Question about Refrigerators
I have an ED2JHGXRBOO side by side refriderator. I am looking for a manuel to help me trouble shoot. My ice maker has quit working and we think it may be the motor. Thank you
Look like Water valve, Check the OHM on Ice maker valve the red color one, or remove 2 screw that hold the vale, pull it out,, unplug the wire that attached to the valve, also the pull out the tubing that supply water to the ice maker by depress the ring while pull the tubing, make a jump wire wirth the cord plug on one end the other end attach the wire connector with insulated plug in to the ice water supply valve side, you will see if the water come out, if not replace the vale which about $39.95 @ Amazon.com, hope this will help.
Posted on Oct 22, 2011
Ice maker wont work
The ice maker gets its water from the filter too. If there is NO water getting to the ice maker then look at the solenoid that lets the water into the ice maker. If water seems to be frozen to the underside of the Ice maker, take the unit out and allow it to dry before putting it back in.
Jan 14, 2014 | Samsung RS267TDBP Side by Side...
Ice maker is not working. I have checked all the normal trouble shooting suggestions and it has not responded. Any suggestions?
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Mar 20, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Just replaced the water filter on our side by side Kenmore 53569202, thinking that may have caused our ice maker to quit working. when opening the door to the freezer, there is a red light blinking twice...
You could have ice in the water shoot which formed because your inlet valve is clogged. The inlet valve is locater in the back behind access cover. Melt the water shoot with a hairdryer and then replace your inlet valve. Fairly inexpensive and easy to change. The reason the water shoot becomes ice is the inlet valve get slower and slower water flow which gives it time to freeze on the way in to the ice maker. Hope i helped, Rate me.
Aug 27, 2010 | Kenmore 53562 / 53564 / 53569 Side by Side...
My ice maker quit. Just 1 yr old. Made a bunch
Make sure that the bin is back in all the way, and that the position of the bar is in the "on" position.
--W/D--
Aug 18, 2009 | General Electric GSHS5PGXSS Stainless...
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Water leaking from bottom of refriderator
Is this a self defrost refrig. if it is then it might be doing that, which then you might want to look for the drain that is suppose to drain into this pan. It might be missing the pan try that, let us know thanks.
Dec 07, 2007 | Refrigerators
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
