Question about Qca Spas Paradise Hot Tub
Self priming hot tub pump won't prime - Qca Spas Paradise Hot Tub
  • 990 Answers
If you have had the tub empty and refilled this could be an air lock and all you may need to do is open the drain valve till you get water out of it. Good luck
Posted on Aug 31, 2010
2 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: pool pump wont prime when
I assume that it pumps from/to the hot tub. If so, the pump is fine. Look for any air leaks in the piping/hoses from the connection in the pool to the inlet of the pump.
Gary
Posted on Aug 30, 2011
Hot tub stuck in PR mode.
Are the pumps primed, the code represents that the pumps are being primed and should only stay on 2 - 5 minutes. If the pumps are not primed then you may have an air lock or dirty filters. You need to release the air or clean or replace the filters and your pumps will prime.
Mar 27, 2014 | Pool & Spa
I have a Mastercraft1/2 HP self priming Shallow well jet water pump, the water fell below the intake in my well and I quickly noticed and turned off the pump. We had water delivered and I'm not su
If water is back up above the intake, it should prime itself in a few minutes. As long as you don't let the case get hot to the touch it should be okay to run dry.
If it fails to prime and pump up pressure, you may have to prime it.
Oct 20, 2012 | Plumbing
Hot tubs
Check the connections and the pump motor. There is a good chance the pump motor has pooped out
Sep 07, 2012 | Pool & Spa
Pool pump wont prime when in pool mode, but will run in hot tub mode. Hot tub is 3 ft higher than the pool... is this a bad impeller? I think it may have run for a few hours without a prime , as I...
Gary
Aug 30, 2011 | Hayward 1.5 Hp Northstar High Performance...
I have an Asralpool self priming pump ref 20601 / serial 094585V It turns on ok but does not seem to be pumping. If left on for 10/15 minutes the pump is obviously getting hot as the water in the...
Is there a place to prime the pump? Self priming doesn't necessarily mean it doesn't need help. If there is no place tp put water in the pump, consider disconnecting the suction hose and fill ith with water, hold the hose up toward the motor to get the most water in you can, then reattach it to the pool and try again.
Aug 12, 2010 | Pool & Spa
Message
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. clean machine with the Saeco scale remover thank you ,Lee Davidian
Jan 17, 2010 | Saeco Magic De Luxe Espresso Machine
My machine seems to be set on ventiate. it wil dispense hot water but that's it.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. I hope this helps , Lee Davidian
Dec 27, 2009 | Saeco Royal Digital Plus Coffee...
Flahes from FL to the temperature (13) after refiling. Temperature level will also not increase.
FL is usually a flow sensor/switch fault. If you have just filled the tub, the pump may not be properly primed. The best thing is to fill the tub through the skimmer when you first start filling it, that ensures the pump is filled with water and is not air locked. You may have to force water into the skimmer to push the air out of the line or loosen a union on the discharge side of the pump to get it primed. FL will not let heater run because it thinks that there is no flow.
Nov 18, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
How do I prime the STA-RITE DS3HF-01?
I have a sta-rite mkse-6 pump and it has lost its prime..... how do I prime it???
Feb 15, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Qca Spas Paradise Hot Tub Logo
532 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
