Question about Bushnell NorthStar 78-8846 (675 x 114mm) Telescope
I recently bought this telescope from a friend. The lens is dirty and the motor has gone bad, is the telescope junk?
  • 3,186 Answers
Yes, first--- NEVER buy a TASCO or BUSHNELL telescope. Most of them are not suitable for Astronomy.
The cost of fixing this scope will exceed its value and is not economical to do.
Instead buy a Dobsonian mounted reflector like this one.
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=08942
and read this web site:
http://www.texasastro.org/telescope.php
and read my TIPS on my profile page.
Posted on Aug 31, 2010
Where can i buy a replacement 10mm lens for celestron 31035 astromaster 76EQ telescope
There are various qualities of 10 mm, some fearsomely expensive. In the USA try here
http://www.optcorp.com/manufacturer/orion?cat=14
May 28, 2014 | Celestron 31035-astromaster 76eq - Kit
How do I remove the black paper disk like thing on the telescope lens?
That BLACK PAPER is there to cause the trap of light and dust and etc from the MIRROR and is held in place usally with adjustable locking screws to balance the reflective properties of the lens.
Feb 28, 2014 | Optics
Just bought a Bushnell telescope 78-4501 - set it up as per the instructions. I can see objects light etc... through the object finder or view finder but I see nothing through the telescope not even...
This is not a real telescope, it is a toy. You will be lucky to see anything with the 20mm lens only. the rest are junk. The telescope needs to be collimated (see your manual) and the finder aligned with the telescope. Align the finder with the scope during the day, although this model was known for poor mounting on the finderscope and will become un-aligned easily.
Oct 17, 2010 | Bushnell Optics
Looking at the moon with the 50 or 100 magnification on my Vivitar Telescope all I see is a extremely small white dot. I have tried focusing back and forth very slowly to no avail. What is the problem and...
Well first thing is you bought a junk telescope. Vivitar, Bushnell, Tasco are all considered toy telescopes.
Sorry-- but it is the truth. Read my TIPS on my profile page. These scopes are NOT suitable for Astronomy. You would have been better buying a pair of 10x50mm binoculars which are almost the same lens size as this scope.
Put the eyepiece with the LOWEST number written on it into the scope. This is your highest magnification. Try the moon again with this eyepiece.
Read this:
Aug 24, 2010 | Vivitar (1607225) Telescope
Bought the scope about 4 years ago. Fairly light use and not used in last 12 months. Was checking it recently and replaced batteries etc. Horizontal motor movement is fine however no vertical motor...
Do a RESET on the hand controller. Re-enter Time, Date, and SITE, and CALIBRATE motors.
Also sometimes a bad hand controller cable will cause this. You can buy another cable directly from Meade. Call them here:
http://www.meade.com/support/index.html
Aug 16, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
IT POWERS UP FINE BUT IT DOESNT SEEM TO BE READING THE CD'S I PUT IN EVEN ONES IT HAS READ IN THE PAST.
the lens cud be dirty or damaged or the cd spindle motor has gone bad. in case of dirty lens try using lens cleaner cd. that dont work means probably spindle motor is out.
Mar 12, 2010 | Nu Mark Numark Cdn36 Dual CD Player CD...
Tasco telescope[46-114500]cannot see anything through lens.bought
THE protective cover is the FRONT of the telescope!!!
The focuser is on the front like the picture above. TURN the scope around -- you have it pointing at the ground right now!
Read my TIPS on my profile page. And read this and look at the pictures:
Jan 15, 2010 | Tasco Galaxsee® 46-114500 (500 x 114mm)...
National Geographic NG70CA Telescope .... help with
Your small telescope will never get beyond about 100 power --- the maximum resolution is calculated as 50 times aperture under perfect conditions!
Use the eyepieces with the LARGEST numbers only and don't use the barlow.
Dec 23, 2008 | National Geographic NG70CA (225 x 70mm)...
Nikon D70, error "F..."
The most basic reason for getting the FEE message is that you're using a older series of lens that has an aperture ring on it (meaning you could manually change f-stops on the lens), regardless on most current Nikon cameras that ring needs to be set to f/22 or whatever the smallest aperture (largest number) the lens has.  Give that a try and if that doesn't do the trick it could just be dirty contacts either on the lens or inside the camera.  They can be cleaned with alcohol or contact cleaner and a q-tip.  Worst case scenario, you're lens has some internal problems.  I suspect that one of the first scenarios is most likely.
Hope this helps!
T
May 22, 2008 | Nikon D70s Digital Camera
I am looking to by a telescope that needs a lens in it
You may want to try a site that sell's used astronomy equipment. www.astromart.com
Gary
Dec 02, 2007 | Meade Infinity 114EQ-DH Telescope
Open Questions:
Bushnell NorthStar 78-8846 (675 x 114mm) Telescope Logo
193 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
