Question about Maytag PAV2300 Top Load Washer
My Maytag PAV2300 Top Load Washer is nine years old. It just started making this LOUD grinding noise when it's washing, rinsing and spinning. What could it be?
I have the same type washer and it is about the same age makes the same grinding noise as the above mentioned one. Did this person ever find a solution?
Posted on Oct 18, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
2001 Maytag PAV 2300 just started making loud grinding noise when it went into wash cyle and continued into rinse and spin as I moved the dial around to those cyles. It also smelled a little like hot...
http://www.partselect.com/ModelFrames.aspx?ModelID=148053&ModelNum=PAV2300AWW&mfgModelNum=&ManufactureID=1&Selected=52406&Position=7&mfg=Maytag&Type=&Mark=7
As you can see in the link, I suspect that the transmission is going or has went. The transmission and seal kit is over $300 with shipment, plus if you are not well versed on washer repair it is probably not something you would attempt yourself. So you will have another large amount for labor.
You have to ask yourself, if it is worth putting that type of investment in your unit!
Jun 09, 2011 | Maytag PAV2300 Top Load Washer
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
The motor is making a loud vibrating noise
Maytag PAV2300 top load making very loud squeeking noise when set at spin
Jul 09, 2010 | Maytag PAV2300 Top Load Washer
Noisy
Not good news...Common reason for those noises are bearings and/or gearbox problems...Sorry......Nomess
Apr 17, 2010 | Maytag PAV2300 Top Load Washer
My whirlpool top loader is making a grinding
The direct drive coupling is broken. This video will show how to replace it.
http://appliancejunk.com/forums/index.php?topic=3437.0
While you have it torn down check the drain pump for blockage too.
Dec 26, 2009 | Maytag PAV2300 Top Load Washer
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
Oct 08, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Spins but does not agitate
this unit has a berring problem the parts come in a kit not an easy doit yourselfer you also need special tools
Aug 09, 2009 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
173 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
