Question about Kenmore 53632 / 53634 Side by Side Refrigerator
Water is leaking out of filter housing does this mean its time to change the filter
    Problem Solver:
  • 15 Answers
No it's probably the o-ring seal at the housing. i would try taking it out inspecting the seal and replace if needed. if not i would put it back on and make sure the housing is on tight and it should seal off.
Posted on Aug 31, 2010
How do you change the filter to a culligan water softener
Here are instruction to remove the filter housing. This is from my tips posting. Culligan filter housings are just Pentek/Pentair water filter housings and these tips apply to virtually any filter housing.
Frequently whole house filters can be very difficult to remove. The canisters become almost impossible to loosen, even after pressing the pressure relief valve and using a housing wrench. The most common reasons for this are the housing was put back on with the housing wrench, debris in the housing threads and a bad pressure relief valve.
h2oservices.jpgl76w9ont156vs3p099e2rqu+8nt56e+fbm9ldnps+cnj57dmpqamzqoj3nqs4doe4cr7sqwf8acoamtivyaikaaaaasuvork5cyii=
How to remove a stuck filter housing.
1. Turn off the incoming water.
2. By-Pass the Softener
3. Go to the nearest cold water faucet, open it and let the water run until pressure drops significantly.
4. Turn the water off at outlet of filter (If housing has shutoff on top off head, turn this off now).
5. Press and hold the pressure relief button to relieve pressure further.
6. Use filter wrench to unscrew housing (If it still won't loosen repeat steps 2-5).
7. After removing, clean housing thoroughly, make sure threads are clean on filter bowl and housing head. Lubricate threads of housing and head with plumbers faucet lube or silicone.
8. Clean and lubricate the O-Ring (replace the O-ring every couple years or if housing leaks after screwing back on). It helps to flip the O-Ring over a couple times per year.
9. Replace the cartridge filter and screw the housing back on.
10. Turn the incoming water on slowly while holding the pressure relief button down until all air is purged.
11. Open outlet and let water run to cold water faucet until all air is purged.
12. Put softener back in service.
IMPORTANT! Only tighten the filter housing by HAND!
NEVER use the housing wrench to tighten the housing.
I hope these tips help you with the angst of removing stubborn filter housings.
RJ
Sep 29, 2011 | Culligan Sediment Water Filter
How do i change the filter in the amana my ice taste bab do i need to cut the water supply off to change the filter
Water filter is located in the upper right hand corner of the fresh food side.
Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
Sep 14, 2011 | Amana ASD 2624 Side by Side Refrigerator
Ive had my water pump changed on my merc c200 and now have a oil leak could they not have tightend it up properly
Hi clongis..
The answer is NO they could not have caused an oil leak if all they changed was the water pump.
When you torque the bolts on the water pump no matter how tight or loose it will not cause an oil leak.
Check to make sure it is an oil leak first instead of black burned oil leaking from the exaust housing.
If it is an amber color then it is drive unit oil and can come from the seals of the lower unit propeller housing, or under the water pumps stainless steel bottom plate.
Which means it is time to repair the leaky seals before they cause you to have lower unit failure...VERY EXPENSIVE.
Please take time to rate me
Aug 07, 2011 | Garden
Miele dw flashes 5 times, water is draining. Suspect filter/valve housing at end of water inlet line. Their is a wire running to this valv so I imagine whatever solenoid that tells the valve to open and...
which light is flashing? if the intake drain light is blinking and you dont hear the drain pump, it means water is not coming in. if the drain pump is running all the time, it means water has leaked into the bottom pan. behind the plastic toe kick, there is a panel that can be removed with two phillips head screws. It you can see water in there, you can dry it out, and try to run another cycle. if it runs fine, cut back on your detergent usage. if it leaks again within a cycle or two, you will need to locate the leak and repair.
Nov 18, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Water leak at rear of filter at hose connections. will old filter cause this to clog and force water out of the connection fittings at the clear plastic water lines
it sounds like the filter housing could have a crack in it, but It could potentially be a leaking line. In the event the old filter where clogged to the extreme, you'd simply have little or no water flow, not enough pressure to cause a leak though. I've seen these housings damaged by customers forcing the filters in or out in ways never intended.
To check the lines are secure/not leaking...
**FIRST unplug the unit from the wall and turn off the water supply**
either go thru the front by removing the toe panel/kick plate grill, or go thru the back panel, you'll still need to remove the grill at the front though. the 2 screws securing the filter housing to the fridge are at the front behind that grill. (if your lines are long enough -they usually aren't- you can undo the screws and pull the housing out to work on it easier/unimpeded). remove the 2 lines to the filter housing carefully(when removing these you simply push the tab surrounding the line "in" or "down" and pull out the line) and inspect them at the ends where the "seat" in the fitting/"O" ring within the housing. with a razor blade or sharp utility knife, cut off a small amount to insure a clean fitting when re-installing the lines into the housing (simply push them in the way they came out, until they bottom out and you can't pull them back out). once that's done you can turn the water back on, plug the unit in, and check for leaks. Is it actually the lines, or the housing itself ?
I've seen this a few times. the complete housing can be replaced and it isn't that difficult. First verify it is leaking behind the filter at the housing, I could try and help further. the housing is # 2186443 if you need it.
hope that helps,
good luck
Sep 28, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Can't change filter without water pouring out
Hi, If you can't shut the valve off to the water source, you will need to shut the water off to your house and change both the filter and the valve to the refrigerator.
When changing the filter, you will get a little water while removing the filter but, not very much. I hope this helps you.
Please let me know if I can assist you further.
Vic
May 30, 2009 | Whirlpool GS6NBEXRB Side by Side...
Whole house water filter , NO water coming thru
Good morning! please try to uninstall the water filter, then observe if there's water flowing on the tube, if there's water flowing then it might be the shutoff control valve that is defective which mean that we have to replace it. best regards
May 05, 2009 | Plumbing
Water filter compartment leaking
If you have already replaced the filter and you can see the housing is still leaking, You have to replace the housing and water tank as an assembly (12956202). Make sure you verify it's the filter housing leaking, and not a fitting at the water valve which is right behind the plastic cover around and below the filter housing.
Apr 28, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Feb 26, 2008 | Refrigerators
Kenmore 53632 / 53634 Side by Side Refrigerator Logo
59 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
