Question about Hitachi 53UDX10B 53" Rear Projection Television
On our set (approx. 9 years old) - the Magic Focus screen keeps appearing - any idea why?
  • 905 Answers
Likely it is appearing because one of the picture tubes (there are 3, red, blue, green) has a focusing voltage that is disproportionate from the others, and is drifting.
I would think that your power supply is beginning to fail, or one of you tubes is beginning to fail.
Posted on Aug 31, 2010
I have a red X on screen of my Hitachi 57f510 HD tv. What does that mean?
It may have to do with the Magic focus if that model has it: auto convergence and if fails a indication can appear on screen. The Magic focus if in play would be a flashing sequence moving to different areas of the screen in sequence.
Dec 09, 2012 | Hitachi 57F510 57" Rear Projection...
Tv will not magic focus, there are two curved sections of blue and green and words are out of focus
55vg825 MODEL DOES NOT HAVE MAGIC FOCUS.
that is a DLP 2005 model.
I am going to make a guess---by the way it is a good idea here to post the actual model number in your description as this saves time and gets you more responses--
If set has magic focus and convergence will not move or is skewed--one or both of the two convergence Ic's this set uses is bad.
Normal life is 5-8 years--a grease to transfer heat from the chips dries out and one overheats and fails.
Most of the Hitachi sets use either 2 STK-392-110 OR 2 STK-392-150 CHIPS---they are the same but the 150 lasts longer.
BOTH chips will need to be replaced if this is the case and any protect resistors around them that are bad also replaced (most of the time just the chips and or 1 resistor need to be replaced.)
Once this is done the set will not have this problem again for 5-8 years.
Depending on your actual model number I may be able to give you general instructions and tell you what you will need if you do the repair yourself.
Keep in mind: usual cost for parts for this repair is about 25 dollars---I can tell you the best place to buy the chips---if you do it yourself there are sites that sell "kits" but for the most part they are much more expensive and most of the parts are not needed.
If you cannot do it shops get 300-400 for this kind of repair---and many will not do it in your home--any good tech can do in home in about 1 hour---I have done hundreds of them 200-250 depending on the set.
Let me know the model number and if you have any questions or need advice reply to this posting here.
SD TECH
Oct 26, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Half of the screen is clear and left side of the screen is blury
Its a Common Problem with Projection Tv's ~ If your flash focus is not correcting the problem, And It can Not be Adjusted in your service menu: under Manual Convergence, your IC chips and maybe a few resistoirs may have failed and need to be replaced!... onegeo
Jul 07, 2009 | Sony KP-46WT500 46" Rear Projection...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Magic focus won'f fix misalignment
YOU NEED CONVERGENCE REPAIRED EST AROUND 300.00 CALL TERRYSTV IF IN N. CALIF
Mar 28, 2009 | Hitachi 43F300 43" Rear Projection...
Convergence hitacho 61swx10b
To enter digital convergence adjustment
mode without removing the front speaker
grill, please do the following:
1) Press “Magic Focus” button on the front
panel.
2) While “Magic Focus” is running, press
Magic Focus button again to “Stop”.
3) Press “RECALL” or “STATUS” button after
“STOP” OSD appears on the screen to
enter digital convergence mode.
4) Proceed with convergence adjustment
and save the data.
5) Do MAGICS FOCUS sensor initialization.
6) To exit, press POWER button on the front
panel.
7) Normal and through 1080i modes are
stored separately. Each one has it’s own
memory setting.
Aug 11, 2008 | Philips 60P8342 60" Rear Projection...
Setting up Wii with TV
I'm 60 plus years old. Do I connect the AV cables to my TV or to my SAT receiver.
Jun 18, 2008 | Nintendo Wii Console
Hitachi 53uwx10b Convergence
You must have the original remote to do complete convergence adjustments. Remote method: Press MAGIC FOCUS button on front panel to start the magic focus. When magic focus is running, press MAGIC FOCUS again. STOP should appear onscreen. Immediately press RECALL or STATUS on the remote (must be pressed before STOP vanishes). The set is now in DCAM (Digital Convergence Adjustment Mode). Manual method: Remove the front grill and access panel or reach around from the back and press the little pushbutton located in the front left corner of the PC board, next to the Digital Convergence Module.
Once in DCAM, the remote buttons STATUS selects green, 0 selects red and ANT selects blue. 2,4,5 and 6 move the cursor and the thumbstick makes the corrections.Make all necessary corrections and then press PIP MODE. The words ROM WRITE? appear onscreen. Press PIP MODE again to store settings. When green dots appear, press MUTE to return to convergence pattern. Press PIP MODE (ROM WRITE? appears again) and then press PIP CH. This will Initialize the internal sensor data positions. When INIT finishes, press POWER on the TV and convergence is complete.
Mar 26, 2008 | Televison & Video
Blurred picture
try the focus adjustment knob on the back of the flyback transformer....if that does not work...order a focus block
Feb 03, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Yellow residual image/smear
I think it is time to buy a new set but if you want to invest some money in it then take it to a qualified tech as these projection sets are a bit complicated.your problem is a convergence the projection lens needs to be adjusted lens.good luck and bleeeing from belize
Mar 20, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
23 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
