Question about Sony DAV-C770 System
Headphone settings appear stuck on and cant change them. I have pressed the sound field to change the setting but it only changes between hptheatre and hp 2.1. We had the unit fixed for a laser problem and it does work but i cant get the sound out of thespeakers. It is hooked up correctly. Any advice would be appreciated. Thanks Scotty
  • 3,083 Answers
This might be worth checking out...the headphone jack contacts can get sprung, and not switch the sound back to the speaker circuits. Sometimes they can be sprayed with electrical contact cleaner, and sometimes they can be resprung to make contact. Since you had the unit worked on, its possible that a ribbon cable or other wire was left disconnected. I would take it back and have the folks that worked on it check it out real quick. Chances are that something is not connected, or the software could need to be reset.
Good luck, and hope this helps.
Posted on Aug 31, 2010
Mpc 1000 loud static
Maybe try adjusting the MASTER level?
Good Luck
Other settings
Adjusting the master level You can adjust the level of the headphone and the stereo out by turning the MAIN VOLUME knob. The MAIN
VOLUME changes the analog signal level. This will also adjust the entire level of the MPC1000 digitally.
01. Press the [MODE] key and then the [PAD 10] (OTHER).
It switches to the OTHER mode.
02. Press the [F1] (GLOBAL) key.
The GLOBAL page will be displayed.
03. In the Master level field, set the level.
You will set the digital signal level, which will be sent out to the DA converter. The MPC1000 can output up to
32 sounds simultaneously. There is the great difference in the level when you play single sample and play 32
sounds. If you increase the value in the Mater level field, you can increase the entire level of the MPC1000 to
create more powerful sound with less noise. However, if you playback many sounds at the same time, the
level may be overloaded, which may cause distortion. If you decrease the value in the Master level field, you
can prevent distortion when you play many sounds at the same time. However, you cannot have a good
result in respect to the noise or punch of the sound. Set the appropriate value in the Master level field
depending on the application.
Mar 31, 2014 | Akai Mpc1000 Music Production Center
I cant get my headphone to work on my gemini cntrl-7.
If you are using virtual dj , adjust your settings under configuration - sound setup , change the output settings to headphones.
Jun 08, 2012 | Gemini DJ Gemini CNTRL-7 USB MIDI DJ...
I cant get any sound I did the trouble shooting
Changing the Audio Output
To switch audio output from the internal TV speakers to a connected external sound system or headphones:
Press 1. MORE.
Press 2. 9 (AUDIO).
Press 3. until the Speakers option is displayed. The Speakers option will display only if an A/V receiver connection has been detected.
Press 4. to switch between TV and either AV Receiver or Headphones.
Check if the MUTE key is on.
• The TV's "Listen to:" setting may be set to SAP (analog program from the ANT input) but no SAP is being broadcast.
• Check that the Speakers option is set to TV to hear sound from the TV speakers. Possibly sound is being sent to one of the audio outputs for an A/V receiver or headphones.
• If using an A/V receiver, check that the Speakers option is set to AV Receiver to hear sound from the A/V receiver speakers.
Press and hold the POWER button on the control panel for 10 seconds to perform System Reset.
Mar 07, 2011 | Mitsubishi LT-40151 40 in. HDTV LCD TV
Cant hear friends on xbox360
Hi. It sounds like you are using your Skull Candy headphones through your TV's headphone jack. To make your friends' voices play through your headphones, first press the big X button in between the Back and Start buttons on your controller. Next, scroll all the way over to the right with your left joystick and select Preferences. Now, click on Voice. Change the setting here to either Play through speakers or Play through both.
Feb 14, 2011 | Skull Candy Lowrider Headphones
I would convert an french my samsung e250
Follow this steps,
1. Press the "Menu" button, or select the "Menu" option, on your Samsung phone. Your phone menu will now appear.
  1. 2.Scroll through the menu using the directional pad and highlight the "Settings" option. Press the button in the center of the directional pad to continue.
    3. Scroll to the "Phone" option and press the middle button. Then scroll to the "Language" option and press the middle button. The phone will now show two fields: "Screen text" and "Input language."
    4. Scroll to the "Screen text" field and press the soft key under the word "Change." A list of the available languages will now appear in a drop-down box. On Samsung phones that use a SIM card, an available option is called "Automatic," which will default the phone to the language of the SIM card.
    5. Scroll to the language you want and press the "OK" button.
    6. Highlight the "Input language" field and press the "Change" soft key. Scroll to the language you want and press the "OK" button.
    7.Press the soft key under the word "Save" to save your changes and return to the phone settings menu.
Nov 23, 2010 | Samsung SGHE250i Cell Phone
Hello, I can't get sound to my laptop. when I go into the sound controls it's set for Internal but doesn't give me the option to change it?
Check the Sound driver in Device Manager.
Obtain and install the update Sound driver from drivers page.
Open www.hp.com type the product number (eg: AB123UA) in the search field >> Software and Drivers >> Select OS >> Audio driver and isntall it. Restart.
Next...
Restart Audi service
1. Windows key+R. services.msc and press enter.
2. In the right pane, double click on Windows Audi.
3. Stop and then Start. Select Startuptype: Automatic.
4. Apply | Ok.
Next...
Connect an external headphone and check for sound, if working.....
Connect External Headphone.
Play some musich and as soon as the Music starts
Removet he headphone with a slight ****. Check if sound coming from Speaker.
Next...
re-install OS
Next..
Repair
Jul 24, 2010 | HP Computers & Internet
Cant change time on nec etw phone
Try this:
NEC Electra Telephone System
Changing the time on a Electra Elite & Professional system must be done from the "main" or primary phone. It is usually extension # 100. 1.- Press "FEATURE" 2.- Dial "9#" 3.- Enter hour and minute 4.- Press "RECALL" to change AM/PM setting 5.- Press "HOLD" to change the calendar setting 6.- Press "RECALL" to change the day of week 7.- Dial "#" to move the cursor to day of month field 8.- Enter day of month 9.- Press "RECALL" to select month 10.- Dial "#"to move the cursor to year field 11.- Enter last 2 digits of year 12.- Press "FEATURE"
Carl
Nov 06, 2009 | NEC Electra Professional ETW-16DC-2
Iomega screen play set up, no image on screen
Hold Fast Forward on remote and press "Menu" repeatedly until the screen appears again.
Aug 10, 2009 | Iomega ScreenPlay
Problems changing volume & sound horrible
Your player is flipped. It thinks that it's connected to an external device, and acts as if it in line out output. When outputing to line out, you really don't have volume control, and you hear it right with the headphones, you would be missing some amplification. Try to reverse the actions that choose line output: Press and hold BACK. The Home menu appears. Press the arrows to select the settings icon(looks like a suitcase), and then press play/pause. Press the up/down buttons to select Audio Output and press play/pause. Now you should see "line out" selected. move the arrows to another setting - headphones if available, and press play/pause. Now unless something is really wrong with your player it should work. If it doesn't, use your warranty if valid, send for repair. Good luck
Jun 23, 2006 | Sony Network Walkman NW-A3000 MP3 Player
Music loud, voice low-pitched
Found your question due to having the exact problem you described. New firmware, format... loaded new music, same problem. While switching to yet another set of headphones the sound got better momentarily. The case doesn't appear loose, but squeeze right next to the lcd and lyra name and the audio was fixed. For some reason the audio was mechanical sounding and the voice was almost non-existant unless pressure was placed on the player where described. I tightened the screw in the retaining strap hole and the one under the USB connector flap and all is well for now. Good Luck!!!!
May 01, 2006 | Thomson Lyra PDP2444 53 MB MP3 Player
Sony DAV-C770 System Logo
46 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
