Question about Olympus Camedia C-765 Digital Camera
Camera will not read memory cards, tried 3 different cards and several batteries. Always same error goes to card setup but will not format card and cards were all previously set up.
  • gbray29 Sep 03, 2010
    The Olympus uses an XD picture card that does not have a lock so this suggestion will not work for this camera.
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 31, 2010
My Canon says Memory Card error even with a new Memory card..what to do?
Some older cameras will only accept certain size memory cards and types. Some faster new memory cards may not work with your canera - check your manual
May 21, 2014 | Canon PowerShot SX120 IS Digital Camera
Hi - I am getting an error message when i switch on my Sony Cybershot dsc t9 saying access and then it flashes format error C13.01 - can you advise how to resolve?
It might be due to a bad contact of the placed memorycard.
1. Pull the memorycard out and in the camera several times and retry.
2. If not OK, format the card in the camera. If that does not work, format it in the computer.
3. Try another memorycard and recheck.
Sep 04, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
Camera won't read memory cards I have tried several different memory cards, the camera display reads "no memory card"
There are several possible causes for memory card errors. Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, and the switch internal to the camera. Troubleshooting tips for this problem may be found at this link.
Jan 20, 2010 | Canon PowerShot A560 Digital Camera
Was OK, but now memory card requires formatting? Kodak Easy Share C-530. I tried several times to put in new memory card, but it always says it needs reformatting and when i try "continue" it then goes to:...
She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
Jul 21, 2009 | Kodak EasyShare C315 Digital Camera
I have tried 3 different Sd cards in my Norcent x125 DCS-760 camera. All 3 times I received a ''card error'' message. What can I do to fix this???
May i ask, have you formated these cards before putting them into your camera?
If not then the first step is to format your SD card through the camera menu. (Read your camera manual to see how to format your memory card). If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
Hope this helps,
Karlos
Jul 04, 2009 | Cameras
When i turn the camera on....it saids memory card requires formatting. then continues to say formatting will delete everything on memory card. i press continue and nothing happens. goes back to say memory...
Use a computer with memory card reader, and read the card using a computer.
If the computer says the same and does not read the card, then the pictures inside the card are usually lost.
If computer instead does read the card, then transfer all picture on computer using the memory card reader, and format the card using complete formatting.
If you need to use the camera tonight, then buy a spare memory card.
If the camera returns same error on different card, then you may have a faulty memory card slot, but that is quite uncommon.
Regards
Jun 18, 2009 | Kodak EasyShare C875 Digital Camera
Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
May 20, 2009 | Canon PowerShot A470 Digital Camera
Format Memory Card Error
The problem with the c350 is that it does not accept a memory card higher than 1GB! I found that out through the Kodak website and not in the User's Guide!
Mar 13, 2008 | Kodak EasyShare C315 Digital Camera
Memory card error
The card error may be caused by several problems:
1. some minor electrical problem - turn the camera off, remove battery, wait several minutes, put back battery and turn camera on, see if it works. Proceed to next step to clean card contacts just in case.
2. Card not contacting with camera slot very well - remove card, put it on table with gold contacts facing up, use a cotton tipped stick with some ethyl alcohol (not alcohol drinks!) or isopropyl alcohol (many cleaning solutions like magnetic head cleaners) to thoroughly clean each contact. Avoid spilling and leaving drops on the card. Dry the card well before inserting it again. Never use water or other cleaning solutions or you'll ruin your card.
3. Card became defective: try card on another camera and/or card reader (many laptops have a SD card reader built in). If not working, discard card and sorry for your loss. If card works somehow, download everything useful and try to format it to see if it's working OK. Try to fill it up with some files and copy them back too some temp folder just to see if it's writeable and readable.
!!! In case the card seems to work, but your pictures are not there (card is empty or contains garbage) you can try to use TestDisk (http://www.cgsecurity.org/wiki/TestDisk) - it's the best picture undelete program and it's free. Of course you should try to recover your data BEFORE testing the card with formatting, writing etc.
!!! Always format your card in the camera after tinkering with it on a computer! Camera format is not the same as format from the PC.
I hope you retrieve your data.
Jan 12, 2008 | Canon PowerShot A710 IS Digital Camera
Card read error
Make sure it's a Sandisc, Toshiba, or Panasonic memory card. No bigger than 2 MB unless you have done a firmware upgrade. Try formatting memory card and if that doesn't work then you will have to get a different memory card.
Nov 27, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Olympus Camedia C-765 Digital Camera Logo
66 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
