Question about GE Spacemaker JVM1640SJ Microwave Oven
Lights continue to burn when switch is turned off. How do you fix?
    Problem Solver:
  • 16 Answers
Bad control board
Posted on May 09, 2008
I have panasonic nn-gs597m microwave its working normal but not heating, I opened the cover magnetron is hot the fan is working. Any help?
follow the next steps , use the VOM and fix it. God bless you
Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell.
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Jun 16, 2013 | Microwave Ovens
Can't get to heat anything can't seem to set clock first Hamilton beach model hbp90d23al any suggestions
Step 1:
see this steps and diagram and fix it. God bless you
Microwave Doesn't Heat
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Feb 07, 2013 | Microwave Ovens
Neff gmbh microwave on but not heating
Step 1:
follow this steps and test and fix it. God bless you
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Step 4:
Why is the microwave not heating the food, but the turntable is hot.?
Step 1:
folloq this steps and fix it. God bless you
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Feb 06, 2013 | Microwave Ovens
Sharp micro doesn't heat
see this causes and fix it. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 02, 2012 | Sharp Microwave Ovens
Maytag microwave problem everything seemingly works but does not heat. Help
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Heating problem
Sep 27, 2012 | Microwave Ovens
My JVM1851 model is 7 years old. Everything is working (light, fan, clock, etc). But food does not cook or warm. no heat!!!
As I understand your trouble, your 7 year old microwave does not heat.
I have found the most likely reason for this trouble is a burned door safety interlock switch.
To fix this trouble, remove the cover, find the switch opposite the door hinge. Test the switch for proper operation. You will need a continuity tester or a volt/ohm meter for this.
Let me explain what happens and you will be able to apply this to your situation. When you close the door these switches tell the oven the door is closed and it is ok to turn on the magnatron. If the switches are burned, they cannot tell the oven the door is closed - door not closed, no magnatron, no magnatron, no heat.
Why do they burn? Do you open the door while the oven is in operation? If you do, there is a spark at the tiny micro switch contact and they start to burn. Eventually, they will not close properly.
You can find replacement parts at a FixYa.com advertiser or a appliance parts store in your area or at www.repairclinic.com
The next most likely problem is the start capacitor. This is the silver can inside. Please do not servic this item unless and until you understand the danger associated with it.
This device stores a very large electrical charge. Modern capacitors are supose to drain off the power after a certain amount of time. Some say it is OK to drain the opwer by shorting with a screw driver to ground. Frankly, I'm not a fan of this method. Please try the switches first ... if that doesnt work, post a note here and we can go to the next step.
I hope this solves your trouble and you are able to get your oven back in operation. If you will search this problem here at FixYa.com, you will probably find other ideas from other volunteer workers.
Thanks for using FixYa.com. Please vote
thanks
a
Nov 09, 2009 | Microwave Ovens
I have a Panasonic microwave (model NN-E566BA) that has worked great since 1996! Last night when we closed the door the fan and light continued to run. We had to unplug it. I tried again this morning and...
I think there is an error in your control ... error in that the oven still thinks it is on though you want it to be off. A switch turns it on, and should turn it off at the end of the time you select. Since it continues to run, the switch must not be opening like it should. AND - THIS PROBLEM COULD TURN OUT TO BE TRANSIENT - HERE FOR A WHILE AND THEN GONE FOR A WHILE AND THEN COME BACK AGAIN.
Is it easy to fix? Probably not - I say this because nothing is as easy as it seems at first. You can evaluate this by removing the cover and taking a look inside at what you have to do to get to the control.
If you descide to go forward with this, with the make and model in your hand, visit the appliance parts store in your area and go make friends with the counterperson.
Alternatively, you can find parts at www.repairclinic.com
For the short term, and this will not be real convenient, but will let you run the oven while you decide what to do, you could plug the oven into a power strip and use the switch on the power switch to turn power on and off.
Oct 19, 2009 | Microwave Ovens
Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
Jul 28, 2009 | Magic Chef Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
24 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
