Question about Exercise & Fitness
How do you lower an Everyoung 86800F Electronic treadmill from standing straight up?
  • Suzanne Golling Aug 31, 2010
    I cannot find our owners manual. We had to raise the treadmill to the standing up position. I have tried pushing in the two two metal buttons on the shaft with holes in it, but I cannot get it go down. Is there another way to put the treadmill down? Everyoung 86800F Electronic treadmill
  • 503 Answers
You can visit the below mentioned link........
http://www.treadmilldoctor.com/
OR
You can call toll free number
800-750-4766 8am to 5pm M-F CST
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 01, 2010
  • okcjeepchero Dec 10, 2010
    Neither of these responses has adequately addressed the initial poster's question.
    How do you lower this unit from a vertical position to a horizontal position ? I just moved mine and am trying to figure out the same thing.
  • 857 Answers
Proper Adjustments for Treadmills
Your treadmill gets a workout just like you do, and needs adjustments from time to time. Most adjustments can be done at home with a few simple tools. It's worth doing this to save the time and money of calling a technician to your home. Also, regular adjustments will help to preserve the life of your treadmill. Always refer to your treadmill instruction manual for details on adjustments for your particular model. There are some basic adjustments needed on many treadmill models. Always turn off and unplug your treadmill before making adjustments or cleaning it.
.Clean Your Treadmill on a Regular Basis
This is important to the life of your treadmill, and can cause a multitude of problems if not performed. Dust can require the treadmill motor to run harder and hotter, eventually burning it out. Take a few simple steps to prevent this from happening: Unplug your treadmill; use a damp rag (without soap) to wipe down your treadmill; vacuum under your treadmill often; and vacuum under the motor hood as well. Dust between the treadmill deck and belt. Do this entire process once a month and vacuum and dust once a week.
Aligning the Treadmill Belt
The treadmill belt will eventually go off center. You should adjust it or the motor and belt can be damaged. With the tool advised in your user manual (this may be hand tool that came with the treadmill) turn the screw on the back left rear of the treadmill deck to the left or right according to which way the treadmill belt needs to move. Do this until the belt is centered. Many manufacturers advise having the belt running while you do this.
Adjusting the Treadmill Belt
Tighten the belt if needed. Using the tool advised by your manufacturer, turn both screws at the back rear of the treadmill deck in an equally clockwise direction. This will provide more tension for your belt if it is loose. To loosen the belt, do the same but turn the screws equally in a counter-clockwise direction.
Keep the Deck Lubricated
Many treadmill decks come pre-lubricated and you don't need to do this task for the first year that you own the machine. Afterward, you may need to start lubricating it according to the directions in your owner's manual. All you need is a rag, a lubricant recommended by your manufacturer (you can purchase these online) and a tool to loosen the treadmill belt. Unplug the power cord and remove the cover over the motor.
Loosen the screws that you used to adjust the belt tension and push the back roller towards the deck. Now loosen the front roller and remove it by inclining the treadmill so it can be removed. If your treadmill has an incline function, plug in the treadmill, turn on the power and incline the treadmill this way.
Next, remove the rear roller and then the treadmill the belt. Unscrew the screws that hold the deck in place--remove them and lift the deck and the belt out at the same time. Now you can lubricate the deck. Be sure you don't over lubricate the deck as this can do more harm than good to your equipment. Your manual should provide a maintenance schedule and recommended products for your treadmill.
Trim Worn Edges on the Treadmill Belt
Before replacing the treadmill deck and belt, you should trim the edges of the belt if it is worn. Lay the belt flat on the ground. Measure and mark the belt so you can trim it evenly on each side. Cutting only what is worn, take a flat piece of steel or other metal object as a guide and use a razor knife to cut along the edges. After you check to make sure the edges are smooth you can replace the belt.
Adjust the Treadmill Drive Belt
The motor drive belt turns the front roller on your treadmill. It may need adjusting from time to time. It is located underneath the motor cover and connected to the motor. Some newer models have an automatic tension device. You shouldn't adjust these since they are preset. As always, consult your instruction manual for directions. First, make sure the drive belt requires adjustment. This is usually the case if the drive belt or front roller stops when the belt is stalled.
Unplug the treadmill. Find the bolt that runs the full length of the motor mount and loosen it. Then find the set bolt(s) on the motor and loosen these (do not remove the bolts). You may also have a bolt that runs the same direction with the walking belt. If so, take a 2 7/16 inch wrench and make a few turns to this bolt and tighten it. If you do not have this bolt, the drive belt must be tensioned by hand. This requires two people; one person applies increased tension to the drive belt, the other person should tighten the motor set bolt(s).
With the motor cover removed, plug the treadmill in again, walk on the belt and try to stall it to make it slip. If the problem is in the drive belt, it will stop or the front roller will stop when stalled. If the motor, drive belt and front roller turn when the walking belt is stalled, the walking belt is slipping on the front roller and needs a tension adjustment as described above.
Posted on Aug 31, 2010
Everyoung treadmill 86800
see the video attached. and lube the rollers bearing front+back.
God bless you
Oct 18, 2013 | Exercise & Fitness
Looking for owners manual for everyoung 86800F model
go for free download: www.fitness.manualsonline.com or www.manualsfactory.com or www.retrevo.com
sincerely. God bless you
May 07, 2012 | Exercise & Fitness
On power up the treadmills slowest speed is 8 klm's/hr, it can be increased to over 16 klm's/hr, but then only lowered to 8 klm's, which is to fast and dangerous to step straight onto. Is
ADJUST THE SPEED SENSOR , SEE THE DIAGRAM ATTACHED, CLEAN, AND TIGH THE CONNECTOR WIRES.
2) RUN THE SOFTWARE CALIBRATION FOR DIAGNOSE , TROUBLESHOOTING, AND FIX IT.
SINCERELY. GOD BLESS YOU
Apr 28, 2012 | Exercise & Fitness
When standing on treadmill, if incline # ie:5 is entered, bed raises, pauses, then lowers back down while #5 continues to be indicated. this occurs with all incline #s but not a problem if I'm not sta
If your incline is not working it can be a few different things.
1)There may not be any signal from the console which could be a damaged cable tight the flexible cable vs keypanel( spray too with contact cleaner spray) vs display board.
2) the console itself has failed :tigh the connector comming to lower board (main motor controller board).
3)The motor control board may have failed from a worn treadmill belt and deck(exchange it) Test if the Voltage with DVOM is there present 120VAC
4) the motor may have burnt out Test the motor with 120VAC.
5)also a potentiometer geared to the motor so the console knows what height the incline is at ADJUST IT.
6) the gearing can slip, giving the console false information which can cause chassis damage FAULTY.
12_7_2011_6_27_57_pm.gifNow with the block diagram you will have strong resultant for determine what is wrong. This I did for people like you, and to know how the main motor board controls functions by 90% aprox of any treadmills. sincerely.
E.CUADR
MANAGUA, NICARAGUA. C.A
Dec 07, 2011 | RTO Sole F80 Treadmill
How do I lower my Everyoung 86800F treadmill from a vertical to horizontal position ?
This might be of a little help. My treadmill is not an everyoung but on the control panel it has two buttons which are used for adjusting the position. While i was searching for a solution on this i came across an individual whop has one for sale you could call him and find out if you are in the US here is a link to his advert.
http://fayar.craigslist.org/spo/2036394410.html
Hope this solution has been helpful?
Dec 10, 2010 | Exercise & Fitness
EverYoung 75900 needs to be reprogramed Display unit show F1 can you pls provide the code thanks Joanne Pekar
I have a problemwhen i start the ever young model 75900F
on screen F1
please send me solution
Nov 05, 2010 | Exercise & Fitness
The belt on my 68600F EverYoung has quit turning. The display screen is still on and says E2.What does that mean? gaylesues@hotmail.com
e2 normally refers to error in the speed sensor - iff the treadmill starts moving and then stops it is speed sensor related, otherwise if it never starts at all you will need to test your drive motor with an external 18v battery (cordless drill battery) to see if the motor will still turn. if it still turns then that narrows the problem to the motor controller which also means that the motor relays are not working and the controller would need replaced
Aug 04, 2010 | Exercise & Fitness
Have the same problem with my Everyoung Treadmill EY88800K. Display was zapped with static and treadmill became inoperable. Great condition and hate to toss out. Any hope?
End up dismantling the unit and disposing everything except for the motor and belt and rollers. Was a good machine except for no parts support.
Dec 28, 2009 | Exercise & Fitness
Exercise & Fitness Logo
413 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
