Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Router its not working with my x box live. it will let me play for about 10 minutes and then disconnect me.
The f5d9230-4 version 5000 is famous for dropping the isp connection and then sending out another dhcp request to your isp to re-establish the connection. The one solution I found is to flash the router with the UK version of the belkin firmware, which is more up to date then the US version.
the links for the updated firmware is as follows
Hope this helps
Posted on May 12, 2008
  • Belkin Master
  • 6,487 Answers
Is your xbox connected wirelessly to your router?
Posted on May 09, 2008
Why am I always instantly disconnected from XBOX live after signing in?
I keep getting disconnected fro xbox live. this has been a problem since I first got xbox live, it takes 30 minutes or something like that and then its disconnects me, for example if im playing call of duty multiplayer it will take me out of the the game. I have a xbox router thingy that is plugged into the back of my xbox and wireless box thing. could I have a easy simple question to get rid of this problem thank you
Jan 23, 2011 | Linksys WRT150N Wireless N Router -...
Belkin Play N600. Acer Vista laptop. Wifi only, laptop wifi connects then disconnects. With ethernet connected the wifi and ethernet shows connected, when unplugged, the wifi will disconnect also.
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 24, 2010 | Belkin Play N600 Wireless Dual Band Router...
Disconnects me for no reason then i lose all my work.
google the ports for the xbox 360 and xbox live, then set your router to forward those ports to your xbox, also manually set your xbox's ip address so it dosent change and your ports won't have to be re-configured.
Jan 08, 2009 | Microsoft Xbox 360 Console
Cannot connect xbox 360 to wireless router
If you use DSL I would also check to make sure you are not being port blocked by your ISP. Some will block you if you exceed bandwidth on a particular port rather than throttling you or shutting you down entirely.
Dec 29, 2008 | Linksys Wireless-G WRT54G Router
Disconnected from xbox live
u need to do a port fordrwading in your router
Dec 19, 2008 | NetGear DG834G Router
Router causing lag after 10-20 min connected.
I know nothing about this type of router. Try pressing the button on the bottom and rebooting your router. Maybe that will help.
Jun 18, 2017 | Zhone 6211-I3-200 Router
Xbox 360 wireless adapter connection
Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
The following ports must be available for Xbox Live to operate correctly:
• UDP 88
• UDP 3074
• TCP 3074
Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
132 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
