Question about Whirlpool Washing Machines
Whirlpool cabrio F1 (F60-68) Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly. See Accessing & Removing the Electronic Assemblies. ok HELP HOW DO I DO THIS??? OR WILL YOU COME AND FIX THIS????
SearsTechToo
  • 261 Answers
SOURCE: wtw6600sw whirlpool cabrio
First off I hope you have a Sears unit and second you did not pay a penny. Your F 1 error is a Primary control failure. Part W10104830 and one other do F1 and a oL code.
If you own a Sears machine you qualify for a recall under sf26-779B.
There is two parts to this call the board and a washplate
MCU part # W10201186
Washplate # W10077050
Recall will need your name and phone number and the machine model and serial number.
If you meet all of these conditions to the letter call Sears Recall at 1-800-659-7026
Posted on Sep 13, 2008
canbruce75
  • 1776 Answers
SOURCE: f1 code on whirlpool cabrio top load
This is from a service bulletin. This may be of interest to you. There have been many problems with these machines in this area. Anyway, I sympathize and hope this helps. Best wishes.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 – CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
Posted on Aug 09, 2009
  • 2328 Answers
SOURCE: F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Posted on Dec 13, 2009
  • 327 Answers
SOURCE: How to fix my Whirlpool Cabrio washing machine F1 code
Hello, error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. To remove and replace the control you’ll have to unplug the washer and then remove three screws from the rear of the console assembly. Pull console towards front of washer to hinge open and/or remove console. Then remove the one screw holding the machine/motor control assembly to the console tray and two plastic legs on the rear of the machine/motor control assembly that fit into the console tray.
Thanks
Posted on Jun 10, 2010
Testimonial: "Thanks. Where can I purchase the machine control assembly?"
blueextc3221
  • 15935 Answers
SOURCE: my whirlpool cabrio washing machine keeps flashing F1?
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%^
Posted on Sep 20, 2010
What's code F1?
It Means: Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
Jan 23, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
What is code F1 mean on the Whilrpool Cabrio. The washer stops about 5 seconds when I first put it on.
Ok the Cabrios have alot of problems. In your owners manual there is a big page where it gives you errors codes and what to do it also givees you a diagnostic feature which helps determine the problem. This site gives you the fault codes and what to replace. F1 means primary control failure. Also sometimes when the control board is bad something else could also be wrong. Good Luck
F1 (F60-68)
See Accessing & Removing the Electronic Assemblies. F1 (F60-68)
See Accessing & Removing the Electronic Assemblies.http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Jun 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Cabrio Top Loader it is giving me a code F1 what does this mean?
F then 1 flashes when there is a primary control failure. Unpgug the machine for 1 minute and then power back up. If fault reoccurrs check all connectors.
Replace the machine/motor control assembly if error continues
Dec 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
F1 (F60-68)
F1 flashing on the display indicates a primary control failure.
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
The link below lists Cabrio failre codes.
Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 failure on model wtw6400sw
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 code flashes after washer starts (Cabrio Model WTW6200SW2
A fault code of "F" then "1" flashes when there is a primary control failure. You will need to replace the machine/motor control assembly.
Sep 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 comes up everytime you wash a load of laundry.
F1 = Primary Control Failure
Thank you
Alert F1 when starting wash cycle
Thank You
Sep 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I turn my machine on and i get a f1 flashing? i clear it and try agian and its ok .Do i need a service call? Or is ther something i can do?
Hi
Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does f1 mean and can it be fixed?
F1 means Primary Control Failure.F then 1 flashes when there is a
primary control failure.Replace the machine control assembly and
see accessing and removing the Electronic Assemblies.
Apr 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
314 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
