Question about Nikon Coolpix S203 Digital Camera
Lens error ! message Installed new battery- what now?Nikon S203
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Jan 25, 2011
How resolve lens error?
When turning your camera on, aid the lens to to retract back and the camera should reset the lens
Mar 22, 2012 | Nikon Coolpix S203 Digital Camera
How do I fix a Lens error on a Nikkon s203
Go to this website for possible solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 25, 2011 | Nikon Coolpix S203 Digital Camera
My camera lens was extended when it slipped from my hands. I now keep getting the lens error message. One time when I switched it on and off, I got the Coolpix logo I normally get when it's trying to...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 19, 2011 | Nikon Coolpix S203 Digital Camera
Keep getting lens error on my s203 what do i do
Your lens could possible be stuck from opening. Check to see that the lens casing is clean and free from stickiness :)
Jun 21, 2011 | Nikon Coolpix S203 Digital Camera
MY LENS ON MY CAMERA COMES OUT WHEN ITS TURNS ON BUT THEN A ERROR MESSAGE COMES OUT AND WONT GO BACK I N..
Buy a new one, by trying to get lens to go back in will do more damage, the guide pins are shot
Dec 23, 2010 | Nikon Coolpix S203 Digital Camera
Lens error
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
May 31, 2010 | Nikon Coolpix S210 Digital Camera
Nikon N80 error message appears when I turn on camera. Message is f EE in top right corner. New batteries installed did not fix problem
Your camera is telling you that the lens has not been set to it's minimum aperture.
As the camera body controls the aperture, the lens must be set to the minimum (highest number) aperture in order for the camera to be able to select any aperture between maximum and minimum.
If the lens is already set to minimum aperture then please report back for further options, but if my reply has solved your problem then please rate my answer.
Apr 03, 2010 | Nikon N80 35mm SLR Camera
Nikon Coolpix L1 has "lens error" message
get it repaired from a local repairman ,..... we have replaced many lens barrels and gear sets as well as Flex strips which cause this problem ....
Aug 14, 2008 | Nikon Coolpix L1 Digital Camera
Lens Error Message
Hi there
I had the same problem a year after I bought my camera. I returned it to Nikon and they fixed it and returned it. The problem reoccurred 3 times and each times Nikon repaired it free of charge. Then after a year it went again and, when I returned it to Nikon they sent me a new camera. Within a couple of months the new camera had the same problem. I have since resolved it with new batteries! The original coolpix rechargeable batteries do not seem to recharge properly so when I put ordinary AA batteries in it suddenly worked. Good luck.
Mar 31, 2008 | Nikon Coolpix 7600 Digital Camera
Nikon D40 Error Message
Get the kit changed. That should not happen right out of the box, but make double sure the next time around, you charge the battery completely before using it the first time. Not doing this can cause problems.
Nov 18, 2007 | Nikon D40x Digital Camera
Nikon Coolpix S203 Digital Camera Logo
137 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
