Question about Pass & Seymour #1595NTLICC4 15A Ivory GFCI Nightlight
I bought several of these switches. Only one seems to illuminate correctly. The one that appears to be correct has the top half of the paddle lit when in the off position. The other switches all have an orange light behind the paddle; however, the light only appears around the crackes of the paddle and the paddle itself does not illuminate. Was there some change in the model or a recall? Wiring is not the issue as I have swapped switches to make sure. The lighting through the cracks is inadequate. Any suggestions are appreciated.
  • 83 Answers
Verify that there is not a piece of tape or protective layer across the light screen.
Posted on May 07, 2017
2 Suggested Answers
  • 152 Answers
SOURCE: 3-way switches do not operate properly
you can either trace them out or keep moving them around until they work... helpful website http://www.thecircuitdetective.com/3and4wyinfo.htm#terms
Posted on Dec 06, 2009
My 2005 Ford freestyle is stuck in park what do I do I've tried turning switch half way and moved shifter but still did not work tried several Times
You have problem with Shift interlock system ! http://www.autoshop101.com/forms/h18.pdf This is for a Toyota but will explain how they work !
SYMPTOM CHART Condition Possible Sources Action
  • Shift interlock system does not release/lock correctly
  • Circuitry open/shorted.
  • Fuse(s).
  • Stoplight switch.
  • Go To Pinpoint Test A .
PINPOINT TEST A: THE SHIFT INTERLOCK SYSTEM DOES NOT RELEASE/LOCK CORRECTLY Test Step Result / Action to Take A1 TEST THE BRAKE LIGHTS
  • Apply the brake pedal and view the brake lights.
  • Do the brake lights illuminate?
Yes
REFER to Section 417-01 .
No
GO to A2 . Let me know if brake lights work or not !
Mar 20, 2015 | 2005 Ford Freestyle
I have a new paddle light switch im trying to install and for some reason it keeps poping the breaker. im wondering if im installing it correctly
make sure you are hooking up the correct color wires to it main wire on top of switch, bottom wire of switch other color wire they should be blackor any other color , just dont hook up the white wire to it this will make your breaker pop , If your copper is touching any metal this will make it pop also,good luck
Jul 29, 2011 | Cooper Industries Cooper Wiring: Single...
The motor seems to be working but the crank stops turning after half an hour. I end up with a bowl of flour after 3 hours.
Hi, Either the paddle is sticking or the belts are slipping. Take the pan and paddle out of the machine and try turning the paddle by hand. It should be nice and smooth. If not the sealed bearing is failing and the pan needs to be replaced. If ok then check the belts. Belts and motor are located in the base of the machine. Unplug it first before checking. Also, make sure the pan is seated in the machine correctly. Hank
Nov 11, 2010 | Regal Ware K6725 Kitchen Pro Bread Maker
Only 1 headlight bulb lit? Just bought a used 2008 Honda CBR125R in Canada from the Honda dealer. I noticed only 1 headlight bulb lit ('passenger side' half) They said that regular headlights only one side...
That sounds right, Check the plugs on the bulbs to see for sure. The passenger side one should have three prongs and the other should only have two. Good luck
Apr 23, 2010 | 2006 Honda CBR 125 R
Refrigerator in-door water dispenser fails to work
First ... your model number is missing some on the end. please check your model number on the machine for the correct lookup of parts.
For your situation I found this model number # FRS22ZRHD1. Take a look at this picture of this models dispensor.
there are 3 switches # QT 2 -- 38a & 38b
this should be close to your model of fridge but you will half to make sure.
and yes you should just replace the bad switch.
Part numbers for the switches for this model # are 218479900 & 241689101
Jan 08, 2010 | Refrigerators
Loose paddle
Pop the top ... remove the front ... carefully remove the belt ... take the drumout - you are correct, the paddles are held onwith screws - tighten them.
reassemble
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How does the illuminated light work inside a Leviton light switch? Since there is no neutral (white) wire hooked up to the switch itself? Does the switch illumination light have its current flow into the...
The neon lamp inside of the switch draws very little current (milli, or mico amps) so there is no significant current flowing to ground.
As for your real question, there are several various types of 3-way pilot switches:
Load on: Pilot on
Load off: Pilot on
Some 3-way pilot switches have an external lead which allows them to be configured either way.
If both of your switches are the same type and are wired correctly, they should work the same.
If you suspect that one is defective, try swapping them.
Aug 03, 2009 | Electrical Supplies
Kitchen pro breadmaker K6725
After making sure paddle was in correctly, ran thru several cycles and kept hearing the click but no action ............am trashing the machine.
Nov 12, 2008 | Regal Ware K6745S Kitchen Pro Bread Maker
Pass & Seymour #1595NTLICC4 15A Ivory GFCI Nightlight Logo
53 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Ottoniel
Mike
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
