Question about Goodman GPC1342H21A Air Conditioner
Can anyone tell me the total freon capacity of an Inner City self contained unit PAMA 024G1. The tag says the factory charge is 2 lbs 15 oz. Is that the total charge?
  • 857 Answers
Yes that is the total charge as mentioned on the product.
Posted on Aug 31, 2010
How much freon does a 2002 Chevy Tahoe take with a 4.8 v8.The system has already been evacuated and is ready to be recharged.
Should have a sticker on the radiator core support that shows how much it takes . But if your's is missing here
Refrigerant System Capacities
Application
Specification
Metric
English
PAG Oil GM P/N 12378526 for United States
PAG Oil GM P/N 88900060 for Canada
Accumulator Replacement
-ml*
- oz*
* Add 60 ml (2 oz.) of PAG oil, plus the equal amount of oil drained from the accumulator.
Compressor Replacement
60 ml
2 oz
Condenser Replacement
30 ml
1 oz
The Delphi replacement compressor is precharged without PAG oil.
The Denso replacement compressor is precharged with 237 ml (8.0 oz) of PAG oil.
Evaporator Replacement
90 ml
3 oz
Evaporator, Rear Replacement
90 ml
3 oz
If more than the specified amount of PAG oil was drained from a component, add the equal amount of oil drained.
Total System PAG Oil Capacity
240 ml
8 oz
Total System PAG Oil Capacity with Rear A/C
330 ml
11 oz
R-134a
Refrigerant Charge
0.8 kg
1.8 lb
Refrigerant Charge Utility with Front and Rear A/C
1.2 kg
2.7 lb
Refrigerant Charge Suburban with Front and Rear A/C
1.4 kg
3.0 lb
Mar 15, 2017 | 2002 Chevrolet Tahoe
With a typical line set, how much R-22 should a ckl30-1 2.5 ton a/c need?
the refrigeranterant charge is stamped on the unit data plate in ounces of freon. take this number and multiply it by 16 and get the pounds and the decimal point will need to be converted back to ounces. example 138 ounces equals 8.625 lbs of freon which is about 8 lbs and 8 0r 9 ounces. this is for a 15 foot lineset. measure your lineset and substract 15 , then take this number and add .6 per foot. .6 ounces of freon per foot of refrigerant line over 15 feet. you will have to use a quality digital scale to weigh in this total charge
May 23, 2014 | Goodman CKL30AR30 Air Conditioner
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
How many bottles of refrigerant a volvo s80 takes?
That's a REAL GOOD question! The factory refrigerant charge specifications for your vehicle is 2.20 Lbs. of R-134A. Freon R-134A comes in 12 oz, 14 oz, 16 oz, 19 oz, and 22 oz cans (as well as 30 Lb Cylinders) - it depends on which brand/size can you are buying, whether your system is COMPLETLY out of freon, or whether it still has some freon in it.
The best way to deal with the situation (in my opinion) if you are going to try and charge you own A/C system is to purchase a kit that comes with a gauge. A company called interdynamics has a real good kit available that comes with a reusable gauge. Once you have the gauge, all you have to purchase in the future is the freon itself. By using the gauge, you can more accurately charge your system without the worry of possibly overcharging. (Overcharging can cause extremely high pressures that can do serious damage to your vehicle or cause personal injury.)
Anyway, this kit is available at O'Reilly's as well as other auto parts retailers. Here is a direct link to see the kit at O'reill'ys web site.
There is also a whole bunch of instructional videos on how to charge your system at the interdynamics web site. CLICK HERE
Jun 16, 2011 | 2004 Volvo S80
Does anyone know how many cans of freeon it takes to charge the air conditioner
It depends on what size cans of freon you are getting and if the system has been retrofitted for R-134A refrigerant (1992 came originally equipped with an R-12 system). The factory specifications call for 1.8 Lbs. of R-12. If it has been retrofitted for R-134A, the general "rule-of-thumb" is 85% of the R-12 specification is needed to charge the system with R-134A. So if we do the math: 1.8 Lbs (R-12) X .85 (R-134A) = 1.53 Lbs. R-134A needed for a full recharge (providing the system is COMPLETELY empty. Then you will have to find out how much is in each can that you plan to buy and do the math to figure out how many cans you need. (some have 12 oz., some have 14 oz., some have 16 oz., some have 19 oz. and some have 22 oz.)
Jun 16, 2011 | 1992 Honda Accord
Freon capacity for gmc suburbun
3.8 Lbs of R-134 , if the vehicle has rear air, that 3 12 oz cans and an a 6 oz can of 134 with oil for lubrication of system
Jul 27, 2010 | 1999 GMC Suburban
What freeon goes in 2000 grand prix?
It is safe to say that 134 a freon is for this vehicle,and it is ready to charge,no retor fits are needed,If this was helpful,please rate,thank you.
Jul 21, 2010 | 2000 Pontiac Grand Prix
How much freon does a 1982 911 a/c system take?
All non-factory a/c's in 911's will be satisfied with 28 oz. of R12. The factory a/c with a front Condenser and a double row rear Condenser will hold 39-42 oz. With only a rear Condenser it should take 34oz. The Important thing hear is not to put in any more freon that it takes to clear the Sight Glass on the Receiver/Drier. This MUST be checked with the deck lid CLOSED and the engine running at 2000 RPM for a minute minimum. Putting in more Freon than is necessary will do no good and only serve to make higher head pressure, more heat and damage your parts.
Also below is a link to all of the info on your ac in your 911.
http://www.pelicanparts.com/techarticles/mult_AC_faq/Mult_AC_faq-1.htm
Mar 24, 2010 | 1982 Porsche 911
Saniserve 707a margarita machine
The best thing to do would be to recover the 404a into a clean recovery jug,weighing how much you take out. Check the nameplate on back it will tell total ref charge. in either oz or lbs. then weigh the charge back into the unit. this is the best wayto verify if you have a proper charge.If the unit is low on charge then you will want to find and repair the leak as soon as possible.
Jul 13, 2008 | SaniServ 401 20 Quart Ice Cream Maker
Goodman GPC1342H21A Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
