Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I m using whirlpool splash washing machine.my power panel is not working and the technician had asked to replace it.the technician says the cost is 3000rs is it so costly.please tell me the price of power panel.
  • 128 Answers
They sell parts at whirlpool type in google then type in whirlpool parts for washer
Posted on Aug 31, 2010
Machine will got start.
Warranty? Owner's manual troubleshooting section? Sounds like a bad circuit board, and time for GE technician. I'd ask them for the worst cost repair. You may want to consider a lightly used replacement.
Apr 27, 2015 | GE GFWH2400LWW Front Load Washer
My whirlpool was stuck on the Lock switch. we used he cancel button but now it wont run. the fill light come on but nothing happens. I have tried unplugging it to reset the panel, but nothing helps
Double check there is power at the outlet. If no power, check circuit breaker box. If the circuit breaker "pops" after resetting, you have a serious electrical problem in the washer or wireing to the washer. Consider the age of your washer, cost to find a lightly used working replacement, vs the cost for repair tech. Ask for an approximate repair visit cost.
Jan 20, 2015 | Whirlpool Washing Machines
Have a whirlpool AW0 R4205 washing machine. No power even after checking the plug and changing the fuse.
good day,
How long your washing machine? for the machine without power if electronic type of washing machine it will cost you a lot but defend on the model. and not to advise to buy the part without any idea what the exactly the problem,most the electronic type washing machine have a PCB problem, if you buy directly for the part but you dont have the cause why it happen,may be if you put new part will do the same or its will waste your new part.
as an advise as a technician,call the technician and ask how much its cost? for labor and part?
if the cost is halt price of the unit? what or how many month for warranty for the part and service? make think to buy for the new one if your unit is more than 5 years.
Nov 02, 2013 | Washing Machines
Whirlpool Troubleshooting
Good day,
How long your washing machine? for the machine without power if electronic type of washing machine it will cost you a lot but defend on the model. and not to advise to buy the part without any idea what the exactly the problem,most the electronic type washing machine have a PCB problem, if you buy directly for the part but you dont have any idea the cause why it happen,may be if you put new part will do the same or its will waste your new part.
Nov 02, 2013 | Whirlpool Washing Machines
Button doesn't work
first disconnect all power from the machine second disconnect the panel from the machine third take the broken panel to your nearest sears store and ask the representative for a new panel for your washing machine
May 10, 2012 | Whirlpool GHW9200L Front Load Washer
Broken door latch whirlpool ghw9100lw1
The following link explains how to replace the door latch on a Whirlpool front loader:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
This is a very simple repair. I'm surprised at the cost of the labor you were quoted. An experienced technician can replace one of these latches in 30 minutes or less.
An alternate method of the replacing the latch is the remove the top panel of the washer and work down through the top. Due to variations in design features between models, this isn't always possible. If you want to remove the top panel, just locate and remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off. If you have access the latch assembly from the top, you can attempt the repair using this method.
If you have any questions, please let me know. I hope this helps you.
Sep 02, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpoop AWM9000-WM1100 Displays fault code 11F? any ideas greatfull
F11 on a Whirlpool AWM9000:
Service manual says "Communication error between Control board and Motor control unit (MCU)".
-Check control board
-Check MCU
-Check wiring to MCU
Basically, there are two electronic boards in this machine- the one up the top that you use to operate the machine (control board), and a power board in the base of machine (MCU). F11 fault is indicated a communication error between these boards ie one of the boards may be faulty, or wiring connection between them may be faulty.
It is impossible to know which electronic board may be at fault, as there is no way of testing them. Would advise calling service technician, but would advise you use an actual Whirlpool technician rather than a local service man, as Whirlpool tech has access to technical info required to solve your problem.
Good luck !!(be wary- might pay to ask for an estimate of what repair might cost when booking service call, as some of the control boards can be expensive)
Aug 11, 2009 | Whirlpool WFW9200S Front Load Washer
Whirlpool Top-Load Washer gvw9959kq
Yes. I replaced the control panel (the panel with all the cycle buttons on it). I downloaded the technician's manual from whirlpool and went through the troubleshooting to find the problem. Th part costs around $106.00. Just make sure you order the right color.
Jul 27, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
113 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
