Question about Refrigerators
How to change water filter on my KitchenAid KSCS23FTMS ?
  • sleevelead Jul 23, 2008
    After replacing the water filter on a Kenmore side by side, the new filter pops out when the water dispenser is engaged.
    Tried the original (older) filter and same thing happens. Filter will not stay in when trying to run the water...
    Thoughts?
  • 172 Answers
On the left side of the water filter there is a button that releases the filter. Push in on the button then push in on the filter and pull it out. Remove the end cap on the filter and place it on the new filter. To install just push it in. Good luck and I hope this FIXYA
The part number is 4396841. It retails for $39.95
Mike Anderson
Posted on May 08, 2008
    Scholar:
  • 150 Answers
Twist counter clockwise a quarter turn and pull out
How and where do you change water filter
From the KitchenAid Manual:
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Replacing the Water Filter
To purchase a replacement water filter, model 67003523 Part
Number 4396395, contact your dealer or call 1-800-442-9991
U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. Depending on your model, see
"Water Dispenser" or "Water and Ice Dispensers."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
http://www.kitchenaid.com/digitalassets/KFCS22EVMS/Use%20and%20Care_EN.pdf
May 16, 2014 | KitchenAid KFCS22EVMS French Door Bottom...
How to change water filter on this kitchenaid superba
go here download the manual http://kitchen.manualsonline.com/search.html?q=+kitchenaid+side+by+side+refrigerator+1&
Feb 19, 2010 | KitchenAid KSCS25FKSS Side by Side...
The water dispenser stopped working but the ice dispenser still works just fine on my KitchenAid Superba KSRG25QFB side by side
First Question, Have you changed the water filter???needs to be done every 6months. dirty water filter can keep water from flowing through system......also nasty to drink.........
Jan 09, 2010 | KitchenAid Superba KSRG25FK Side by Side...
How to change water filter of Kitchenaid refrigerator ksss36fkx00
pull the bottom cover off the lower front, you will see the filter on the left lower side. can get them at walmart ...easy to change
Jul 07, 2009 | KitchenAid Refrigerators
Changed filter water leaking out of ice maker even when shut off
if u have changed the filter and it wasnt letting water though before you changed it, then some foreign material has come out of the filter and has wedged its self under the plunger of the water solenoid holding it open
Apr 28, 2009 | KitchenAid Superba KSRG25FK Side by Side...
I have a Kitchenaid Superba and when ever we turn on the ice maker. it says our filter needs to ebe changed. is that a problem? However before even when the filter was bad it still made ice. whats wrong?
Most refrigerators with filters will not work...with a bad filter...they will work initially ...for a while after the filter indicates it needs to be changed but over time the filter can become completely clogged...and no water will flow...also the impurities that were being filtered out...are now in the water and the ice and can accumulate in the ice tray...or at the spot where water is dispensed into the tray...with real hard water calcium can build up and inhibit water flow. I would definitely change the filter..... I had the same problem and the filter and the monitor for the filter are tied into the circuitry...so yes it can definitely stop the water flow.
I hope this helps....good luck...please rate me...The Fang
Mar 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
I need help
how to change the water filter
Jul 11, 2008 | KitchenAid Superba Architect KSCS25INSS...
Slime in refrigerator water line
The water quality is really bad, you should change your filter often even the big water filter from your main line, need to change it after 4 to 5 months.
May 30, 2008 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
875 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
