Question about Whirlpool LGR5644 Gas Dryer
Dryer does'nt blow hot air - Whirlpool LGR5644 Gas Dryer
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 31, 2010
5 Suggested Answers
  • 83 Answers
SOURCE: maytag dryer not blowing hot air (2yrs old)
If the vent is blocked, it will not stop the heat, it will only restrict the air flow.
Generally a couple of things can cause the heat to stop.
Either the thermostat or the element.
I would first suggest the element.
It may be fatigued therefore the internal wire within the element becomes fragile and eventually breaks down. Although it is an electrical item, it is mechanically built and can fail.
In some dryers the element is held in clips.
These clips can cut into the element.
The thermostat maintains temeperature but again, it is mechanically built and can also break down.
If you are not capable of inspecting or troubleshooting the internals of the dryer (i.e remove the cover and look for the failurer), then have it inspected by a repairman. There is not too much that can go wrong with a dryer. The most expensive part wuld be the motor that spins the drum.
Posted on Sep 17, 2008
  • 52 Answers
SOURCE: dryer does not blow hot air
If this is an electric dryer, it could be the heating coil is broken or burnt through, you may have a restriction of built up lint in the vent hose, or one leg of the 220 volt breaker tripped. Please rate my solution.
Posted on Apr 21, 2009
SOURCE: Dryer blowing cold air only
older homes with fuses can have to fuses on the dryer circut-1 could blow and the dryer would run without heat
Posted on Jun 20, 2009
aasc
  • 1606 Answers
SOURCE: dryer working but not blowing hot air
Either bad thermal cutoff or bad element .( first 3 numbers missing on model #)
Posted on Jul 06, 2009
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
I have a hdd error when I try to record on my jvc
that is a dew sensor message /mean warm up your cam room temp press eject and get an air dryer
and blow hot air inside for a few seconds ,do not set the dryer at high level /medium or low to avoid damage to the plastic or inside it if that does nt work
you got to replace the sensor in the camera.....
Feb 25, 2010 | JVC GZ-MG175 HDD Camcorder
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Dryer working but not blowing hot air
Jul 05, 2009 | Kenmore 800 6983 Electric Dryer
Dryer gets too hot
if it gets too hot with new limit you might need to take dryer to neighbors yard and blow out all lint from whole unit from the lint filter, blower, indide and exhaust hose and also check the flapper where the air goes outside
and blowing out the lint from an old dryer with an air compressor makes a BIG MESS
good luck
Jul 03, 2009 | Dryers
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Wont blow hot air
heating element failure 30 bucks and an hour of labor
Jan 14, 2009 | Dryers
Air flow and heating problem inside dryer.
???? this doesnt make much sense, can see how you would be measuring air flow within the cabinet??? air blowing out unit strong means your gettin good air flow fom within, that is a direct relation as to the amount of (hot) air being pulled across the clothing
Jan 14, 2009 | Whirlpool LER4634J Electric Dryer
My dryer is ot blowing hot air
Remove the heater vent, then turn dryer on. Does this fix problem? If so then you have a block in your vent hose.
Dec 31, 2008 | Kenmore 75962 Gas Dryer
Wont blow hot air
check that you have 240 volts to the dryer terminal block
if so check the element and the element thermastats
May 07, 2008 | Estate EED4300SQ Dryer
Whirlpool LGR5644 Gas Dryer Logo
63 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
