Question about Maytag 24 in. MDB6657 Built-in Dishwasher
My dishes are not getting clean and there is a film all over everything.
  • 5,081 Answers
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Posted on Aug 31, 2010
Fixed problem after viewing 93 code but now dishes have brown film or white film. Dishes still dried on food. Have a Samsung DMT800RHS. One suggestion was to get phosphorus which is ******* for deterg
look at the arm that has the water nozzles on it to see if some of them are plugged. Also make sure the screen at the bottom of the machine isn't restricted.
Nov 06, 2014 | Samsung DMT800RHS Dishwasher
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
After running a full cycle the dishes have a film left on them. Sometimes soap is not rinsred off the dishes. Tried different soaps for dish washers. It seems the only thing to take the film off of the...
Film on dishes post cycle is caused by 2 things.... Poor water flow during the wash / rinse cycle.... i.e clogged sump inlets or restricted drains. Clean the drain hose first. Start at the cink connection and clean EVERY connection and in-line componenet from the port hole at the sink connection all the way back to the drain hise connection port at the dishwasher.
If you still have dirty dishes post cycle after drain cleaning... then remove the lower wash arm support and clean the accumulator / sump area thoroughly. See this link: (items 1 and 4) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140844&diagram_id=28222738#d28222738
Test again.
If the problem persists you will have to gain access to the pump impeller. Inspect the impeller, and pump housing for damage. UNDER the dishwasher. Item 22 of the above link.
This should get your diswasher performing properly again.
I used this model number as a reference: GU2400XTPB1
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
When my dishwasher is finished running and drying there is a filmy residue on my dishes, and it's not cleaning like it did before. I'm doing everything the same way, it just started doing this. Please...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 02, 2011 | Kenmore 24 in. 15079 Built-in Dishwasher
Our whirlpool dishwasher, gu3200 is leaving food residue on the dishes. We have taken it apart, cleaned everything, rinsed it with vinegar and the arms are rotating...yes the problem still persists. Any...
heatman101
Jan 22, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Detergent is left in dispensers and dishes are not clean.
make sure you are getting hot water to D/W might also try different soap
Oct 26, 2009 | Dishwashers
Greasy Film on dishes
You need to use something with citric acid in it like a can of frozen OJ or tang, the citric acid helps break up deposits. (run without any dishes in it) Hope it helps.
Mar 18, 2009 | Frigidaire Dishwashers
Film on dishes and inside dishwasher
Hi debstone
This is a common problem. what you should do first is pick up some GLISTEN and run it through on a full wash with NO dishes. the use electasol POWDER detergent and turn your jet dry down to 1. that should fix your problem. hope this helped
brent
Aug 01, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Black film on dishes
Dishwasher magic. Sold anywhere appliances are sold.
May 29, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Jenn-Air (Maytag) Dishwasher Leaves Film on Everything
Make sure you are using rinse aid like jet dry. All newwer dishwasher are made to only work properly with this in it.
Apr 23, 2008 | Jenn-Air 24 in. JDB1080AWS Built-in...
Maytag 24 in. MDB6657 Built-in Dishwasher Logo
126 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
