The computer is not talking to printer - we cancelled a program to print anoter one - printer screen is showing error - we turned computer off and on - nothing is happening -
    Problem Solver:
  • 18 Answers
Animal08,
This sounds like a definite corrupt driver, although if you check your services to see if the print spooler is started and in the properties that it is set to manual or automatic. To get to this, if you do not know, is to go to CONTROL PANEL, go to ADMINISTRATIVE TOOLS, go to SERVICES and go to PRINT SPOOLER. Click Properties to see if the service is being used, and make sure it is and that it is started. Also delete and reinstall your logical print device.
Posted on May 08, 2008
Just purchase this printer and can not get past this error to continue setup
On the computer, right click on the start button, then go to Control Panel and then printers or printers and devices. Find your printer and double click it. Then look for something like "See what's printing" Open that up and you can cancel any print jobs that are in the que.
Oct 13, 2017 | PRINTER Office Equipment & Supplies
I have an MG2200 Pixma printer. It stopped printing in the middle of a delayed queue because it ran out of paper. I put the paper in and then I think I turned it off and then on again. It will not...
Log off your computer so it shuts downs.
Log back on
Go to control panel
-Find Printers
-Click on Printers
Plug your printer into computer
-Printer should show up on screen
-Right Click on Printer and set as default
-Left Click on printer
-Click on see what printing
-Cancel job that's printing
Close printer
-Try to print again
Nov 02, 2013 | Canon Office Equipment & Supplies
My printer hp laserjet 4350n is not printing because it shows or display 49. ff04 service error
A critical firmware error has occurred that
caused the processor on the formatter to
abort the operation.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the printer. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 Service
Error.
Recommended action Hp Service Manual
1 Press CANCEL JOB to clear the print job
from the printer memory.
2 Turn the printer off and then on.
3 Go to www.hp.com/go/lj4350_software.
Select Download Drivers and
Software. Check for the latest firmware
image version at the bottom of the
page. If this firmware image is newer
than the one installed on the printer
and the printer can receive a firmware
update, download the newer firmware
upgrade.
4 Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file. If the message
appears only with a certain software
program or print job, contact the
software vendor for assistance.
5 If the message persists when using
different software programs and
attempting specific print jobs,
disconnect all cables that connect the
printer to the network or a computer.
6 Turn the printer off.
7 Remove all memory DIMMs or thirdparty
DIMMs from the printer. (Do not
remove the firmware DIMM in slot J1.)
See Firmware DIMM (LJ 4200/4300
only).
8 Remove all of the EIO devices from the
printer.
Jul 06, 2011 | HP LaserJet 4350 Printer
Computer cancels printer 922
the article is cpyright protected that's the reason. get the web site grabber software or do the ctrl+prt scr and paste it to paint (built in image editor of windows)
now you can print it
Mar 13, 2009 | Dell 922 All-In-One InkJet Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
Cancel print button freeze
Try this:
Start > Run > Services.msc
Look for print spooler, right-click on it and select Restart
Then:
Start > Control Panel > Printers and Faxes > double-click on your printer > Click on Printer menu and select Cancel all documents. Click on Yes.
Restart both PC and printer
Jul 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
49.FF05 SERVICE ERROR
occurred.
Try following these steps -
1. Press CANCEL JOB to clear the
memory.
2. Turn the printer off, and then
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2410, www.hp.com/
support/lj2420, or
www.hp.com/support/lj2430.
Click Download Drivers and
Software
. Check for the
latest firmware image version
at the bottom of the page. If
printer and the printer can
receive a firmware update,
upgrade. Not all printer
models can receive firmware
upgrades.
4. Try printing a job from a
for assistance.
1. After performing the actions
listed in the preceding item, if
using different software
programs and attempting
specific print jobs, disconnect
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
replace the firmware DIMM.
10. Replace the formatter
Jul 14, 2008 | HP LaserJet 2420 Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
occurred that caused the
to abort operation. This type
operations. In some cases,
electrical noise in the cable
transmission to the printer.
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
Error.
the printer memory.
then on.
3 Try printing a job from a
different software
program. If the job
the message appears
only with a certain
software program or
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
HP 4350 ERROR MESSAGE: 49.2F90
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Paper jam notice......make sure paper tray is pushed down.......error....
I've just talked with HP support and they fixed the problem. This is the solution:
1- unplug printer while it's on
2- after 10 seconds, and while it's unplugged, press the cancel and OK buttons at the same time and plug it while holding the buttons.
3- after the printer is on, release the buttons
4- if it does not start the computers, then turn it on manually (with the power button) while pressing the cancel and OK buttons at the same time and release them after the printer starts
5- try the copier and print a page through the computer
6-turn it off for 1 minute and then on again. The message should not be there now
Good luck
Dec 07, 2007 | HP Photosmart C5180 All-In-One InkJet...
210 people viewed this question
jasbo
jasbo
