Question about Cadet Manufacturing American Standard 2366.100 Cadet Pressure Assisted Flush Toilet
Tank serial # looks like this? S 00 K 4520 13 Trying to Identify tank brand, have a K on the bowl
    Scholar:
  • 122 Answers
That is a Kohler model 4520<br /> the other numbers are for manufacturer codes.<br /> <br /> is this an older toilet? Kohler discontinued that model.<br /> <br /> <a rel='nofollow' href="http://www.designtool.kohler.com/us/detail.jsp?item=9654702">http://www.designtool.kohler.com/us/detail.jsp?item=9654702</a>
Posted on Aug 31, 2010
Where do you find the serial number of a echo PB403T
Model and serial number are underneath the recoil starter, on the engine block. Tip the blow on it's non-engine side and look right above the tank from underneath the blower.
Nov 04, 2013 | Echo Pb-403T Leaf Blowers
My Homelite d3300 DX series runs great for a while then quits some say its a stopped up but it looks clean some say air filter it is clean do you have any solutions I mixed gas ratio 40:1
Hal:
Check the fuel filter at the end of the fuel line in the tank... sometimes it will get hung up in the tank and won't be immersed in the gas. also check to see if there is enough fuel line in the tank to ensure that the fuel filter stays immersed in the fuel in the tank.
Jan 02, 2013 | Garden
Where is the model serial number on the Canon MX882
Issue: Where is the serial number located?
Solution: Locate the serial number MX882
Locate the Serial Number The serial number of the MX882 is located inside the printer, as shown below.
  1. With the printer powered on, open the Paper Output Tray (A).
    The above illustration shows a PIXMA MX870.
  2. Lift the Scanning Unit (Cover) (B) and fix it with the Scanning Unit Support (C).
  3. Wait until the print head carriage moves to the ink tank replacement position.
  4. To the right of the print head carriage, inside the printer, is a white sticker that is attached to a metal plate. The serial number is located on the white sticker. Please see the illustration below.
    The serial number starts with four letters and ends with five numbers, for example: ABCD01234.
May 09, 2011 | Canon Office Equipment & Supplies
Is my water heater still under warranty leaking water on top of heater and out from bottom and from plate
1) If water heater is leaking, I suggest you protect yourself first.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
2) You have to do some work to find out if tank is under warranty.
-Contact manufacturer: http://waterheatertimer.org/Water-heater-manufacturers.html
-Contact installer: If plumber installed heater, then installer backs warranty for some manufacturers. If you installed heater, then warranty is less or void
-Look at paperwork and manual that came with water heater and read about warranty coverage
-Look at markings on tank to see if tank is 6 year, 15 year etc
-Warranty is based on date of manufacture: To find date of water heater, look at serial number located on label on side of tank:
Open link below for serial number decoder by manufacturer.
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
3) If tank is older than 6 years, and tank label shows this is a 6-year tank, then tank is no longer under warranty.
If you have a lifetime tank, then warranty is in effect, so contact manufacturer.
Open following link to see troubleshoot checklist for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Other things to consider:
-If tank rusted out after a few years and installer did not install a jumper wire between hot and cold pipes, then tank warranty will probably not cover tank.
-If tank rusted out and you have water softener, and did not inspect anode rod or maintain water heater, then you did not read manual or maintain heater, and warranty might not cover problem.
-I suggest you read water heater manual cover to cover so water heater will not start leaking.
Other useful links:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Feb 12, 2011 | Reliance Water Heaters
When was this model built?
You posted under water heaters.
Following information is for tank-type water heaters both gas and electric.
Look at label on side of tank.
You will see type and rating of water heater.
You can also see brand and serial number.
Serial number has date of manufacture, but each brand is different.
Open following chart to determine age of your specific water heater:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 08, 2011 | Water Heaters
What years were the Rheem 81v40d produced?
You can find age of water heater from serial number located on label on side of tank.
Label also shows tank size, and tank wattage and element wattage
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Serial number decoder:
For example Rheem serial number 0790...
First 2 digits are month 07 July
Next two digits are year 1990
Rheem site does not show 81v40d
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Dec 26, 2010 | Rheem 65 GAL ELEC Water Heater 6YR Self...
Can't locate serial number
get a mirror and look behind the toilet by the rim, under the tank and inside the tank above the water line
Aug 03, 2009 | Cadet Manufacturing American Standard...
Ford focus 1800 lx 2001 lpg
You will need to look on the tag on the tank its near the service valve should be riveted to service valve/ fuel gauge cover.the tag/plate will have retest date,model,serial number and important to you is whats known as water capacity,WC .what ever the water capacity figure is minus about12 litres and that is the lpg capacity.You could run it very close to empty and see how much it takes to fill it up.
Oct 10, 2008 | 2001 Ford Focus
Is my watch authentic?
no need for serial number- look on the dial, if the 'x' marking the ten o'clock has 'cartier' written on it, your watch should most definately be authentic.
Jun 13, 2008 | Cartier Tank Francaise W51001Q3 Wrist...
Cadet Manufacturing American Standard 2366.100 Cadet Pressure Assisted Flush Toilet Logo
165 people viewed this question
Top Cadet Manufacturing Home Experts
Donni Steen
Tom Chichester
Are you a Cadet Manufacturing Home Expert? Answer questions, earn points and help others
