Question about Dryers
I have a Kenmore Elite Smartheat Quiet Pack 9 and it keeps beeping.... Every time I use it and it is on and running the buttons for the "End of Cycle" signal lights keep lighting up from "Off" to "High" to "Low" and it does it over and over again. I try to press the button but it doesn't turn off. I've unplugged it and plugged it back in. I've tried using a different cycle but nothing works. Please help me - the beeping is driving me crazy. :( Christine Christine
  • 221 Answers
SOURCE: Dryer will run for a
It sound's like the motor might be going bad, the dryer motor may be drawing to much current during operation causing the fuse to blow, check the motor to see if it spin's with little or no resistance, also turn the drum by hand to make sure it spin's freely, or it could be a short in the wiring that's causing the fuse to blow, check the wiring for a frayed or damaged wire, or for a wire that may be making contact with the shell of the dryer.
Posted on Apr 15, 2009
SOURCE: kenmore Elite HE4 - Smartheat Quietpak9
Dryer heats but will not dry clothes. Uncloged linted in screen and where the tube is. Did not fix the promblem. Could it be the heating element? And if so what is the cost to replace it?
Posted on Jul 27, 2009
SOURCE: I have a kenmore elite smartheat quietpak 9 model#
I know it might be coming too late for you...but at least it may help others. I`ve just fixed the problem myself. First you didnt mention if the inside light turns on n off with the closing of door. Mine was burned so I replaced it to find that it was always on. so I figured it had to be the door switch. I called Sears n the part was more expensive there $52 cad but they had it in stock.So I unplugged the Dryer n turned the breaker off. ( as an amateur , one should b xtra careful...)unscrewed the 3 back screws, the few screws holding the pieces of metal under the top enamel cover, gently pulled up the control panel enough so I could reach the plastic connector that links the interior wires to the door switch n pulled the defective part out n gently inserted the new one in as I didnt take the whole front apart I did need a hanger wire to grab the wire from the top. Obviously u could take the front of the dryer off but I could easily see the wires n picked it up on the first try,the whole process took me 10 min max n it works. Oh yes! I did remove the very bottom front part ( 2 screws) only to find a manual in there it will tell u how to test the dryer n get a error code back ( in a nut shell u press more time less time more time less time within 5 seconds while the dryer is off (no lights) n in the manual it gives u the meaning of error code...Good luck to all!
Posted on Aug 11, 2009
SOURCE: My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Posted on Feb 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore HE4T elite: Incomplete F 06 error
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
The drum won't turn in my kenmore elite smartheat electric quiet pak 4 dryer
CHECK DOOR SWITCH, CHECK FOR BROKEN BELT? CAN U OPEN IT WHILE ITS ON AND TURN BY HAND AND SEE IF IT STARTS? REMEBER TO PUSH IN DOOR SWITCH BUTTON WHEN TURNING IT
Feb 12, 2015 | Kenmore Dryers
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer will run for a couple of minutes and will stop/ Pops the fuse. We are getting the Power failure code. Kenmore Elite Smartheat quiet pack 9
Apr 15, 2009 | Dryers
Kenmore smart heat quiet pak 9, just beeps won't start
m dryer did the same thing tonight and it was the door switch luckly i wiggled it and it came back on
Feb 22, 2009 | Kenmore Elite HE4 Electric Dryer
Control locked
Mine has an "auto dry" button. It says underneath, "Press & hold 3 seconds..." to unlock control. I did it, it worked.
Feb 07, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
73 people viewed this question
Top Dryers Experts
