Question about Car Audio & Video
Just bought a used car yesterday - 2004 Chevy Trailblazer - has a CD stereo system - put a cd in - pushed the eject button & the cd wont come out - sounds like it is spinning & then display says Check CD - but it won't come out - the salesman didn't tell me there was a problem with the CD player - it was a brand new CD I put in so nothing wrong with the CD - how do I get the CD out? The system won't spit out the CD?
  • 1 more comment
  • lmcurtis15 Aug 31, 2010
    I looked it is front loading cd player - there is like a "netting material" just inside the player - but I don't see any little hole near the insert point. I will get the manual out
    Reading the manual right now - but don't see any small hole at the point of loading and dont see any screws to undo on the cover - so not sure if I am going to be able to get it out or not. Obviously as you can see - I don't know anything about cars and I don't have a man around to help with things like that.
    Front loading CD player appears to be some "netting type material just inside player - looked for small pin hole near insert area - do not see any - do not see any screws to take off cover - tried to push eject button again - sounds like CD is spinning inside then just displays Check CD message but player will not eject the CD?
  • 857 Answers
Please follow these steps:
turn off the car and removed the fuse for the radio and put it back in. Once u put it back in the cd player should work fine.
or
A: Press the reset button on both the changer and the remote. The reset button on the changer is located on the front panel of the unit, It can beactivated with the tip of a pin.
B: If the unit does not operate after resetting it, remove the magazine by inserting a business card between the magazine and the mechanism. The lock lever will disengage to allow the magazine to eject.
C: Make sure all cds are in the magazine, a CD is found lodged in the carriage, remove all cds from the magazine and reinsert the magazine into the changer.
D: Press the eject button. This should cause the loged CD to move from the carriage into the empty magazine. The magazine should automatically eject and normal operation will return.
Or
•1
Wait for your car's stereo to cool down. If you have been using it for an extended period of time, it may have gotten hot and the ejection device may not be working properly. This may be caused by a dirty or scratched CD, or a peeling CD label.
•2
Hold down (do not just press once) the eject button on the front of your car stereo's CD player. Listen for a mechanical ejection noise. If your car stereo is making this noise, it is more than likely that the CD is just sticking inside the CD player.
•3
Look for a hole the size of a pin on your car stereo's CD player. This hole is very small and looks similar to one on a CD-Rom drive. Once you have located the hole, use a pin and attempt to manually eject the CD.
•4
Remove the face plate of your car's CD player (this only works if your CD player is not factory installed) and attempt to manually remove the CD by pulling it out through the entry slot. Do not force items such as pliers into the CD player's entry slot. Wait until you see the object and gently remove it.
If this doesnot helps counsult a repair guy.
Posted on Aug 31, 2010
  • 4,924 Answers
Usually they have a emergency eject if this is a tray load device ...it has to have a little hole near the inserting point ..and when a pin like tool is inserted and a little push in ...the CD should came out ...
But if it do not have such a thing ...try to make a reset if the unit's menu is available ...or ..just open if up...and retrieve the thing manually ..Just unscrew it ..and get the cover off..you have to do it anyway if it is to repair it ..or you will have to change it if the device is proving to be defective ..
another thing t try first ..is to power it off..and restart ,,,better remove the power from the plug ..but keep in mind that some of these devices have a pin like code..and if it had a previous owner..after removing the power supply it might ask for that code..
  • Catalin Turcu
    Catalin Turcu Aug 31, 2010
    the front do not have any screws or something like that ..you have to get the unit out of its place ..and the screws will be on the bottom side..and after you get those out will have to see how the unit gets apart ...My advice is to ask someone that knows anything about and do not try yourself cause it might have snapped parts and other hings that will put you in doubt ..and I don't think you want to ruin it completely before having a chance to know if it is worthless or not..
    better ask a friend or a neighbor to help you open it and retrieve the disk ..and get ti to a repair shop when you will have the means ..or ..try a second hand stereo ...if you do not see the point in buying a new one ..(in case this one will be beyond recover..)
    I have a mechanic friend I will ask him to look at it. I do not want to break it. Thank you anyway
Can't get my cd to eject from car stereo
Did somebody put coins or something inside it? Try putting a high power vacume up to it and seal the whole opening with the vacume end...
Jun 18, 2012 | 2006 Chevrolet Malibu
My cd is stuck in player of a 2004 chevy blazer 4x4
  • You need to wait for your car's stereo to cool down. If you used it for it for an extended period of time, it may have gotten hot and the ejection device may not respond.
  • Hold down the eject button.If you can hear the mechanical ejection noise. If your car stereo is making this noise, it is more than likely that the CD is just sticking inside the CD player and you can try and grab it with your had and pull it out .
  • Look for a hole the size of a pin on your car stereo's CD player. This hole is very small and looks similar to one on a CD-Rom drive, after locating the hole, use a pin and attempt to manually eject the CD. Now in case you have a factory stereo.
    Hope this will help you out.
  • May 16, 2011 | 2004 Chevrolet TrailBlazer
    ERROR 03 WHEN PUSH CD BUTTON
    Two solution proposed on other forums:
    1. Hold 'eject' button for 10 seconds. The system should eject the cd.
    2. Slide a credit card back and forth on the cd opening. Push eject, the cd should be ejected.
    Hope it works.
    Oct 14, 2009 | 2004 Mitsubishi Endeavor
    My car radio jvc won't eject my cd? an need to kow how to?
    this is a common problem with this model radio. if it wont eject by pushing the eject button. you can do a hard reset by holdin the SEL button & the POWER button at the same time until the until ejects your disk. OR pushing the SEL button first, then the POWER and holding both until it resets.
    hope this helps
    Sep 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
    Stuck CD in the multi CD player of 2004 Chevy Malibu Maxx
    The only thing that is left for you to do is to remove the stereo and then disassemble it and remove it yourself. A little daunting but needs to be done. Sounds like it went in wrong and then became jammed
    Jun 10, 2009 | 2004 Chevrolet Malibu
    2005 chevy trailblazer cd player won't eject cd
    I have a 06 Z71 and it did the same thing so more than likely your just going to have to buy a new cd player. I would recommend going with an aftermarket cd player because you probably going to spend just as much on another stock unit.
    Jun 04, 2009 | 2005 Chevrolet Trailblazer Ext
    2004 Chevy Silverado factory Stereo, CD is stuck in player, sounds like it is trying to eject but won't!
    I searched quick and couldn't really find anything on a manual eject button. Flip through the manual a little bit and see what it has about the radio. If all else fails and you aren't worried about possibly breaking the stock cd player, some skinny needle nose pliers should reach in far enough to grip the cd and you can pull it out. But there is a good chance you could break the cd player in doing so.
    May 04, 2009 | 2004 Chevrolet Silverado 2500HD
    Cd player won't turn on
    ur vehicle needs a new stereo unit..
    Apr 02, 2009 | 2004 Honda Odyssey
    2004 chevy trailblazer
    2004 Chevy Trailblazer radio won't eject CD. Push the eject button and the thing just clicks and says "check CD" . Tried bulletin 04--8-44-020C (fuse removal and reinstall) didn't work. Any other suggestions before going to dealer?
    Sep 04, 2008 | 2004 Chevrolet TrailBlazer
    Cd ejection
    Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
    Mar 13, 2007 | JVC KD-S680 CD Player
    Car Audio & Video Logo
    93 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
