Question about John Deere Garden
What are the valve settings on a jd 14se 4.5 ohv engine
  • 583 Answers
SOURCE: SETTING VALVE TIMING ON 4 STROKE OHV MOTOR
I dont understand what mr fixit is talking about ,I thought you wanted to know about valve timeing.either i`m nuts or he has beenstanding too close to the moonshine still.I will answer what I think you are asking.You cannot alter THE VALVETIMINGon these single cylinder ohv motors .If you have had it stripped you will have noticed an arrow and a dot on the crankshaft and camshaft respectivly ,if yuo put these to each other the valve timeing is set ,what you need to know next is the tappet clearances ..what I need to know to tell you that is the model of the engine gx160???let me know and i`ll finish it off
Posted on Aug 29, 2009
Testimonial: "THANKS VALVE CLEARANCE SETTING WITH TDC AND ALL THAT JAZZ"
Richie_asg1
  • 1036 Answers
SOURCE: JD LX173, Kohler Command OHV Engine keeps droping mounting bolt
Use a thread locking compound on the bolts - and torque them to the correct spec.
This will prevent them shaking out.
Posted on Sep 08, 2009
  • 640 Answers
SOURCE: ohv motor, has compression but
If there is a simple fix for your problem, it lies in checking valve lash. Any other problem means going into the engine to find. I hope this is helpful for you.
Posted on Aug 19, 2011
kel1guy2002
  • 3740 Answers
SOURCE: What is the valve setting for 2004 18.5 HP briggs
31C700 engine? (model number)
This is pretty generac for all of their engines as a general rule 0.004 - 0.006
From the service manual for the 31C700 engine:
ADJUST VALVES
1. Set No. 1 cylinder at 1/4" (6.4mm) past TDC, compression
stroke.
a. Adjust valves and check, Fig. 17.
Valve Clearance (cold) IN and EX .005" (0.13 mm)
b. Torque adjusting screws and jam nuts to 60 in. lbs.
(7.0 Nm).
2. Set No. 2 cylinder at TDC, compression stroke.
a. Repeat for No. 2 cylinder.
Thanks for choosing FixYa,
Kelly
Posted on Aug 24, 2011
BAMOUT
  • 2478 Answers
SOURCE: need valve settings for 13.5hp ohv vanguard
Your owner's manual tells you
Posted on Apr 20, 2013
What is the valve setting for 2004 18.5 HP briggs & stration intek ohv engine?
ADJUST VALVES
stroke.
(7.0 Nm).
Kelly
Aug 24, 2011 | Craftsman Garden
I have a Craftsman mower powered by a Briggs and Stratton 775 platinum professional series with OHV. A couple of weeks after using my mower, I started it up and I heard a knocking sound I shut it off...
There is the possibility that the valves need adjusting. As you probably know, if they are too far out of adjustment, starting will be difficult and there will be "runnability" issues. The Briggs OHV engines all have adjustable overhead valves. Just remove the little cover stamped OHV, careful with the thin gasket behind it and get a feeler gauge, possibly a Torx head driver and box wrench to do the job. Some of the set screws for the rocker arms have slotted heads maybe. The Briggs site has the instructions for this and ALL the specs on all their engines pertaining to valve clearance on intake and exhaust. Many of their OHV engines also incorporate a compression release feature which correct valve adjustment is critical for it's correct operation. If you need more help or links to the Briggs help (under FAQ), then post back.
Most Briggs OHV engines are set at 1/4" past TDC on the power stroke. Many adjust them at TDC (with both valves closed), but for the sake of the compression release (works off the cam), Briggs specifies 1/4" below TDC on Power Stroke.
Jun 05, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Briggs straton ohv on tiller , govener will not work, runs at high speed all the time, starter rope has become extremely hard to pull, will not spin engine.
The hard to pull, will not spin the engine issue could be because you need a valve adjustment. A valve adjustment is critical because it enables the built-in compression release on the Briggs OHV engine to function correctly and enable an easy start; plus of course, smoother running. Remove the valve cover and adjust those valves at 1/4" down past TDC on the power stroke. You WILL see a difference in the engine once you do the adjustment.. Here is a Briggs spec chart which has those values for their engines. Yours should be listed in the OHV engine section.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
Here is the Briggs recommended tutorial on HOW to adjust those valves. Scroll down this page to "Adjusting Overhead Valves"
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Servicing%20the%20valves/
May 22, 2011 | Garden
Can i put a ohc in my exploere or do i have to stay with the ohv what is the dif
You would have to change engine, OHC-over head cam is the cam sets on top of the cylinder head, OHV-over head valve the cam sets in the center of the engine using pushrods to open/close the valves.
Feb 20, 2011 | 1998 Ford Explorer
I need a picture of the spark plugs on a 1998 ford taurus numbered
I don't have a link with pictures, but I will describe the cylinder and coil numbers for both the overhead valve (OHV) and the overhead cam (OHC) as best I can.
Facing the engine from the front bumper.
On the 3.0 overhead valve (OHV) the cylinder location looks like this:
1 2 3
4 5 6
The coil location looks like this:
5 1
6 2
4 3
If you have the 3.0 overhead camshaft (OHC) engine again facing the engine from the front bumper your cylinder location looks like this:
1 2 3
4 5 6
Your coil location looks like this:
4 6 5
3 2 1
I hope this was helpful.
Feb 15, 2010 | 1998 Ford Taurus
Sep 08, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Aug 28, 2009 | Garden
Engine only cranks until it comes up on compression, then stops
I would be checking the valve clearences if its ohv they should be set at 4 thou, If it is side valve they should be set at 6 thou intake and 8 thou exhaust.
Jul 13, 2009 | Garden
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
VALVE ADJUSTMENT
Since the problem was "How To" set the OHV valves, this link will provide the answers using the .005 " valve lash recommendation.
See: http://engines.myfaqcenter.com/Answer.aspx?p_faqid=3441
Great illustrations are also included on this B&S webpage.
Apr 11, 2009 | Garden
Garden Logo
41 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
