Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Back of freezers seems to form ice after a month and this chokes off the cool air to lower section if i take off back and defost it with hairdryer it will work fine for a month
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 31, 2010
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Fridge not cooling
Check to see if your evap in the rear of the freezer is icing up. I had the same concern a month ago. My evap fan( one in the freezer) went out and ice formed in the freezer becuuase of no air flow. The fan you hear running in the freezer also supplies flow to the firdge section through a "dma\\ampner" If your freezer is cold but fridge section is not I would check for a blocked section(blocked with ice build up) where the flow of cold air to fridge section is restricted. I would use your model number and go to www.appliancepartspros.com and search for your fridge with your model number. This will give you a parts, mounting and routints breka down of your fridge and you will have a better idea what your dealing with.
Sep 24, 2012 | Jenn-Air Refrigerators
Freezer side is freezing and refrigerater is warm
You have an Iced up freezer there...is the freezer "packed full of stuff?" If so you are blocking all of the vents that cool the fridge...The freezer section of a refrigerator is responsible for keeping the freezer frozen and the frige cool...air passes between the two compartments via the settings you set on those dials "a b c etc." Take everything out of the freezer and stick it all in coolers or something for a couple of hours see if there is ice built up around the vents at the sides and bottom of the freezer compartment. If so, the freezer needs to be "de-iced" normally this is accomplished automatically via heaters placed here and there throughout the fridge...So this may also be a source of your problem. if the heating element is bad, it would allow ice to form...I can also assume that the airflow from the fan in the freezer is "weak at best" meaning it is also full of ice... You can melt the ice with a hairdryer and some time of course...but be thorough with it. If you have a heat gun even better, just don't get it too close to the plastic or you will melt it. hope i've helped a bit...let me know what you find in there
Jun 09, 2012 | Jenn-Air 48" Side-By-Side Built-In...
Bottom of the freezer keeps filling up with water and freezing solid. eventually leaks thru the door onto the floor. It takes 3 to 4 weeks for it to form thick enough to eventually leak thru the door on to...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE GSS25JF Side by Side Refrigerator
Refrigerator side not cooling
The fresh food section is cooled by the freezer section by forced air supplied by a fan. If you have air flow, check the temp inside the freezer. It should be between 0 and -10. If not look inside your freezer and see if you have ice built up on the back panel. If so you have a defrost problem that is most likely a bad defrost heater, a bad termination thermostat or timer. If ther is no ice then check your fan under the refrig. If you can hear the compressor running it should be turning. If this all checks out then you have a freon system problem like. Low Freon pressure or a restriction.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
Refrigerator side by side neither will won't stay cold
You have an automatic defost malfunction. There is a timer (or circuit board) which controls the run and defost modes of your refrigerator. Once in defost, there is a heater that comes on to melt frost behind back panel. Once a certain temperature is reached behind the panel, a defost thermostat (or bi-metal) cuts off the heater. This maintains your frost-free operation.
Nov 05, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator model NoGC20C7C3Ewith fridge setting just on and freezer setting low following defrosting the operation seams ok but deteriorates with ice forming on the rear freezer panel and the lower...
Defrost system problem. Could be in heaters, defrost thermostat, or defrost timing circuit. Freezing in vegetable section is due to air back flow related to frozen evaporator coil in freezer compartment.
Colder air settles and warmer air raises.
Ice maker problem is separate. Bar up engages micro switch that is supposed to shut it off. Bad micro-switch?
May 27, 2008 | Maytag Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Dec 17, 2006 | Frigidaire PHSC39EESS Stainless Steel Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
