Question about Refrigerators
I just purchased an old GM Frigidaire from the 70's i think. The Fridge has one main exterior door and an Ice box/ freezer (similar to micro or dorm fridges) The Ice box freezes, but the fridge only gets to 52 degrees. I'd like it a bit cooler. Ice box also drips water. Any suggestions?
  • wtoddkuebler Aug 31, 2010
    Fridge model number looks like A-3913821
  • 503 Answers
It sounds like you have a problem in the automatic defrost function. The most common problem on a Hotpoint/GE fridge is the defrost heater element burning out.
Remove the back wall from the inside of the freezer section and you will see the heater below the evaporator coil. You will need to check it with a volt/ohm meter to know for sure if it is bad, but that is the most likely problem.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Aug 31, 2010
  • Refrigerators Master
  • 4,924 Answers
This kinda old fridges...have a temperature button inside ..and has to be set from there ...I dont think that any temperature is available on the setting button but levels...from 0 to -7 ..or something like that First thing to do is to defrost it completely ..and clean it good..specially the ice box..after that set it to a lower temperature from that switch ...and let it freeze again ...If the temperature do not get down to the values near 35F ...than it will have to get it to a repair shop and complete the freon level ...
the dripping of the ice box..is kinds normal on this models and when the inside temperature is way above 32...but it is accelerated by the lack of isolation ...if the door of the ice box is not closing well..
anyway ..it supposed to have a drain drawers under the ice box ..specially for collecting this flow..
so..low the temp...see that the door is well sealed ...and if it do not want to get to a lower temp...see if the freon level is ok ..and complete it if there are any leaks..in the installation ..
Fridge warm and freeze cold
Rachael, I recently had a similar issue. Unfortunately, the problem you describe could be related to several components & sensors that could have failed which cause similar symptoms. There are a few things that you will need to start with in order to best lead you in the best direction for repair. First, ice building up says that there may be a problem with the auto defrost cycle. Usually a sensor that sits on the evaporator in the freezer side. You want to start with actually measuring the temp in the freezer and the fridge. If you can, remove items, turn fridge off & then unplug fridge from outlet. Let sit overnight with doors open. Two goals, here. One, ensuring that any ice that has formed in the air passages has a chance to melt completely. Second, unplugging the fridge helps "reset" the control module. You stated "hearing the motor" working. Do you mean the compressor or the fan in the fridge. IMPORTANT, you need to make sure that when the fridge is "running" that you can feel air blowing in the freezer & fridge section. Do this before turning off & unplugging. Lastly for now, did anything out of the ordinary happen before you noticed improper operation?
Jan 15, 2014 | Frigidaire Refrigerators
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire FRT045GM freezer works but fridge does not
hi ,
your freezer cabinet need to get all out and open the back wall.
  1. you have 2 element that can be check one is the heating element , two is the thermostat.
  2. you need a volt meter to check them.
  3. if the frost is all over the coils then one of the element i told you before, is bad
  4. if the frost is in one area not all over then you got gas leak.
  5. good luck 911service today.com...let me know
Jan 03, 2010 | Refrigerators
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
Ice build-up on the inside top of of freezer door
This is a problem that the factory has released a bulletin on.They have released new hinges, and insulation for inside the door. So far I've only seen the bulletin for Kenmore upright freezers made by Frigidaire. Since it is a Kenmore the bulletin is a Sears Service Flash but the units are identical. For sears its SF46-517. They may extend the service to Frigidaire units but you'll have to contact Frigidaire about that.
Nov 04, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Punctured freezer wall in dormer fridge
Usually try not to even answer these questions because anything less than a FixYa drops my rating, so maybe don't bother rating, OK?
Yes, it's a goner. Repair would cost more than a new unit.
Oct 27, 2008 | Master Bilt Indoor Step In Cooler 70""W x...
Dorm refrigator icing up
Make sure the fridge and freezer are not packed with food. It needs a lot of breething room.Also make sure the door is seeling tight. Not a lot of room in small fridge. Good luck
Sep 06, 2008 | Frigidaire Refrigerators
Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Mar 30, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
