Question about Refrigerators
I have purchase a W10184871 dispenser control board as a factory authorized substitution for part number 2252051 (Whirlpool refig mode GS^SHEXNT00). The original part had three electical connectors, the new "factory authorized subsititue" has only two connectors. How is this to be installed?
4 Suggested Answers
hiltonjug
  • 612 Answers
SOURCE: ribbon connector came off at the control board
You should be able to reconnect the ribbon. There should be a plastic piece that you push back away from where it connects. Re-insert the ribbon and then push the plastic piece into the connection. This plastic piece holds the connection tight. If it will not stay in after trying this, replace the ribbon. You can get one at www.partselect.com for $9.30 + shipping. Good luck
Posted on Dec 15, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Is there a work around
I have a feeling that the temperature control board is not the problem. The fresh food compartment has two thermistors that relay information to motherboard through your control panel. If thermistor is bad or covered by an item it will continue to cool and freeze fresh food. Your air damper between freezer and fresh food compartment may also be wide open. Click Here=> Service Manual Tech Sheet Click Here=> Tech Sheet If you need additional assistance please let me know here or HERE, Thanks, Sea Breeze
Posted on Dec 21, 2010
imufo2
  • 3773 Answers
SOURCE: ice maker wouldn'tmake and drop
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 10, 2011
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
How do I factory reset a Sharp Aquos LC32D44U?
You must have its remote control to make it to factory reset. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
If you have the remote control, just enter its service mode; surf through and select the 'Factory Reset' option, and press OK.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sorry to say that nothing more can be done without its remote control, other than contact the authorized service center for help.
Aug 01, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have a whirlpool ref/freezer the ice dispenser won't work. makes ice and water dispenser is ok. sv
Your model appears to be quite simple electrically. It does not have a major circuit board it's very possible that the pressure switch, wire connection at the dispenser, hinge or the interlock freezer lightswitch is bad on your model. Do you have a multi-meter/OHM meter? John T. Appliance 911 Appliance 911 Sea Breeze
Here is a manual that is very close to your model http://appliance911seabreeze.com/KSBS20QEWH0%20_ED20DFXEB00_Serviice_Manual.pdf
May 09, 2014 | Whirlpool EL02CCXP 19" Cold Pals Compact...
Whirlpool refrigerator ice dispenser no longer workds
HI, the Ice maker control module will need to be replaced in your unit asap if possible. this module controls and initiates the actions when the lever is depressed.
Jun 05, 2009 | Whirlpool GS6SHAXLS Side by Side...
Water Dispensor Quit Working
if you have water on the floor may be is the line if not water valve
Mar 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Ice Magic Plus not make ice at all.
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out(beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Jan 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold GS6NBEXRL01
hi .thanks for the question . the defrost cycle is probably on. either that or a faulty thermostat. thanks the appliance doc rate me please
Sep 10, 2008 | Whirlpool GD2SHGX Refrigerator
Whirlpool GS6SHAXLB03
IF YOU REQUIRE A MOTOR CHANGE FOR THE ICE DISPENSER AS A WHIRLPOOL AGENT IN SOUTH AFRICA TO MY KNOWLEDGE THE MOTOR SITS BEHIND THE IS HOPPER.REMOVER THE HOPPER AND IT WILL BE VISIBLE.GOODLUCK.MOHAMED
Sep 10, 2008 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Aug 10, 2007 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
