Question about Dell 926 All-In-One InkJet Printer
Printer prints large solid black squares instead of the text
When i print anything that is solid, or anything other than just plain text, large swaths are faded badly or completely white instead of what should be a solid black/gray color. help please.
How old is the drum unit on the printer. Really sounds like either the drum unit, which is different from the toner on the Brother machines, or the High Voltage power supply is failing.
Feb 08, 2016 | Brother HL Office Equipment & Supplies
Won't print large font in solid black. Only prints outline of letters in black
Try resetting word to factory settings to clear all the settings, Then make a new document and type whatever you want with the font size you require, save then print, see what happens.
Mar 10, 2015 | Office Equipment & Supplies
Pages sticking to fuserwhen leading ege has wide
Replace the fuser, its overheating and that would cause the pages to stick the way they have been when trying to print pages of lots of black solid ink.
Apr 19, 2010 | IBM Infoprint 1572 Laser Printer
I have run out of black ink in the large cartridge. Can I make the rpinter use the smaller cartridge to print black and white?
No, the larger cartridge is used for text printing only.
The smaller cartridge is used to add black to images instead of using the color ink to make a composite black.
Don
Oct 23, 2009 | Canon MP610 Photo All-In-One Printer
It will print only solid blocks of black (or color, if I had written in color) instead of the text I write.
Unfortunately it was either hit by a power surge or has a bad circuit board and probably needs replaced.
Aug 03, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Printer always uses large black & runs out, cant isolate other
The BK5 is for black text only. The other black ink is used for shades of black/gray together with the three basic colors in printing color photos. You cannot use it to print black text.
Jul 29, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
HP D7360 prints in magenta instead of black. Both cartridges are
Check your other colours. Anything other than a True Type Font is printed in colour shaded with black, so it sounds like you have a problem with yellow and cyan. Either the ink cartridges are out or the print heads have a blockage.
If the cartridges are not empty or v low, try sitting the print head over a folded paper kitchen towel damped with hot water for 10 minutes. Remove it and try your diagnostic again.
Dec 11, 2017 | HP Photosmart D7160 InkJet Printer
Hp f380 with Visa OS not printing black
when ready to print go first to where it says PREFERENCES click there , and then slect BLACK CARTRIDGE ONLY ,just to be sure that is not the cartridge ,fun a print , see what happens. hope this helps
Apr 01, 2008 | HP DeskJet F380 All-In-One Printer
Printing squares instead of text
Reinstall the drivers failing this goto printers and faxes right click on the icon and select properties. Select Advance tab at the top of the now open window then select print processor once in there select a different graphic mode ok and close then test.
Thanks J
Nov 21, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Dell 926 All-In-One InkJet Printer Logo
531 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
