HP logo hit the F 10 key for 2 times and you will be on bios screen hit the F9 ket and restore the setting to default and hit F10 agian to save and exit and allow it to boot it thats work try with battery connected
Regard!
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
