Question about Kodak EasyShare C643 Digital Camera
Door The metal connector on the door feel off...is there anyway i can fix that with out haveing to buy a power cord..
    Problem Solver:
  • 4 Answers
I bought a non-working "parts only" identical camera from EBay for $25, and I was able to remove it's batt door. And was able to take to broken door off my camera, and replace it. Now, it's really small work, so I hope you don't have big fingers. You have to be slow and patient. The only tools I needed were one of those tiny "watch" screwdrivers, and a pair of good tweezers. Remove all the visible phillips screws until the back of the camera case lets you know its ready to come off. Fit tolerances are almost microscopic, so it takes courage and care to see what you have to do to remove the front cover also (another screw or two). I practiced on the EBay LCD-broken camera first. Now, the batt door has a hinge pin that you can then pull out with tweezers, but first study the tiny door spring to make sure you know how it goes back. Withdraw the pin and capture the spring. Replace the door, and put everything back together in reverse. In the process I was careful not to touch anything in the camera that's electronic for fear of electrostatic discharge from my fingers that might "fry" something. Feel gratified for having beat the "not user serviceable" Kodak camera repair industry. Saved maybe $75, plus didn't have to buy a new camera.
Posted on May 21, 2008
How do I remove the front driver side power window switch on a 2008 Buick Enclave
Armrest Door Pull
Remove Rubber Cover
Remove 10mm *****
The first step is to pry out the plastic trim plate behind the chrome colored door release handle using a small flathead screwdriver.Then remove the 10mm ***** behind the plate using a ratcheting wrench with an extension bar attached.
Next pry out the rubber cover at the bottom of the door pull located in the center of the arm rest. Use a Torx T-25 (star bit) screwdriver to remove the two screws.
Remove Torx T25 Screws
2 T-25 Torx & 1 10mm *****
Pry Up Arm Rest Panel
Use a flathead screwdriver to pry up the rear of the plastic arm rest panel. There is a plastic hook at the front of the panel, so only pry it up from the rear edge.
Lift Rear End First
Plastic Hook At Front of Panel
Power Window Connector
After you lift out the arm rest panel, you'll need to disconnect the power connector for the window and door lock switches.
Push Connector Release Tab
Power Connector Unplugged
Two More T25 Screws
Push on the release tab with a flathead screwdriver and pull out the power window / door lock connector.Use a Torx T25 screwdriver to remove the two screws located below the arm rest panel.
Remove T25 Torx Screws
Outer Edge of Panel
Push In Center of Fastener
Then move to the outer edge of the door panel and locate the two small round fasteners. Use a small screwdriver to pop in the center pins of the two fasteners.
Pull Out Plastic Rivet
Black Plastic Fastener Removed
Remove Lower Fastener
Pull out the two plastic rivet fasteners and set them aside in a safe place.
Pull Panel Away From Door
White Plastic Pop Rivets
Pull Off Sail Panel
Grab the door pull in the arm rest and tug it towards yourself to disengage the pop rivet friction fasteners that hold the panel to the door frame.Move to the top corner of the door panel and pry off the triangular "sail" panel. On some vehicles, the sail panel contains the tweeter speaker.
Lift Panel Off Door Lock
Pull Out Door Pull Cable
Lift the door panel off the door lock button and tilt the top of it out towards yourself.Use a pair of needle nose pliers to gently lift the metal ball at the end of the door opener cable out of the mechanism.
Disconnect the door cable from the back side of the door panel.
Door Pull Cable Removed
Disconnect Power Mirror
Then disconnect the power connector for the side view mirror by lifting up on the release tab. Slide the power connector off the plastic anchor on the metal door frame.
Slide Connector Off Anchor
Unlock Connector
Connector Detached
Look behind the door panel and locate the large wire connector with the pink lever lock. Swing the lever open to unlock the connector and separate it from the socket.
Door Panel Removed
Power Window Motor
10mm Bolts
Now the door panel can be completely removed by lifting it up and off the door frame.To replace the power window motor, remove the 10mm bolts.
Stock OEM Door Speaker
Remove 7mm *****
The stock "OEM" speaker is held in place by a single 7 mm *****. Remove it with a socket and ratcheting wrench.
Pry Off OEM Speaker
Speaker Removed
Disconnect Power Plug
If the speaker is stuck to the door frame, gently pry it off with a small flathead screwdriver.Disconnect the speaker's power plug by pressing the release tab with the small flathead screwdriver.
Fits 5.25", 6.5", 6.75"
Re-installing Door Panel
According to the Crutchfield website, the 2008 to 2012 Chevrolet Malibu's front door speakers can be replaced withaftermarket speakers in the following sizes: 5 1/4", 6 1/2" or 6 3/4" speakers with the use of a bracket.If you'd like to reduce road noise, make your car quieter and also improve the sound from your speakers, I'd recommend applying some Dynamat Sound Deadener on to the metal door frame.
Re-Attach To Anchor
Plug In Power Side View Mirror
Re-Insert Power Connector
To re-install the door panel, first hold the panel close to the door frame before re-connecting the large wire plug. Swing the pink lever closed to lock it in place.Slide the socket for the power side view mirror back on to its anchor and insert the power plug.
Lock Power Connector
Pink Lever Locked
Re-Insert Door Pull Cable Ball
Insert the metal ball at the end of the door opener cable back in to the door handle mechanism.Slide the black plastic cone part of the cable back into the slot in the door opener assembly.
Door Opener Cable Reinstalled
Hang Door Panel On Frame
Gently lower the door panel down on to the edge of the door frame with the door lock switch through the opening at the top.
Line Up White Plastic Fasteners
Push On Sail Panel
Push Door Panel In Place
Move to the bottom of the door panel and line up the white plastic pop rivet fasteners with the holes in the metal door frame.Push all around the door panel to re-insert the pop rivet fasteners.
Re-attach the sail panel at the top corner of the door frame.
Push Panel Flush Against Frame
Insert Side Edge Fasteners
Insert Larger Piece First
Next move to the side edge of the door panel and first re-insert the larger piece of the two fasteners. Then insert the smaller "pin" piece of the fastener into the middle of the larger piece.
Insert Small "Pin" Piece
Install Lower Edge Fastener
Tighten 2 T25 Torx Screws
Re-Attach Power Connector
Insert Front Hook First
Insert and tighten the two Torx T-25 screws located under the arm rest.Re-attach the power connector to the plastic arm rest panel.
First insert the hook at the front of the arm rest panel and then snap the rear end in place.
Pop Arm Rest Panel In Place
Tighten 2 T25 Screws
Replace Rubber Cover
Insert and tighten the two T25 Torx screws into the door pull cup. Then replace the rubber cover over the two screws.
Tighten 10mm Door Handle *****
Replace Door Handle Trim Plate
Malibu Door Panel Replaced
Replace the 10mm ***** that goes above and behind the door opener handle and tighten it. Pop in the plastic trim plate behind the door handle.
Apr 10, 2016 | Buick Cars & Trucks
LG Ground terminal block wire exploded. Need to replace entire harness and 4-prong power cord. Do I really need to replace the entire harness or can I buy a new terminal block and cut the black grounding...
you can buy a new block and you don't have to replace the whole harness if the wire just burnt at the block,you can cut it,put on another wire connector and reconnect it to the block with the cord,make sure when you're done all the nuts and connectors are tight so this doesn't happen again and use the metal cord bracket,if it's not on your cord buy one,it holds the cord in place so when the dryer moves it holds the cord in place,if you don't use it the cord could cut on the metal frame and the wire connectors on the block will come loose from the cord moving or vibrating with the dryer running
Feb 24, 2018 | LG DLE2101 Electric Dryer
Open button gone and the plastic door is bent and not joined to hinges or the metal part .
I would Talk To PlayStation About Sending YOur Product To Them To Fix .. Or Try Fixing It Your Self... By Un Screwing back and try to repair .. or buy a new one.. depends how you feel about it..
Dec 29, 2011 | Sony PlayStation Portable (PSP) Console
Mem test failure replace Dimm 0
There is only one DIMM slot in the printer.
Unplug the printer, disconnect the interface cable.
Remove the right side cover by sliding it to the rear.
Open the metal access door by pulling on the metal tab located at the left side of the door.
You will see the DIMM, reseat it, plug in the power cord and power up. It will power on with these covers open. If the error comes back, you will have to buy a replacement DIMM. Take the bad one with you to match. BestBuy, Radio Shack or any computer store even Walmart should carry them. They are "keyed", so they only can go in one way.
Apr 05, 2011 | HP Laser Jet Printer P3005dn
1997 mercury grand Marquis driverside rear window motor works but window won't go up. Inner door panel off. Metal cable with a black foam cover and pink plastic clip off. Can't figure what it fits to.
usually this means you need a new window regulator.
Section 01-11: Glass, Frames and Mechanisms 1997 Crown Victoria, Grand Marquis Workshop Manual
REMOVAL AND INSTALLATION Window Regulator, Power Front Door
Removal
  1. If front door window glass (21410) is in the down position and is inoperable, the following steps must be taken; if front door window glass is operational, go to Step 2.
    1. Remove front door trim panel (23942) and front door trim shield (237A04). Refer to Section 01-05 .
    2. Disconnect battery ground cable (14301). Refer to Section 14-01 .
    3. Disconnect window regulator electric drive harness connector.
    4. sva~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Be careful not to strike or scratch front door window glass because it can break.
      Remove window regulator electric drive retaining screws through holes.
    5. Remove window regulator electric drive (23394) from front door power window regulator.
    6. Raise front door window glass to full up position by hand and secure with tape.
    7. Go to Step 5.
  2. Remove front door trim panel and front door trim shield. Refer to Section 01-05 .
  3. Remove front door window glass as described.
  4. Disconnect window regulator electric drive harness connector.
  5. NOTE: Use care not to enlarge sheet metal holes in the door inner panel.
    Remove two 1/4-inch rivets retaining lower bracket of front door power window regulator to inner panel. Use drift punch to knock out center pins for each rivet. Using a 1/4-inch diameter drill, drill out remainder of rivet.
  6. Remove three window regulator electric drive retaining screws from inside door to remove window regulator electric drive from front door power window regulator.
  7. Remove two window regulator retaining nuts.
  8. Remove front door power window regulator from front door (20124).
Installation
  1. Lubricate regulator mechanism with Teflon® Lubricant E7FZ-19590-A or equivalent meeting Ford specification ESB-M1C111-A.
  1. Install front door power window regulator minus motor (23208) into access hole in inner panel.
  1. Position front door power window regulator using upper studs and tabs on window regulator electric drive mounting bracket.
  1. Install rivets retaining front door power window regulator to door inner panel (1/4-20 x 1/2 inch screw and 1/4-20 nut and washer assemblies or equivalent metric fasteners may be used).
  1. Install two upper front door power window regulator retaining nuts.
  1. Install window regulator electric drive with three screws. Do not overtighten screws.
  1. Connect the window regulator electric drive harness connector.
  1. Install front door window glass.
  1. Adjust front door window glass as described.
  1. Install front door trim shield and front door trim panel. Refer to Section 01-05 snorkelbobby_38.gif
Feb 14, 2011 | 1997 Mercury Grand Marquis
Trouble DL no start
The machine requires the door to lock prior to starting any cycle. Sometimes, the door lock connector comes loose. Try this:
1. UNPLUG THE MACHINE FIRST
2. Open the door and remove the retaining spring on the rubber bellow that connects it to the metal front panel.
3. Peel the bellow open on the door lock side (roughly 3 o'clock position)
4. At this point, you can reach in and feel the door lock assembly and the wiring that comes into the bottom of it. Wiggle the connector a bit and push it upward to be sure the contacts are being made.
5. Reassemble everything, plug it in and give it a try. If this doesn't help, you may need to have the door lock replaced.
Good luck.
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I paused the wash cycle to add a garment. I can't get it to start again. I can open the door and the light is blinking, but it will not restart.
  1. I had the exact same problem. Just fixed it. If there are no error codes (F xx, showing on the display) then it's probaly the door closed sensor. At least that's what mine was with same problem. Most likely, it's simply the connector to the sensor that's shaken loose. The unit thinks the door is not closed and will not do anything including trying to lock the door (the latching you hear when first starting a load). slide the washer out so you can get to the rear. Might have to disconnect all the hoses and power, which for me was the hardest thing of all since it's in a cabinet. Anyway, remove the back metal panel by removing about 12 Torx screws and the four plastic slide latches. then remove the top (just three more torx screw on the back that hold the top in place. looking from the inside of the unit down by where the door normally latches there are several electrical connectors (don't forget to unplug the power). one or more of these is probably loose. Mine was the top one. That's it. Note also, there's a pamplet inside with lot's of troubleshooting information. It's taped to the right side panel inside. I'd take it out so you can refer to it later, if needed. why they don't put it in with the owner's manual, i have no idea. It's written for the consumer, though it does have a simple schematic that might be helpful.
Aug 27, 2010 | Kenmore HE3T Washer
Error codes on xerox 212
An E5 most frequently comes from the door connector . When you open the right side on the upper left there is a black connector. Those contacts may be dirty or bent. Carefully clean and reform if necessary. I will send you some other info to follow.
Also if you take the copy cartridge out and and clean all the contacts inside the machine you can see, it may also correct it.
Recurring problem with E5. Door connector has been replaced, contacts on Interconnect board are clean and shiny, but interlock connection still not reliable. When you remove the rear motor cover and press on the door connector, the E5 goes away and the fuser starts to warm up. The door connector is mounted loosely to the door to allow it to locate itself with the interconnect board when the door is closed. If it is too loose, the connector will not make good enough contact to complete the interlock circuit
Jan 24, 2008 | Xerox 212 Laser Printer
Broken door spring on kitchenaid dishwasher
kitchenaid should be made to recall all of these dishwashers that have that string holding door since it could pose a hazzard to children. They should be made to put in a metal cable at no cost to the consumer
Jan 12, 2008 | Dishwashers
Door falls open
I have had this issue TWICE now on a three year old dishwasher, and Sears charges you $150.+ to fix it. It is quite simple to fix, there is a special part that has all the pieces attached to it, except for the spring. You will have to remove the screws that are holding your dishwasher under the counter. This could be behind the rubber on the sides. I had to remove a gray plastic circle piece on the inside to see the screw (it pops right out, don't loose it!). Pull out the machine enough to see the out side- side. You will see a (plastic) white roller, string(rope), and a piece that attaches to the dishwasher. There is a number on the white plastic piece that looks like a L (it just slides out). Thess pieces are called the Dishwasher Door Balance Link. You will need to order these pieces, they are all inclusive, and come for both sides of the door, at a whopping price of $15.00. VERY simple to install. Attach one end to the spring, line up in roller then attach to the dishwasher. It is easier to look at it and follow what is on the dishwasher than me clearly explaining it. I feel that paying $1000.00 dollars for a dishwasher would warrant using metal pieces instead of substandard plastic, for this application. These door are very Heavy and like I have said I have replaced them twice with a waiting time of three weeks for the repair man. Please try it, you can do it.
Dec 26, 2007 | Kenmore 24 in. 16492 / 16494 / 16499...
Kodak EasyShare C643 Digital Camera Logo
48 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
