Question about Sony KP-51WS500 51" Rear Projection Television
What's a 'crt'??
Hi! you answered a question on the website that sounds like my problem....i bought the tv from my boss; it has always had the 'arced green lines' when a darker colored screen is on (i've never had a big screen tv, so i thought it was normal :) ....ANYWAY, now it will stay on for a little while, then a green flash, and a total green screen, then the whole thing will turn off....i can turn it back on after a little while, but it will do it all over again after a period of time....please help!
corinna
  • Sony Master
  • 8,617 Answers
A CRT is the Cathode Ray Tube (CRT) or picture tube. That model has been known for the green tube shorting. Its not too hard to replace a CRT if its done safely and correctly but they are kind of pricey to purchase. let me know if you need any further assistance.
Posted on May 09, 2008
Boss hoss trike Shaft drive oil
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Boss Hoss but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Boss Hoss Cycles Product Specifications
Boss Hoss Cycles
http://antakesuma.xyz/fds/b/boss-hoss-bhc-3-ls2-2008-custom-cruiser-v8-automatic-repair-manual.pdf
https://www.bosshoss.com/parts.asp
Boss Hoss Cycles Contact Us
Apr 16, 2014 | Boss Hoss BHC 355 Motorcycles
When I turn the tv on, it sounds like static electricity coming from the back.
Check its final anode connection for arcing. You have to replace the final anode rubber boot, if arcing is here. Seek tech support. This is a dangerous work, for an un-experienced one.
Jun 22, 2012 | JVC Televison & Video
My rca model f36669 makes a popping sound and cuts off and back on
That's hi voltage arcing. Dangerous condition were a component has broken down and is arcing causing the power supply to 'crowbar' or go into over current protection mode. Call a TV repair pro for an estimate to see if you want to keep the set.
Apr 26, 2010 | RCA F36669 36" TV
My TV was snapping or arcing then no picture at
Sorry to hear this. What has happened is that CRT coolant has leaked from one or more CRT's down onto the Main bd and or the Power Supply bds and shorted them. You must replaced ALL three CRT's and the shorted Main bd and or the Power Supply boards. Then a Full Convergence Alignment must be done by a very good and experienced tech. Not cheap.
Apr 04, 2010 | Samsung PCL545R 54" Rear Projection...
Super Boss FM HI-FI Wireless Headphone SF878 no sound from the tv
Hi - the tv sound will be picked up like an fm radio signal at 83 mhz. To get there, press the reset button the side of the headphones, then press scan. the first signal to be picked up will be the tv signal. This assumes, of course that you have fresh batteries in the transmitter and headphones, and that the volume is turned up on the headphones and the TV. Worked for me. The signal is not stereo, though.
Dec 30, 2009 | Televison & Video
Hi my name is matt, i took the the back cover off and saw that there is an arc of electricty thats constant and makes a popping sound at the back of the picture tube, also noticed a spark on the main board...
hi ,matt
pls don' t open TV back cover it your self becose inside the back cover very High Voltage [more then 29 KV] EHT is working and she is wery dengures in tv on condition
your tv problum is EHT or CRT base so pls check and replace this spear with qualify technicean.
i think CRT Base in focus pin is sperked and pictur on screen is out of focus .Replace CRT Base with NEW . it 's not Expanciv spear.
Oct 30, 2009 | Zenith C36V23 36" TV
Hitachi 51F510
The loud "pop" sounds like high voltage arcing coming from one of the CRT's.....you may have to pull each CRT out and put silicon sealant on the anode connectors to prevent the arcing.(one of the CRT's may be arcing internally also and the only cure is to replace that CRT) If you let the arcing continue,it will short out the horizontal output transistor sooner or later.......
Mar 28, 2008 | Hitachi 51F510 51" Rear Projection...
Arcing between pins on CRT
Hi.
Your problem is due to moisture in the the Crt base socket you will need to replace the white plastic crt plug I have tried to clean & dry them out but it never fully corrects problem.
As far as the pins & glass crt neck goes clean them with Isopropyl alcohol this will thoroughly clean all the carbon off.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Panasonic CT-32HXC14 32" TV
TV - only single, linear image with sound
vertical line on the screen is due to problem in horizontal deflection coil circuit
plz check
  • connector loose which is going to deflection coil mounted on crt.
  • loose contact or print break from flyback to def.coil.
  • capacitor defective going to deflection circuit.
  • if you are not tech person call tech. to fix it
  • it is not a major problem & can be fixed at your home.
  • hope this will help.
  • good luck.
Oct 17, 2007 | Televison & Video
Arcing around neck board
sounds like bad crt if you saw arc inside glass...no economical fix-replace the monitor
May 30, 2007 | Likom ViewMate LP995 (White) 19 in.CRT...
Sony KP-51WS500 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
