Question about Epson Stylus Photo R1800 InkJet Printer
Print head Using the guts of a R1800 as a textile printer, the inks are thick and tend to gunk up the capping station, Now i need to replace them both, don't know the Epson part numbers.
    Problem Solver:
  • 12 Answers
Hey aside from replacing the print head
you may want to check this out
http://www.maxpatchink.com/epsonclean.shtml
or you may want to google another site
Posted on May 09, 2008
I can not manually move the printer carriage on my HP Photosmart B210e printer
Might be service station jammed.Service station work is to clean the print heads,stores spitting ink init as we as capping the print heads to protect from the nozzle drying..After switching off the machine service station capping the print heads and arrest the carriage assm for protecting the print heads, in this condition carraige assm wont come out until its released by service station. Its required expert to release the service station, if you force to pull it will damages the print heads.. You justify what you can do for this issue...If you are capable do it...But care fully
Jan 09, 2012 | HP OfficeJet Office Equipment & Supplies
Have not used my Epson R1800 for almost 6 months. When I turn on the power the printer head, with the cartridges, stayed at the very right end, not moving. The paper and ink lights flash and the head just...
Your User's Guide is available here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
After leaving the printer inactive for a extended period you should expect the ink cartridges to be dried up and the print head 'gummed' in place.
You will need to refer to page 82 of the pdf, Cleaning the Printer.
As part of cleaning remove the existing ink cartridges and while the cartridges are removed try and clean the print head of any ink residue. Note that if the red light is on or flashing above an ink cartridge the printer sees it as empty (dried up).
The print head will not move if ink cartridges need replacement; replace ink cartridges according to the red lights, likely all. Press the ink button to see if the printer will begin the charging cycle. If all is well the green power light will stay on and the red ink light will go out.
If you do not get this desired outcome try Cleaning the Print Head, page 73 of the User Guide. Hold down the ink button when the red light is off for 3 seconds. Run a nozzle check pattern; if nozzels are not printing a clean pattern, repeat this process up to 3 or 4 times.
Feb 03, 2011 | Epson Stylus Photo R1800 InkJet Printer
HP 7780 suddenly stopped printing in red. I have changed the cartridges several times. I am using brand new HP cartridges. Have cleaned the print heads, aligned several times, nothing has heled. The...
Hi Good day!!!
Maybe your print head is clooged (red)
Then most about 98% are more likely to be an ink clog which just needs to be unclogged using something like print head cleaning solution
Basically, if a print head has been left unused for some time... moisture inside the ink begins to evaporate and instead of liquid ink, a thick inky jelly begins to form inside the print head.
When this occurs white lines appear in prints and most people not realizing the problem, will replace their inks... But when that does not work. Some assume they have an electrical fault, and replace their print head, others will replace their printer !
But provided there is no obvious print head damage? In 98% of cases it simply needs a little patience and print head cleaning solution injecting directly into the print head to dissolve the dried ink trapped inside. This will dissolve the clog and allow your expensive ink to flow once again. Most will then print as new.
Thank you for using fixya
Jan 03, 2011 | HP Office Equipment & Supplies
How to replace a print head on a T2265 sprint pro
Tally Genicom T 2265 Printer print head. The following information regarding Print Head is taken from Website. Please go through carefully. Print heads are very sensitive from the type of ribbons you use. These textile tapes, used as consumable in dot matrix printers are made by special technologies. They are impregnated with ink and special oils, which lubricate the print head wires during printing. While print head works, the quantity of ink and lubricant in ribbon exhausts, and the quality of printed matter gradually declines. When this quantity goes down below certain limits the ribbon begins wear to threads. These fine textile fibers mix with cellulose filaments from the paper and form a dark gray dust. This is a sure sign that the ribbon is dangerously worn and must be changed with a new one. Otherwise you will soon need a print head repair service. Still not satisfied about those points, please get in touch with local authorized printer service engineer to set right the issue. Have a Nice Day The same problems you may have with "old" ribbons, because after time the lubricants and inks get dry. The usage of "worn" or "dry" ribbon leads to difficult movement of the printhead's wires, its quick wear or crush. If you wish to use your printhead for a long time without any problems, you must use a quality ribbons with an original guarantee. Never use re-inked old ribbons. This surely guides you to print head repair or to buy a new one. It is a good idea to read the User's Guide for your printer, if you have not already done so. If you don't succeed in finding it, then carefully look at your printer and try to find the lever for printhead positioning, it controls the printhead gap. You must adjust manually this gap in correspondence with the number of printed copies.
Jul 15, 2009 | Office Equipment & Supplies
My yellow ink head on my r1800 printer is clogged.
If it is within warranty then contact epson support. If not and normal head cleaning doesnt work then try a print head cleaning solution such as:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Hope this helps.
Mar 12, 2009 | Epson Stylus Photo R1800 InkJet Printer
R1800 head streaks
I have been plagued by the same problem - the nozzles don't appear clogged - yet on heavier media there is a definite abrasive sound - and its leaving horizontal bands. After many cleanings with no luck I tried cleaning the heads with a bunch of Q-Tips lightly coated in Windex. After removing a ton of black deposits - it didn't immediately fix the problem; frustrated I turned the printer off. The next morning when the clean-heads-on-power-up kicked in - I noticed a large amount of ink collected in the vacuum sponge. It seams the bit of reside left over from the cleaning may have finally dissolved what I can only guess was a large ink deposit that had hardened and was striking the media when heavier stock was loaded. At any rate - no more abrasive sounds - and more importantly no more horizontal banding.
To clean I disconnected the power when the head was traveling. Then the head was free to move as I gently tried using the Q-Tips to clean the heads.
Hope this helps.
Dec 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Copys come out blank
A couple things can cause this you may not have tried yet.
  1. First in your printer driver properties, select the highest dpi setting and the correct paper setting for your type of printer.
  2. Run a print head cleaning cycle. Run up to five cycles in sequence. Print a nozzle check pattern after every one or two cleaning cycles to see if you have made any progress. On most printers, after approximately every fifth cycle, the printer will perform a more powerful head cleaning routine.
  3. Clean the capping station The capping station is a rectangular flat sponge surrounded by a raised gasket. When the print head is in the “parked position,” at the right side of the printer carriage, the gasket of the cap presses against the print head, sealing it. One purpose of this is to keep the print head from drying out due to air exposure. Instructions: (1) push the “ink change” button to move print head off the cap. Unplug the printer (2) Look inside the printer case, below where the print head was originally sitting, to find the cap or caps. A cap is a rectangular piece, approximately 1” high by 2” wide(3) Look at the cap, using a flashlight if necessary. It should be horizontal, not tilted at an angle. If it tilted, there may be a problem with the fixture supporting it. (4) Clean the cap. Sometimes you may notice a buildup of residue or liquid in the cap or on the gasket; other times you will not. Use a drinking straw to deposit warm water, or use the tube from the inside of a bottle of Windex to deposit Windex, onto the sponge. Use your finger to dispense only two or three drops of liquid at a time. The liquid will remain in the cap for a few seconds, but will soon drain out. Repeat this several times. Try not to let the Windex or water spill around the cap, and into the printer. (5) Fold a paper towel into a 4”x4” (10cm X 10cm) pad. Press the towel gently on the sponge to dab away ink and water or Windex. As you push on the sponge, push down and slightly to the right, to protect the spring-loaded mechanism that supports it. (6) Dip a cotton swab (Q-Tip) in water, and use it to wipe gently around the edge of the capping station gasket, to remove dirt buildup there.
  4. Ink flow problems can occur if the air channels on the top of the cartridge become blocked. Check to make sure the cartridges that their is not bits of machined plastic on the top that was not properly removed.
Jul 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
R 1800
where can i get a print head for my epson R1800 printer?
Mar 04, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
