Question about Cameras
I have a problem with the Panasonic AJ-D200. The tape will not close. The symptom developed after I loaded a head cleaning cassette. I then loaded a normal tape and now it won't close. I then changed this tape drive for a spare drive. Powered up the camera and tried again. I loaded a head cleaning cassette. Then loaded a normal cassette and now this one won't close. The problem seems to be with this head cleaning cassette but I cannot risk using another spare tape deck. I cannot see the latch that would be affect the closing mechanism. Does anyone have a diagram or a solution?
    Problem Solver:
  • 9 Answers
I came across this very problem on two Panasonic AJ-D200 and the problem seems to be a bit of plastic mould on some cleaning cassettes, As the cleaner is inserted it bends a piece of the cassette holding cage release mechanism which is made from aluminium so all you have to do is bend it back in to place that is if you are lucky and it hasen't broken off.
Posted on Sep 18, 2013
  • 3,083 Answers
I've always pulled my hair out over problems like this. I think you're right, the cleaning cassette is bad, but problems like this can be tricky. It's going to be hard to find a diagram or service manual, but you might get lucky. I would take it into a camera repair shop, and just see if they would explain the reason the deck won't load, or if they've ever seen this problem before. It might give you enough of a clue to be able to fix it yourself, or they might help for a reasonable fee.
Here is an answer from another tech on FixYa:
usually this occurs when the door latch release mechanism is broken. This mechanism is located on the basket where you push the tape in and it's job is to open the tape "door" on the cassette that you insert. Unfortunately, the only fix for this is to replace the cassette basket.
Guess that might be the solution, to do what you've been doing, but skip that cleaning tape and buy a different kind, or clean the unit by hand.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Aug 31, 2010
How to fix sony camcorder with tape deck that won't close. camcorder squeals and ejects tape.
bit late...but. STOP ASAP! by removing the battery, after removing battery, wait 20 seconds, re-fit battery & CLOSE the cassette door.
then wait 10 seconds, slap the closed door twice quite firmly. then open, if it opens, discard that cassette tape, clean the players head using cleaning tape.
use new cassette tape.
Jun 30, 2015 | Sony Video Cameras
Playback flickering
The most common cause of this is dust, debris or contamination on the heads.
Firstly, it's extremely important that you use only DRY LUBRICANT type DV tapes on the Canon branded camcorders.
Different manufacturers design their heads to be used with either Dry or Wet (coating lubricant type) tapes - NEVER BOTH. Canon is DRY type.
Consumers are led to believe that they should be using well known branded DV tapes, such as Sony. This is fine, if your camcorder is a Sony. However, you should NEVER use Sony tapes in your Canon - Sony tapes are of the WET type.
So, the question is, "Are you currently using Dry or Wet type tapes, or a mixture of both?" If you have used either a WET tape, or a mixture of both in your Canon, then this may have contaminated your heads.
If this is so, then don't panic - simply run a special Head Cleaning cassette (for Dry tapes) in your Canon for no more than 5 secs. Note: your heads are very delicate, so only run the cleaning tapes for a few secs at a time.
Also, try to avoid recording over the cassette too many times, as the quality will sometimes degrade each time.
An example of the Dry tapes are the Panasonic ones (Myself and other Pro Videographers often use Panasonic Prof, Studio or Master Quality tapes, as these are some of the better quality Dry tapes on the market).
As your XL2 is a Pro Camcorder, I recommend you stick with Studio quality (or higher) cassettes.
See this link for Dry DV tapes: http://cgi.ebay.com/Panasonic-mini-DV-digital-video-cassette-AY-DVM63SQ-5pk-/170645949017?pt=US_Camcorder_Tapes_Discs&hash=item27bb4a8a59
or
http://cgi.ebay.com/5-Panasonic-Master-HDV-HD-video-tape-HC9-Mini-DV-/220519311691?pt=US_Camcorder_Tapes_Discs&hash=item3357f9a94b
See this link for Head Cleaner cassette: http://cgi.ebay.com/MiniDV-mini-DV-Panasonic-Head-Cleaner-Cleaning-Tape-/220683036059?pt=US_Camcorder_Tapes_Discs&hash=item3361bbe59b
If the problem still exists after head cleaning, then suspect either a faulty cassette (most likely) or damaged heads requiring service.
Let me know how you get on...
Scott
"If this has helped you, please be kind enough to leave a testimonial"
Jul 09, 2011 | Canon XL2 Mini DV Digital Camcorder
I am trying to use a Panasonic AJ-D650, which hasn't been used for about 5 years. Initially the DVCpro tapes wouldn't load but they are now loading correctly. However if I press play or any other command...
most likely problem with the AJ-D650 is deteriorated electrolytic capacitors on the mechanism drive board. when these caps fail, the mechanism will not load completely, if at all. also check for bad capacitors in the signal path from the head drum. first and easiest step is to clean the heads; often a good cleaning will restore operation to a non-playing machine.
Oct 22, 2009 | Panasonic Televison & Video
Aj-d200 video camera, cassette door stuck partially open. best diagnosis and/or remedy?
Partially open sounds like a mechanical problem with the cassette housing/door assembly. The door usually stays fully open or will not open at all, caused by component failure on the mechanical driver board. Check to make sure nothing is stuck in the mechanism, like a label or a broken piece from a cassette. If the door will move, but will not latch closed, the problem is most likely on th emechanical driver board.
Mar 25, 2009 | Panasonic AJ-D200 Camcorder
AJ-D250 PANASONIC E-62 PROBLEM
E-62 error on AJ-D250 points to a cassette housing problem. either replace the cassette housing or have it rebuilt (replace gears on the sides that raise and lower the cassette). "replace belts" won't work - the AJ-D250 doesn't have any belts.
Oct 14, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
No sound or vision playback of dv tape
From my poin of view cyliner (rotary head) have poor conection or this parts will be replace.
Aug 06, 2007 | Panasonic NV-GS11B Mini DV Digital...
Tape keeps ejecting - panasonic nvfj620
Is it only the Head cleaning cassette which keeps getting ejected, or is it happening with every tape you insert? Was the Head Cleaning Tape a little tight in the Cassette compartment? Did you have to put some pressure to push it in or did it come out with difficulty? From your symptoms, it looks like there is a gear timing problem with the cassette loading compartment gears. It could also be due to some obstruction inside. try shaking the VCR, and if you are hearing some noise, Open cover and check for foreign objects.
Apr 25, 2007 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Lines in replay
Digital video camcorder are recording signals in very thin line (as thin as 1/8 of a hair.) Therefore, following symptoms may appear if video heads become dirty even a little. If such symptoms appear, clean the video heads with a commercially available dry cleaning cassette. If the symptoms reappear shortly after cleaning, the video cassette may be defective. Stop using the cassette. Video heads may become dirty under the following conditions: (1) When using the camcorder in humid or hot places. (2) When using cassette with damaged or dirty tape. (3) When using the camcorder in dusty places. (4) When using the video heads without cleaning them for a long time. Note: Before you make important recording, clean the video heads and make a test recording first. We also recommend cleaning the video heads after use before storing the camcorder.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Dirty Replay
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
