Question about Sony DSR-30 Mini DV VCR
Sony dsr-30 when i load a tape it locks up none of the functions work and it won't eject
  • 7 Answers
Did you check if the timer is set?
if so, clear it or switch it off.
Posted on Sep 01, 2010
Mini DV Tapes Won't Play
Please give the model and the make
Apr 16, 2008 | Sony DSR-11 DV / Mini DV VCR
I have a Sony PDX-10 and it's giving me two blinking yellow symbols (underlinded triangle and tape with line through it) when I fire it up loaded with a tape. Tried changing with tapes that work fine in...
Looking at PDX 10 User Manual Page 232
Your description -
Under lined Triangle
Cassette Ejection needed
Slow Flashing: The Write protect tab exposed
Fast Flashing: Moisture Condensation
Cassette out of tape
Self diagnosis display function activated
Sounds like the diagnosis function maybe your best shot......
Check displayed error codes in viewfinder on Page 231 of the User Manual or let me know if you dont have copy of them.
Tape Symbol Flashing:
Tape near end
No cassette inserted
The write protect tab exposed.
I think this is basically telling you the loading mechanism has a problem, the viewfinder is displaying an error code indicating the nature of the fault..... IF error Code is : E61:........ or E62........ (dots indicate extra numbers) these MUST be referred to Sony Service Centre.
Hope this may help
Ian 561
Jun 24, 2010 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
The DSR11 will allow a tape to be loaded then it turns off. The tape loads and ejects OK but keeps powering off Any ideas?
since the tape loads, that rules out the cassette housing; the problem may be a defective reel motor, defective gear, defective tape sensor, etc.
Aug 03, 2009 | Sony DSR-11 DV / Mini DV VCR
Sony DSR 45P error code C3125
Press the power butten several times while holding down the eject button. It will solve your problem and clear the error. If it not then there is something wrong with your reel motor or the circuitery which deals the reel motor. You must consult your nearby sony service center.
Rajab Ali
Mar 08, 2009 | Sony DSR-45P DV / Mini DV VCR
Sony DSR-45 will not eject tape nor play,ff,rewind shows error
The generic error codes C32:xx indicate that a motor is not functioning. If you have not worked on these machines before, extreme caution is advised. These have extremely sensitive alignments that can easily be disturbed.
Please update this with your familiarity with these machines and I'll try to provide additional directions.
Thanks,
Dan
Nov 21, 2008 | Sony DSR-45 Mini DV VCR
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Sony DSR-45 Error Code C3140
C:31:40 is "FG fault when starting drum." In plain terms, the video head assembly is not producing a feedback signal that tells the control circuitry that the heads are spinning. Most probable cause is a bad drum assembly, but check to make sure the flex cable going to the drum is properly seated.
Oct 17, 2007 | Sony DSR-45 Mini DV VCR
DSR-1800 Lost Lock
This error 07.042 means Detected the abnormal capstan speed.here what u have to do go to maintanence menu.and check the capstan speed
Sep 28, 2007 | Sony DSR-1800 DV/Mini DV VCR
Sony DSR-11 Will Not Recognize Timecode
I think you may have misconfigured something because the problem is not in your DSR-11 try connecting it to a monitor and you will see the time stamp and picture as proof of what I am saying. The problem I think is that your Mac is not processing the time stamp correctly. Try this link first it helped me: Remember follow the instructions ezactly: http://forums.creativecow.net/readpost/35/856108
Sep 11, 2007 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-30 Mini DV VCR Logo
93 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
