Question about Dryers
Dryer won't start. If you turn the start know to the right, there is a humming noise so it sounds like the motor is getting current, but the dryer drum never starts to turn. Dryer is an electric Kenmore model number 417.82052101.
    Genius:
  • 1,075 Answers
The main belt is broken or has come off,back needs to come of and belt replaced.new belt must be put in warm water to loosen it up ,quite hard to get it back on but can be done and will save you a cal out fee.adrian,,,,,,,,,,
Posted on Aug 31, 2010
  • 91 Answers
SOURCE: kenmore dryer hums but will not rotate
PRETTY OBVIOUS REPL/ MOTOR
Posted on Jan 03, 2009
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer hums/heats up, but drum does not spin!
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Yank out the tub. Clean the junk out (send me the coinery) oil the wheels and Idler with temp resistant zoomoil from ace hardware. Use this guide to replace dat belt Kimosabe:
BELT CONFIG 101
Posted on Apr 08, 2009
  • 58 Answers
SOURCE: Motor draws current, won't turn drum.
The motor has failed & needs to be replaced
Posted on May 05, 2009
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Indesit G74V dryer won't spin
Some dryers have a belt tension idler and switch combination that works to keep the belt under tension and shuts down the dryer if the belt breaks or falls off.
Apr 28, 2017 | Dryers
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
GE electric dryer not working
It sounds like your motor is failing.You went to turn it on and it hummed... The motor got hot and triggered the safety shut off. When it cools you may be able to get it to hum again. But you will need to replace the motor.
Let me know if I can help you further.
Apr 15, 2010 | GE DWSR405EBWW Electric Dryer
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
Hums when turned on-won't turn over
belt may have broke. if you are hearing a humming sound . thats the motor .whitch is good, sounds like the belt broke or slipped off.
Sep 12, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer stopped running
Hi, I can determine a motor bad by the noise. Does it hum while holding the start button or is it a grinding deep sound? It can sound like the motor starts slow but once it gets going, it is ok. Sometimes the house lights will dim when the motor statrs going bad.
Vic
Jul 02, 2009 | Dryers
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Dryer won't start
sounds like the start windings in the motor have failed you will need a new motor to repair this.
Jan 22, 2009 | Dryers
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
Dryers Logo
57 people viewed this question
Top Dryers Experts
