Question about Memorex MLT3221 32 in. LCD TV
No image. Only sound. - Memorex MLT3221 32 in. LCD TV
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Aug 31, 2010
I want sound configuration off jumpers
you can setup the sound jumper setting in the help of this image here is the image for your sound configuration.
Thank you for using Fixya.
Regards
Manish
Jun 11, 2010 | Asrock P4VM8 Motherboard
TRV22E
Please provide the model and the make
Apr 09, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
All of a sudden I have no sound on my Inspiron 1525..I have been having problems with this model since I bought it. I would like to try to reset it to the factory settings but don't remember how. ("factory...
check if computer is mute, check in sound properties if speaker headphones is selected, check if sound device is detected in device manager. try uninstall reinstall sound driver. to perform factory image, press F8 up to 10 times during the DELL LOGO, select repair your computer, select language then click next, click Dell Factory image Restore.
Feb 23, 2010 | Dell Inspiron 1525 Notebook
I have managed to put a lock on my memory card in my camera... (it is on protection mode and dont know how to get it off as i want to delete all the pictures on the card. I have the old pentex optio wpi...
If your pictures are on the SD card in your camera, many of the sd cards have a small micro switch on one edge that will lock your card... you may want to pull it out of the camera and make sure that the physical lock isn't set..
Dec 02, 2009 | Cameras
Need a small sound board for my Samsung TV
If the sound is distorted, then you need to replace Sound board. If you do not have picture and sound, it has nothing to do with sound board.
There might be millions of reason and depends on the make and model of the TV.
On most of the samsung TV's, such problem might be due to defective Circuit Board. It can be replaced or repaired.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Samsung Remote Control
No image and sound on the rca hdtv 50' power button flashing
sounds like a fly back problem
have a qulifyed tech check this out its high voltage leaking you are hearing.
esp if its a sqweek hiss sound.
Jan 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No image
sounds like the power supply has gone down poss. one of the electrolytic capacitors. common problem if the lampunit does not work
Dec 13, 2017 | Toshiba TheaterWide 52HM94 52" Rear...
EasyCap usb adapter sending images only from vcr. No sound.
while i preview mode there is no sound only image. when you record then playback sound is there.
Sep 16, 2008 | Ulead Videostudio 8 for PC
DSC P51
There is a seperate microphone to do that. Usually when the CCD imager is bad it cause a white screen to appear or the colors are distorted in the view finder.
I would take it into a camera shop and see what they say unless the battery hasn't been replaced recently.
Jun 27, 2008 | Sony Cyber-Shot DSC-P51 Digital Camera
Sony tv with no image
When i turn the tv on there's no image and the red light blinks twice each time, but no sound or image or any sign of anything.
Please help me with this problem, my tv is a sony kv-25 with more than 10 years of age.
Mar 16, 2008 | Sony KP-46S25 TV
Memorex MLT3221 32 in. LCD TV Logo
51 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
