Question about Mitsubishi WS-55511 55" Rear Projection Television
When truning on tv it just trun itself back off
  • ray wilkins Sep 01, 2010
    2 blinks then 2 blinks on my mitsubish ws55511 from raywilkinsauto@hotmail.com thanks for your help
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
When it turns off and green power light goes off:
On front of set press and hold both the Menu and Input buttons for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
I know these sets very well, post a comment here.
If this told you something you did not know rate this solution as very helpful as I do this for free.
SD TECH
Posted on Aug 31, 2010
  • 3 more comments
    it has 2 blinks ,2 blinks for codes on my ws-55511 mitsubishi tv
  • Kalgwl2 Sep 06, 2010
    I'm getting 2 light blinks.
    Can you tell me what they mean or what I should replace ?
    Greg
    Kalgwl@bellsouth.net
  • leeannwynn Sep 17, 2010
    my code flashed a 2,2 on my model wt46807
  • SD Tech
    SD Tech Sep 17, 2010
    2,2 is short protection 98% that one of the two pico fuses that protect the convergence circuit is bad.
    This model uses a single convergence IC (about 15 dollar part on Ebay and the same seller sells the fuses 5 for 3 dollars.
    I will attach photo of the IC and fuses (circled in black) All parts are on middle circuit board.
    This can be a do it yourself repair and I have start to finish, step by step instructions for this in your set.
    The instructions are free and I can send them to you.
    Look at the photos----the information in the instructions tells you everything you will need and how to get the board out, replace the fuse and IC and put it back together---it does involve soldering as fuses and the IC are soldered in.
    If you want the instructions to read and see if you or someone you know can do it, let me know.
    If this helped rate this solution as very helpful as I do this here for free.
    SD TECH
  • EdAdelman Dec 23, 2010
    I just had the same thing happen on my wt46807. Did you ever get this fixed?
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: truned it off left home and came back sometime lat...
The most common problem is the deflection board. You can get the Deflection board PSB-260 from www.tvrepairworld.com the replacement board comes with a CD with instructions for the board removal and replacement
Posted on May 21, 2010
Ive changed the crankshaft sensor coilpacks an when I trun the key it wont start so I took plug wire off plug an truned the key an it only sparks one time on my 2005 honda santFE
you really need to step back and start over with the basics and move on from there...
timing belt
fuel pressure
things like that
Oct 30, 2014 | Cars & Trucks
I have a mitsubishi ws-65313 projection tv i was waching it and went black now its not working the green light is on but tv isnt working and i try to turn it off and the ligth still on i push the botton...
Hi. i believe this to be either of these three problems.
1. Power: it could be that there is a problem with the power electronic element(s). the solution is to go see an engineer.
2. Screen: if the television uses LCD display, it could be a problem with the liquid in it. Solution is to see an engineer.
3. Sleep mode: the TV could be in sleep mode which makes the screen go blank until removed from sleep mode. Solution is to read the TV's users manual to see how to wake a sleeping TV. Get back.
Jul 15, 2011 | Mitsubishi Televison & Video
My laptop trun on for a sec but then it load for a sec and trun off and the fan working it just keep truning off it does not stay on to gmake it to the menu it trun off while it loads help
sounds like its had a knock and one of the heat sinks on the CPU or graphics chip is loose and overheating. It needs to shut of so as not to damage the CPU/graphics chip.
Jul 05, 2010 | Computers & Internet
Truned it off left home and came back sometime later and it would not trun on
May 19, 2010 | RCA HD52W59 HDTV Projection Television
How can i stop my razor from truning off by itself?
Try to check the battery first. check and see if the battery depletes fast, if not try inserting a different battery on your phone to check if battery is the problem. If the same problem hapenning on the phone.. try to do a master reset on it. master reset will erase some of u\your save info on the phone. And if problem still persist you might want to have your phone checked and have it repaired if necessary.
Sep 04, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Fs 45 stihl
you could try cleaning the back of the head out as it may be jamming onto the shaft.
Jul 18, 2009 | Garden
Sony kv32v26 video flashes off/on/off/on/off/on/ audio is good
you have a bad crt if you open the set on the flyback you see 2button 1screen 1focus
you see the screen trun it up just a littet
you see it will stop but because if you trun it to far it will shut down. and you have line thur it .
just trun it a littet bet. hear what you are doing is trune up the screen livies up. but your crt is going bad. sorry to say that to you .
Jun 02, 2009 | Emerson EWF2004 20" TV
Sound but no pic
You need to take this television in for service for component failure. You can contact PROSCAN customer support at this website. www.oncorpus.com. Go to the customer support section and ask them where you can take you television for service. You can also call the customer support at this telephone number. 1-888-977-6722. I hope this information helps with your problems.
Mar 31, 2009 | Proscan 32LA30Q Television
Cinego projector trun off it self
it is cooling. leave it alone. the projector need to do this
Oct 22, 2007 | Radio Shack Cinego D-1000 Multimedia...
Mitsubishi WS-55511 55" Rear Projection Television Logo
424 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
