Question about Vacuums
How to clean the iron it has scorch marks on the bottom. It has a self cleaning button
  • 17,130 Answers
To remove the scorch marks the self cleaner might not work so well as doing a manual job. So get a good degreasing spray and use it to wipe off the marks. Do not scratch or use any hard wipes to strach the iron but only to achieve with cleaning.
Posted on Aug 31, 2010
How to remove scorch marks
Try Magic Eraser, otherwise sandpaper it lightly and paint a thin coat of laquer back on.
Jul 14, 2014 | Vacuums
How to clean base of iron only 6 months old
If it has a non-stick sole plate: 1. heat 1 tablespoon each of vinegar and salt to boiling and then let cool - you want the salt to dissolve. 2. Use a nylon scrubbie that won't scratch and remove deposits/scorch areas with the solution. 3. If your iron is non-stick, it is supposed to be self cleaning. Happy Ironing.
Jul 25, 2011 | Vacuums
I have burned my nylon trousers with the iron, its left a terrible black burn fabric mark on my iron, how can i clean the iron?
Get some XXXX steel wool. That's the finest grade. Rub from TIP TO HEEL until the junk is off. DON'T rub sideways, the iron will snag when you use it. After you clean the soleplate, wipe it well and run a steam cycle to remove the dust from the ports.
May 13, 2011 | Vacuums
How do I clean my iron?
I am assuming that you have scale or lime build up on your iron. Make a solution of half white vinegar and half distilled water. Pour it in the water container on your iron. Turn your iron on its highest setting and set for steam. Wait about 15 minutes and turn off the iron. When water cools pour off the remaining water/vinegar solution. Fill the iron with distilled water and turn on. Let it heat and then cool then pour off that solution. Do this till the poured off water runs clear. If you have scale on the bottom of the iron you can clean that with an old toothbrush dipped into warm white vinegar. There may be easier ways to do this but this is eco friendly and it works the best of anything I have tried.
Apr 08, 2011 | Vacuums
We have a new pink steamglide iron Model No18160. The sole has a stain which I cannot clean. The instructions recommend using vinagar which I tried and which did not help. Can you help advice?
There are many products on the market which can be used to clean stubborn stains from the iron sole.
However, for realy stubborn problems I would use very fine sandpaper with a grit of aproximately 1200.
With a fair amount of rubbing or sanding it should be possible to remove any stain or mark from the bottom of the iron & provided you use a very fine sandpaper it wont leave any scratches.
Best wishes,
Graeme.
Mar 22, 2011 | Vacuums
Steam holes on the plate are letting out limescale onto clothes, is there a way to clean out iron
Yes you fill the Iron with White Vinegar (the acidic Vinegar dissolves the lime deposits), and then flush with hot water, then clean the bottom with CLR (Calcium Lime and Rust remover) brand cleaner from any hardware store. This also is how deposits are cleaned out of a Coffee pot.
Jan 12, 2011 | Vacuums
Theres water pouring out of my t fal iron's little holes when I begin to iron my shirt...why!
The iron needs to be cleaned as I have just discovered myself. I have a hinari and the instructions are as follows. Fill the water tank and turn the iron on to medium. When heated press the steam button and hold it over the sink or a container so that the water can run out of it. It will take sediments with it. The cleaning of the iron should be carried out once a month.
I experienced the same trouble and carried out the instructions and all is well again.
Jun 28, 2010 | Vacuums
Black marks on carpet
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=706295
posted by carpetburner on Jun 25, 2008
While I was walking on the carpet, I noticed a couple of black marks. I figured it was on someone shoes. I was vacuum a couple of days later and stated noticing small black marks on the right side of the brush marks left in the carpet by the brushes. I tried to clean them and they don't come out. They are sort of like a scorched pinched place or something. I had the handyman take it apart and he found nothing stuck in it, belt was replaced not to long ago, and he said everything looked fine. The black marks are not on the belt side. Maybe a wheel is sticking? It all seems to roll, and turn ok.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. After reading your question, there are only a few things that could be causing the problem. It is very possible that the brushroll could be dirty, or install wrong, on the ends of the brushroll the gray bearing holders will state NEW and OLD and both of the bearing holders needs to be identical – meaning the 2 should say NEW / NEW or OLD / OLD, not new / old of which could be causing the problem. The average belt change should be done every 4 to 6 months for the best cleaning, and the extra belts are stored in a Ziploc bag in the refrigerator. If the wheels are spinning properly then it is not the wheels unless they are dirty and the can be cleaned just by popping them out of the bottom plate holder with a screwdriver and then clean them under the sink. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 25, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
147 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
